Magnesium Fire Starter -- Cave Campground, Lassen National Forest - Page 3 - Fiberglass RV
Click Here to Login
Old 02-23-2016, 06:10 PM   #41
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Originally Posted by Ellpea in CA View Post
Mike, that sounds like a transition thing. The lint needs something more to catch before moving up to a log or kindling or charcoal. So you'd start with lint, add some dry, broken twigs, and then gradually keep adding more beefy material.
Well, the lint didn't even want to finish burning, let alone catch anything else on fire!
Old 02-23-2016, 06:14 PM   #42
james kent's Avatar
Trailer: Boler 1984
Originally Posted by Rzrbrn View Post
By the way it really helps to use a windscreen around most stoves, particularly the alcohol stoves. Helps heating things faster and uses less fuel. Something like this shield work very well (Amazon): HIGHROCK® Lightweight Compact Folding Camp Stove Windscreen
Name:	ImageUploadedByFiberglass RV1456272310.222457.jpg
For years I carried the rim from a cake mould similar to this. It would be wrapped around the pot kit while travelling and opened up and placed around the camp stove in windy conditions. They are available in second hand stores for a buck or two.
Old 02-23-2016, 06:43 PM   #43
MarkyVasquez's Avatar
I use the Weber cubes to light my fires. I think it's paraffin wax. There are videos on YouTube where they float it on water for an hour and it'll still light. It'll light with a magnesium and steel fire starter. They're also small, last about 15 to 20 minutes and you don't have to worry about spilling liquids. They're also very light, inexpensive, and can be found at Walmart, Lowes, and Home Depot for under $4 for 24 cubes. Click image for larger version
Name:	ImageUploadedByFiberglass RV1456274528.773373.jpg
Sent from my Nexus using Fiberglass RV
MarkyVasquez is offline   Reply With Quote
Old 02-23-2016, 06:56 PM   #44
Just don't mix them up with your Nicorette gum.
Old 02-23-2016, 07:17 PM   #45
Trailer: BigFoot
The cake mold windscreen is an elegant solution to the problem of windy conditions. Never heard of that one.
Rzrbrn is offline   Reply With Quote
Old 02-23-2016, 07:47 PM   #46
Mike Magee's Avatar
They're not quite that small! I've used these before, but for some reason the aesthetics of a wood chip/paraffin stick seems more palatable for my fire. Those stark white, unnatural-looking cubes just shout "hazardous chemicals" to my brain; valid or invalid, I recoil from using them. Oh well, I'm weird.
Old 02-23-2016, 07:53 PM   #47
I know folks who use those paraffin cubes to light the charcoal in the chimneys for Dutch Oven cooking. Seem to work well.
Old 02-23-2016, 11:50 PM   #48
I know what you mean about the chemicals. I figure if they do add anything to the wax, it's probably something petroleum based like charcoal starter fluid. It's just used to start the fire. So by the time the fire is started it'll probably burn off any unwanted chemicals.
The best way to get a fire going is to use a little bit of muscle, a bow and lots of pressure on a stick with a little moss on the end.
Old 02-23-2016, 11:52 PM   #49
Mike Magee's Avatar
Marky, no chemicals in that last fire starter, for sure! Unless one counts the pain reliever after applying all that pressure... lol
Old 02-24-2016, 12:16 AM   #50
Everything on and in this earth and the universe is made of chemicals.
Old 02-24-2016, 02:56 AM   #51
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
Aha. This must have been some pretty defective lint!
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 02-24-2016, 05:11 AM   #52
Tom Trostel's Avatar
I always use Rutland Safe Lite fire starters for charcoal or wood fires. They look like sawdust and wax pressed together. They burn hot for 10 minutes. I've never had them fail. These seem to be very popular with Big Green Egg owners (not a trailer, it's a grill).
http://www.amazon.com/Rutland-Safe-S...d+fire+starter
Old 02-24-2016, 08:39 AM   #53
Paul O.'s Avatar
Yup, the lint was loaded with some fire retardant chemicals, for our own benefit...
Old 02-24-2016, 07:33 PM   #54
Mike Magee's Avatar
Fire retardants in our clothing, that must have been it! Well, you just can't depend on dryer lint from our house. From now on, it's navel lint for me...
Old 02-24-2016, 07:56 PM   #55
CA
Navel lint
MIKE! MIKE! Please remember to remove lint from navel before lighting
Best,
EllPea in CA
Old 02-25-2016, 11:08 PM   #56
Mike Magee's Avatar
NOW he tells me! (typing from the burn ward)
Old 02-26-2016, 08:43 AM   #57
Originally Posted by Donna D. View Post
Here on the WET coast we have a plant/tree that will burn when green or dripping wet, leaves and all. Vine Maple - Acer circinatum is a species of maple native to western North America, from southwest British Columbia to northern California, usually within 300 kilometres of the Pacific Ocean coast, found along the Columbia Gorge and Coastal Forest.
It will smoke, for certain, but burns HOT. So if you absolutely need something to get a fire going when it's raining, I can suggest this.
Ummm, how to put this? I think that is a picture of a thimble berry? But I'm one of those forestry folks who didn't know that vine maple burned well unless dry. I've sure cussed at it a lot. It is nasty to walk through, or cut because it whips back at you. I do know it burns hot when seasoned.
slowpat is offline   Reply With Quote
Old 02-26-2016, 09:40 AM   #58
That's a Google image when I searched, but that's what I remember it looked like, but we know what happens to a rememberer as we age!
My dad was the one that taught me about Vine Maple and cold rain. He hacked off a thin, leafy limb in the pouring down rain. Took his knife to the bark and core until it looked like it was just a stick of hair. Did that to a bunch of this "brush" (as he called it). Struck it with a long fireplace match and it took off! This was in a fire pit, protected from wind... but boy was that rain cold. We had a nice hot fire.
Old 02-26-2016, 09:22 PM   #59
I'd take a picture of mine but it hasn't leafed out yet. I burned some slash this morning and was contemplating this. I'll try that sometime. I used a fusee (road flare) and dry kindling to get my fires going this morning.
Sekrit forestry trick--not recommended but has been done and only in the winter when snow is on the ground and will be on the ground for days to come--never do this, etc. but I heered that you can light the dry moss on a dead lodgepole and it will run up the tree. If the tree is recently dead, and conditions are just right, the needles will light and you have a big torch. Of course, I have never done anything like that...
You can also pour saw gas down a hole in a stump and that provides a nice lunch fire--same conditions as the tree thing and same disclaimer...
Old 02-27-2016, 08:05 AM   #60
Paul O.'s Avatar
I suspect that the high flammability of the vine maple and the fact that it has nutritional value is related to its high sugar content. Any botanist/arborist hanging out here to confirm this speculation?
Magnesium Anode Rod or Aluminum? Kevin K Care and Feeding of Molded Fiberglass Trailers 4 04-23-2012 08:36 PM
Lassen Volcanic Nat'l Park Adrian W Camping, Campout Reports 3 10-08-2009 09:52 PM
Mammoth Cave campground Chris Z Camping, Campout Reports 4 03-28-2007 03:07 PM
Now HERE is an RV that's a real conversation starter! Buck62 General Chat 13 12-21-2006 08:23 PM
Fire, Fire Everywhere & No Volunteer Fire Dept Raunie Aasland General Chat 2 11-24-2006 09:05 PM
» Trailer Showcase
Truusje
marijke
197 Scamp
JenT
