Click Here to Login |
12-08-2018, 05:21 PM | #22 |
Name: Dick Trailer: '15 17' LD Casita and '17 Tahoe LT
Buelfire- Do you have any pics. of your loaded 638 behind your Casita? I keep thinking that is what I would like to try but still just not sure that is a good idea. Other problem is that several states will not let you pull a bumper pull with a bumper pull. My Honda 700xx weighs in at 500 lbs. plus the weight of the 638 is getting close to 1/3 the weight of the Casita. And maybe add a fuel can a few odds and ends. Do you have any idea of what the tongue weight ended up being? Thanks dm.
12-08-2018, 11:08 PM | #23 |
Name: Tim Trailer: in the market
Ohio
Stevebell, I feel your pain.
I would like to figure out how I can safely carry a 300 lb motorcycle attached on the back of a Fiberglass trailer or on the tongue/A-frame portion of the trailer frame. Has anyone done any welding mods to make this work and still have a safe trailer that follows properly? I have a pickup but unlike the O.P. - I don’t want to give up the space in the truck bed and I want to use a topper or cap on it and store gear there. My current bike is a Suzuki DR-650 which I like but it’s heavy (at 370lbs with empty gas tank) to mount on a clam shell trailer frame. With a smaller Pick-up and a smaller light fiberglass trailer, every pound counts when trying to make this work due to the limited hitch weight and lighter framing materials with a 17’ clam shell. The bike has to be less than 300lbs and better 250lbs to even think about making this work and even then there are still problems with weight distribution. Even if the shell and trailer frame could structurally handle hanging 300 lbs on the back of a trailer that is designed so it exerts 250 – 300 lbs on the hitch ball, one would need to add a bunch of weight to the front of the trailer just so it tracks properly. I’m just not sure the frames can handle the dynamic force of a big bump at highway speed with a 300 lb bike on the back. There are really only two dual sport bikes out there that are under 300 lbs that can handle off road trails and whose motors can comfortably sustain 65 mph on the highway…the New and expensive Honda CRF450L and the older Yamaha WR250R both of which weigh about 290 lbs. I could probably get the weight down to 265 lbs if I removed the front and rear wheel/tires and carried that weight in the pick-up but once I start making “setup” of the bike a chore, I’ll be less inclined to use it. There are some thorough-bred 450 class bikes made by KTM and BETA and a few other manufacturers that have essentially used slightly de-tuned race bikes and made them street legal and they are closer to 250lbs but they don’t do well with highways speeds, the motors need rebuilding frequently and they are very expensive. I wish Escape or Casita or other Fiber Glass Shell mfg. would offer the option of a heavy duty trailer Frame when you order your build and select all your options or offering the 17’ Fiber Glass Shell on 19’ or 21’ foot trailer frame so a motorcycle or other heavy equipment could be added. If the Shell was on an easily adjustable slide that would be even better for balancing the load and maintaining the correct tongue weight depending on how you loaded the trailer. I’ve see some Collapsible/Pop-UP A-Frame trailers that have a substantial deck area on the Tongue designed for 2 or 3 bicycles so making it work with a light motorcycle could be a solution but I don’t want that type of Travel Trailer RV. Since nobody makes a Clam Shell that can accommodate this need I’ve been thinking I might have to get a small Cargo Trailer or toy hauler and maybe build it out to my own specs using my own interior finishing products and appliances. This place in AZ let’s you do this. DuneSport in AZ - https://dunesport.com/toy-hauler/build/bumper-pull. But if I go that route I'll probably have to buy a bigger, thirstier truck...ugh...so many tradeoffs...I'm definitely suffering from "perfect rig" anxiety. I won’t do the double or triple trailering. I won’t mount a hitch to the front of my truck (Honda Ridgeline) and carry the bike there. That would be pushing it weight wise and interfere with both my view and air flow to the radiator. I want to preserve my limited truck bed and secure the space with a cap/topper. The other option is a small B+ or class C motorhome and mount the bike to the back using a hitch mount rack or towing a very light weight (3500 lb) older Nissan pickup and carry the bike in the bed of the towed pickup or tow a 3500 lb jeep with the bike mounted on the rear hitch rack on the jeep. These are real “first world problems”…ya know? But I’d appreciate it if someone could solve it for me. Like the OP, I don’t want to give up the bike. A good Mountain e-bike might work as a substitute for my desire to explore trails but it would not get the highway work done. |
12-09-2018, 06:56 AM | #24 |
There was a Hunter Compact Jr. that had a whole new frame built to create a mount on the tongue for a small motorcycle. Tongue weight was quite high, so it was towed with a 1/2T truck using a WDH.
I've also seen a few molded trailers removed from their frames and dropped onto flatbed trailers. That gives some flexibility to arrange the loads- cabin and motorcycle- to get a better balance, but it increases overall weight. If you want to keep your Ridgeline, the custom cargo trailer sounds like the best option. If you want molded fiberglass, look up Chariot Trailers. |
12-09-2018, 04:58 PM | #25 | |
Name: Shawn Trailer: 2021 Bigfoot 25B25RT. Prior units: 2019 Escape 21, 2001 Casita SD17
Kentucky
12-09-2018, 06:37 PM | #26 |
Kentucky
12-09-2018, 09:04 PM | #27 |
Buelfire- Looks like a trailer full. I have a Honda 700xx that will fit an 8' trailer with room to spare but my Yamaha rhino barely fits on a 10' trailer. I think the Rhino and a 10' trailer will be to much for the Casita, so will make do with the Honda. I have also considered just buying a Dual Sport bike and putting it on the front of the Tahoe, or even a smaller dirt bike that weighs less than 200 lbs. but would rather not lose the street ability. Many riding areas have to be accessed by highway so it needs to be street licensed. As I mentioned in an earlier post, a setup like yours can be seen in the gallery on the Casita web site. I thought it might happen to be yours. Thanks for your help. dm.
12-10-2018, 06:06 AM | #28 | |
Kentucky
12-10-2018, 10:39 AM | #29 |
Buelfire- The link to the picture is on the Casita manufacturer web site. The link is casitareaveltrailers.com. When it opens, go to Resources and scroll down to Gallery. Problem is they are 3 pages of just thumb nail pics. and you will have to go through them to find it. I think it is on page 4 and is #168. Let me double check. Yep. Still there. Hard to see from the thumb nails but it is in the bottom row and the middle pic. Looks as if the trailer sits level and not enough tongue weight to make the Casita sit low in back. Have you also tried the 7812 behind the Casita? The 10' would work well for me, I think but am concerned about the weight. The Rhino weighs around 1200 lbs. plus another 400 or so for the trailer. Sounds as if you have had good luck with carrying on the front of your vehicle. Might be the best way for me. Just hate to have to buy another bike. Hard to find a dual sport that weighs much under 300 lbs. Wasn't sure the Tahoe could handle it. Chevy dealer says no problem. dm.
12-10-2018, 11:10 AM | #30 |
Kentucky
DM, That is not my picture, but certainly looks like my setup! The weight of the 7812 Aluma is a lot more than the 638. I can barely move the 7812 around my property by hand, however the 638 is no problem to move, ever up a slight grade.
12-10-2018, 02:00 PM | #31 |
Sure makes it easier to be able to move it by hand. I used to have a 4x6 that I carried a smaller atv on and could maneuver it up a slanted drive as you mentioned. My boat was larger and was always a hassle to park with a vehicle or with one of the other atvs. Thanks again for your helpful info. dm.
12-10-2018, 07:10 PM | #32 |
Check out swivelwheel.com to haul your motorcycle behind your trailer without being a double tow.
Dave & Paula |
12-10-2018, 07:18 PM | #33 | |
How would that not be a double tow? It's still a trailer.
What happens to the hole when the cheese is gone? - Bertolt Brecht |
12-10-2018, 07:29 PM | #34 |
12-10-2018, 09:54 PM | #35 |
DavidB- I called Swivelwheel a few months ago and they felt that my Casita was to small and they would not recommend even trying it. Another company called Singlewheel recommends at least a 30 footer and a 5th wheel.
12-10-2018, 10:51 PM | #36 |
Name: XXX Trailer: whatever
NA
Hesitant Reference
I'm hesitant to refer you to another forum source, because these can be proven A-holes in their mama's basement just wishing they were doing what we're doing. The shiiits live vicariously though us.
You think the fiberglassrv.com forum has opinions? OMG...this so-called moto forum has almost anyone and their mama give you their Moto hauling opinions under the sun (and many in the darkness of their mama's basement) Thus, the juvenile bullying mentality is a double standard for RVs and Motos. I don't waste my time to log in there anymore. You can just read as public without an account, like fiberglassrv. However, if you choose to log in, there are a few knowledgeable Jems of members on the forum...you just have to be a good gardener to get to the information you seek and be cautious of your postings. Operate like Indiana Jones or Lara Croft here: https://advrider.com |
12-10-2018, 11:02 PM | #37 | |
Name: Scott Trailer: 1978 Trillium 1300
Scott |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Border Bike Rally (& Car Show), Bike & Car Weekend event (ON S | John J. M | Rallies, Get-togethers, Molded Meets (Archive) | 1 | 06-07-2008 06:28 AM |
Meet & Greet and Wine Tasting (Welcome & Introductions) | jrnutpaul | Oregon Gatherings | 0 | 07-05-2007 04:29 PM |
30 amp vs 15 amp? | Greg A | Problem Solving | Owners Helping Owners | 27 | 03-16-2007 09:17 AM |
15 AMP TO 30 AMP QUESTION | Karalyn | Problem Solving | Owners Helping Owners | 19 | 07-04-2006 07:34 AM |
» Trailer Showcase | |
The Egg KCMongo |
Somewhere Else BrianT |
» Featured Campgrounds |
