need help on Electrical question - Fiberglass RV
Old 02-28-2018, 06:51 AM   #1
Monte W's Avatar
Trailer: Perris Pacer
Hi good people. So my head is about to explode ! I gutted my little egg and the one thing i didn't give much thought to is what electrical stuff to put back into it! I thought i'd do a little research on the web and come up with a plan on what to buy but crap there is so much to chose from . I just want the basic stuff ! Any ideas would be helpful! I want to be able to run 3 inside lights, my running lights, a water pump . fan , and charge my battery ! Thanks for any advice you can give!
All the best, Monte ( Das Cave )
Monte W is offline   Reply With Quote
Old 02-28-2018, 08:04 AM   #2
el wiring
about the best I have seen although a little overboard was work done by lisa the lisatania! you can do a search for her stuff.
my opinion use the kiss principle think it through draw it out and go! we have a 13f scamper we do not use el. it has it all but for us not needed I don't even know if it works.
bob
Old 02-28-2018, 09:08 AM   #3
In our Uhaul I installed a Progressive Dynamics 4045 power converter. It charges the battery, takes a few 110 breakers, and has a dozen 12 volt fuses. I have 12 volt lights and Fantastic Fan, plus a couple 110 outlets and lights.
Old 02-28-2018, 09:43 AM   #4
David Tilston's Avatar
There is no basic standard to apply. It all depends on where you intend to camp, how much power you require and how much you are willing to spend. I can tell you what I would do, but not what you want to do.
Given your modest power requirements, a 100 watt solar cell and a good battery are probably all you need. Though shore power is frequently available and very convenient, so maybe a converter/battery charger is a good idea too.
Each component is a balance of priorities. Cost, ease of use, durability, fashion sense..... it all depends on your priorities. Each one is a separate decision, with it's own issues to consider.
Battery: capacity, cost, maintenance, size, venting requirements
Solar cell: capacity, cost, rigid vs flexible, type of controller, fixed or portable
Converter: capacity, cost, number of AC and DC circuits, size
This is not a comprehensive list.
Old 02-28-2018, 09:53 AM   #5
dave my thoughts
dave my thoughts exactly on our 3 week boondocking trip to az we never ran our battery down but our 12v requrements not much no tv no inverters outverters needed.
I bet we didn't use 2 gal of propane either
bob
Old 02-28-2018, 10:53 AM   #6
Monte,
I'm also about to redo my electrical needs so I will be watching this post with interest.
Elvin
omache27 is offline   Reply With Quote
Old 02-28-2018, 10:58 AM   #7
CA
I tend to keep it simple. For starters, your trailer brake, turn, running, and marker lights are all 12 volt and are powered from your tow vehicle. So standard trailer light wiring works for that. Go LED if you can, they can (if built right) last longer and use less power.
For your internal lights and water pump (and a heater fan?) you will need a 12 volt deep cycle battery. A fuse or breaker panel so you can protect against shorts causing fires is important. Put a fuse on each circuit. One for the internal lights, one for the water pump, etc.
One of those circuits can be for an inverter so you can get 120 volts AC for household appliances. I don't normally bother with this, but it can be helpful to charge cell phones and small things like that. Don't plan on heating or cooking off an inverter. They are not that efficient in the first place, and your battery does not have that much power compared to cooking or heating needs. Plan on Propane for cooking and heating, or AC power from a full hook up camp site.
As far as solar panels go, they can charge that deep cycle battery. The more watts the better, but you can go overboard. You might want to do a "power budget" if you plan on boondocking for extended periods of time.
An alternative to solar cells, or a supplement, if you are away from AC power for extended periods of time, is a small generator. They make quiet ones now and the energy in a gallon of gas is more than in a large deep cycle battery.
Food for thought.
Tom
TomE11 is offline   Reply With Quote
Old 02-28-2018, 03:17 PM   #8
Trailer: Sprinter 'til I buy
Denver, CO
Although he is across the pond, and working on a Sprinter, this guy provides excellent planning and detail in a series.
Here are two you may want to watch:
Tom 72 is offline   Reply With Quote
Old 02-28-2018, 06:27 PM   #9
Monte W's Avatar
Thanks for the input! That's the power of this site! YOU KNOW someone out there knows the answer to you question!
Thanks
electrical
Electrical-can't get my electrical heater started. robertmarchiony Problem Solving | Owners Helping Owners 6 09-08-2017 06:11 AM
Need help-AC question Sharon Herman Modifications, Alterations and Updates 7 03-05-2017 05:15 PM
Newbie - need electrical systems help please! kristylwalker1 Electrical | Charging, Systems, Solar and Generators 11 09-08-2015 12:00 PM
Need Help - Solar Charging Question Huck Modifications, Alterations and Updates 5 04-16-2014 11:41 AM
Electrical Help/Question bobflhtc Electrical | Charging, Systems, Solar and Generators 10 06-04-2013 08:16 AM
