Lost my power cord cover - Fiberglass RV
Click Here to Login
Old 07-05-2009, 02:53 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I lost my power cord door cover on my 13' Scamp.
Scamp has replacements for $5.00 plus shipping.
http://shop.scamptrailers.com/p-264-cord-p...efore-2003.aspx
are there any other suppliers out their.
Old 07-05-2009, 02:56 PM   #2
You should be able to find it at nearly any RV parts supply place. Here's a quick find on Google:
Hilltop RV Superstore
Old 07-05-2009, 03:57 PM   #3
Adrian W's Avatar
Red face
Yes, most RV stores would have some type of cover, but I have not seen one like yours. Simular, yes, but not as neat as the old style seems to be, not a well made as well perhaps. I have my cover "door" taped on, one side of the "hinge" broke off two years ago. I had been making a temperary hinge with white duck tape, but this year I used white vinyl tape.
I want to put off having to take out the rivets.
DesertHawk- Las Cruces, NM USA
2015 Lance 1985 ~ Casita de Campo ~23' 4"
~Previously ~ 2005 16' Scamp
2009 White Ford F-150 Reg. Cab Longbed ARE Topper
Adrian W is offline   Reply With Quote
Old 07-05-2009, 04:49 PM   #4
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Mine just broke off my 76' Trillium on this last trip - looks like it's time to replace all 3 cover plates on my Trillium as they are all finally falling apart from weather exposure. My problem is I have the beige Trillium and I doubt that I will be able to find anything but white now. One of the forum's members was having a tough time finding a quality replacement for his Trillium as the replacements are all cheaply made.
Old 07-05-2009, 06:00 PM   #5
I certainly can't attest to the quality of the materials, but if you click on the link I provided you'll see Off White as well as Polar White. I bought an Off White Stove Vent hatch cover and it certainly isn't bright white.... almost a cross between a tan and white. Might not be perfect match to your old ones Booker tho... Removing and then replacing the vent cover by riveting wasn't any big deal. And, I used butyl too.
There's one exactly like the one Kevin is looking for too.
Old 07-05-2009, 09:21 PM   #6
Booker B.'s Avatar
Thanks Donna, I will try those out. Do they sell the water intake/outflow covers too?
Old 07-05-2009, 09:33 PM   #7
Don't know... what do the Trillium's look like? There's three pages of water "fillers," here:
Hilltop RV > PLUMBING > WATER PRODUCTS > FILLERS >
Old 07-06-2009, 05:15 AM   #8
Kevin K's Avatar
Do I drill out the rivets to take the old cover off or can I grind the rivet heads off? (will not be using the old cover)
Old 07-06-2009, 10:53 AM   #9
Booker B.'s Avatar
Hi Kevin,
I had better luck drilling out the old rivet heads and then popping it through that way. If you drill the same thickness as the rivet you can end up with the rivet head stuck on the drill bit and it's hard to pull off. I haven't tried grinding them.
Thanks Donna, I found the the 3 water intakes on that link.
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 12:43 PM
30 amp Power Cord francene Problem Solving | Owners Helping Owners 13 01-31-2010 07:50 AM
Sealing the Power Cord Door when in use Keith Williams Care and Feeding of Molded Fiberglass Trailers 21 09-29-2009 11:47 AM
Fusing question for main power cord Parker Buckley Problem Solving | Owners Helping Owners 25 03-21-2009 07:55 PM
Power cord hatch/door Legacy Posts Electrical | Charging, Systems, Solar and Generators 11 10-17-2002 05:46 AM
