You may be able to do this yourself by using the Edit button of the post, one of the choices on the edit form should be delete.
If that does not work then report the post you want removed to the moderators by clicking the icon of the red triangle with exclamation point under your name in the post you want removed.
Brings up a box to say why you are reporting post, just say you want it removed for the reasons given here and they can delete it. Normally used to report posts that violate community rules but since it provides a direct link to the post it is a good way for moderators to jump to a post and delete for non offensive reasons.
