Need trailer brakes - Fiberglass RV
Old 02-25-2013, 02:17 PM   #1
PleinAirGal's Avatar
Trailer: 2010 Scamp with side bench, towing with 2010 6 cyl Ford Escape
Need trailer brakes
Hey guys, where is the best place to get trailer brakes installed. I don't want to get sold more than I need. I have a 6 cyl Ford escape with the factory tow package and am shopping for a 16 ft scamp or casita, in that order.
Would appreciate any leads...don't suppose any of you guys want to sell yours eh? Would prefer newer than 2001
Gabriele
PleinAirGal is offline   Reply With Quote
Old 02-25-2013, 02:23 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Most 16 foot trailers come with brakes. You will need a brake controller installed in your car. UHaul or any small auto repair shop can do this for you. You will pay a premium at an auto or RV dealer.
Thomas G. is online now   Reply With Quote
Old 02-25-2013, 02:37 PM   #3
It's my understanding that the UHAUL places will do the hitches but not the installation of the trailer brakes on the car. I think I will call my mechanic and get his input. I am aware that the trailer will already have brakes, and also that CA requires them. Thanks again Tom.
Old 02-25-2013, 02:47 PM   #4
Thomas G.'s Avatar
Not all UHaul places have the same restrictions, so it is worth checking out a few different ones. Wiring a brake controller and perhaps a 12 volt charging lead to a 7 pin connector is not a high skill job, so this can be done at many places like a trailer or hitch shop, an RV dealer, etc. The more overhead they have, the more they will charge you.
Old 02-25-2013, 02:48 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
You don't say what year your Escape is, but I think E-trailer has all the parts you need for a controller and installation along with related instructional videos. ( Link to page)
Worth checking out even if you pay someone else to do the job!
Francesca
Old 02-25-2013, 02:54 PM   #6
I ordered a class III hitch and it was made especially for my truck and it came with the required bolts. installed it myself with NO problems. The threads were taped into the truck frame and all I had 2 do is bolt up the hitch. It would be easier if you had someone help U hold it up.
The directions gave a Torque setting and you can get a torque wrench at a Pawn Shop or Harbor Freight for around $20.
Purchase the wrench and socket and save yourself some cash.
Go to Amazon.com and look for hitches.
Old 02-25-2013, 07:59 PM   #7
That sounds good. I shared the info with my husband. I am sure he and I can do it. We thought there was welding involved.
For those who want to know.. We have a 2010 ford escape with the factory tow package already installed. The receiver is the smaller, inch and quarter or half, I forget which.
What we need to do is change out the four point plug for the larger 7 standard plug.. I think. I called our mechanic and he said he does not do that.. So still checking around.
Was going to make a decision today and get it done but ended up in the studio painting today...
Thanks for your input all.
Gabriele
Old 02-25-2013, 08:12 PM   #8
If you don't want to do-it-yourself, an RV service center's probably your best bet for brake controller wiring.
FYI:
From the E-trailer link I posted earlier (post #5)
This is the installation kit that will convert your existing 4-way connector to a seven way, and allow for the installation of a brake controller.
Full video instructions at those pages...
Francesca
Old 02-25-2013, 08:17 PM   #9
That smaller receiver is a hint as to how much you can tow. Check your specifications carefully. I think you will find that a 16' Scamp or Casita might be a bit heavy for that hitch when loaded. Check the real world weights elsewhere on the site.
You can get a pre-wired 7 pin plug that the existing 4 pin will plug into and then you just add the brake, charging and, (if needed) the back-up light, wires.
Old 02-25-2013, 08:29 PM   #10
Some 1-1/4" receivers can tow up to 3500 pounds, and if it came from the factory that's probably what's installed on the O.P.'s Escape.
Francesca
Old 02-25-2013, 09:37 PM   #11
The ford escape with the factory tow package is rated 3500 lbs and 350 on the tongue. From my research, I should be good to go...I am just concerned about the smaller receiver. Some say I will be ok, and some say get a new hitch with the standard receiver.
I am sharing all these threads with my husband. I guess that makes me the secretary..although I will be making solo painting trips pulling the trailer on my own, so good to know this stuff.
Thanks guys.
Old 02-25-2013, 09:54 PM   #12
Thanks guys.
Don't be hornswoggled by all the folks that think a 2" hitch is "better" than the factory hitch that came on your rig.
It would do nothing for your rig to change it out, and you may in fact wind up with a setup inferior to the one designed by Ford specifically for your vehicle.
The main rationale folks seem to use when promoting 2" receivers for such small vehicles is that it's easier to find/fit accessories like bike/cargo racks. Even were this true, an adapter for that purpose is readily available for the hitch you have on the tug right now. Cost: about twenty bucks.
Francesca
Old 02-25-2013, 10:07 PM   #13
Brian B-P's Avatar
Why the concern? No Scamp 16' should get near the hitch rating. In Frederick's listing of actual trailer weights as they arrived at campsites, found in Trailer Weights in the Real World, the heaviest Scamp 16' weighs 2800 pounds. Only that heaviest one has a tongue weight over 320 pounds, and there's no need to be that high. A larger hitch might have greater capacity, but it won't give the Escape any more capacity, either total or tongue weight.
Although the 2" size is more common, there are no authoritative standards - just common practices - and the 1-1/4" size is the common practice for capacities up to 3500 pounds. Ball mounts and other accessories are more readily available in the 2" size, but there's no reason to think you won't find what you need in 1-1/4".
Old 02-25-2013, 10:13 PM   #14
841K9's Avatar
Trailer: 1976 Scamp 13'
Wisconsin
Francesca
Normally, I would agree. But the factory hitch on the Escape/Tribute/Mariner is pretty cheesy.
The aftermarket 2" receivers are much better built with heavy gauge tubing that will carry far more weight than the vehicle could move.
The factory will work, but My personal preference is to err on the side of caution.
Of course, I tow my Scamp with a Blazer swapped to 1 ton running gear, 10,000lb hitch and a beefed up frame.
841K9 is offline   Reply With Quote
brakes
Trailer brakes... Jan Adams Towing, Hitching, Axles and Running Gear 4 12-04-2011 03:02 PM
Trailer Brakes Alexandra B Problem Solving | Owners Helping Owners 4 07-20-2009 11:53 AM
Trailer Brakes Pete Dumbleton Towing, Hitching, Axles and Running Gear 0 04-25-2008 07:57 PM
Trailer Brakes Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 4 01-02-2008 01:36 AM
Trailer Brakes Pete Dumbleton Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
