Nest Caravans — Building a new FG trailer, step by step - Page 11 - Fiberglass RV
Old 10-04-2014, 04:20 PM   #141
carlkeigley's Avatar
NE Oklahoma
This is really a great thread Robert.
Thanks for letting us in to your real time world.
And a real time weight will be something other
than offered by most.
Great job.
Old 10-11-2014, 05:30 PM   #142
Robert Johans's Avatar
Trailer: Nest Caravans
Been busy trimming and cleaning up the first two shell parts — adding the necessary prep to facilitate assembly.
Also, testing our suspension parts for fit on the actual shell. The Flexride axle has been tacked to our custom mounting brackets, and bolts are temporarily positioned through the brackets and through the shell.
The Flexride, with adjustable torsion arms, was shipped with a pre-set 22° down angle. With no load on the mounted wheel/tire assembly, you can see we now have about 5" of space between the top of tire and wheel well. Of course, under the full load of an assembled trailer, the torsion arm will compress. When the time comes to dial-in our ride height, we will adjust the torsion arms accordingly.
BTW, special shout out to forum member, Brian BP, for his idea on improving the design of our mounting brackets. We're taking his advice. Thanks, Brian!
Old 10-11-2014, 05:44 PM   #143
More problems to solve... How to mount the spare tire.
The full size spare fits below the front nosecone storage box and between the towing delta frame arms. About a third of the spare crosses over into recess area built into the floor of the lower shell.
Frankly, we've not yet decided on the most elegant mounting solution. This shot shows a test — "roughing in" some metal to act as a custom bracket to keep the spare tucked up tight.
Hmmm, I'm scratching my head about this one...
Old 10-11-2014, 06:19 PM   #144
Ian G.'s Avatar
Is there any way to attach the spare under the rear of the trailer without compromising ground clearance?
When I designed the frame for my Boler I integrated bracing for the spare tire to mount under the rear but of course the Boler has the stepped frame which provides more clearance.
Old 10-11-2014, 08:05 PM   #145
cpaharley2008's Avatar
I had several Lance travel trailers with the tongue mount underneath, they attached a hinge on one side and a drop down system that attached on the other side with a slide in locking bolt, similar to those pins that hold the shoes on the tongue jacks bottoms.
Jim
Never in doubt, often wrong
Old 10-11-2014, 08:27 PM   #146
NE Oklahoma
Just a thought:
How about a swing arm to allow the spare
to swing out making it easy to get to?
If it doesn't clear the tongue there might
be a camber to lower/raise just enough to clear.
Old 10-17-2014, 09:25 PM   #147
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Hey Robert, how about a cable drop down set up for the spare tire like my Ranger uses ? A cable reel would be a bunch lighter than a metal assembly. BTW, this thread is great, thanks for the insite of the build.
Old 10-18-2014, 04:40 AM   #148
Raz
Raz's Avatar
Vermont
I keep my spare inside the trailer, under the permanent bed. There, it is out of the sun and the elements. When I needed it, it was easy to get to and very clean. Raz
Old 10-18-2014, 07:06 AM   #149
Timber Wolf's Avatar
North Florida
I like the rack you have but think you need something that tightens down and has some adjustment to it. Over the years new tires might be slightly different in diameter or thickness and the spare tire mount should be able to adjust accordingly. You are building a trailer that will outlast all of us, who knows what tires/rims will be used in that time. I am really looking forward to seeing the Nest "standing up".
Old 10-18-2014, 07:45 AM   #150
Well, if you're ever changing a tire on a dirt road in the rain, you want the spare to be as easily accessible as possible. Sitting on the back wall of my Casita, I like mine just fine. However, the demographic that Nest is attempting to appeal to is very concerned with style and I doubt they will be taking their trailers down many dirt roads.
Terry G is offline   Reply With Quote
Old 10-18-2014, 08:01 AM   #151
honda03842's Avatar
Name: Norm and Ginny
In about 100,000 miles, 7 years on the road with small trailers, we've only had the occasion to use our spare once. That time was while driving a new trailer home with too old tires.
In our history flats seem to be rare on the trailer. In my view something that needs to be accessed probably less than once a year doesn't need to be totally convenient.
If the Nest owners are especially well off and 'clean handed' they'll be calling their road service to change it anyway.
My first concern would be that mounting and unmounting the spare should not require unusual strength.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-18-2014, 09:21 AM   #152
I read somewhere that over ten per cent of new cars are being sold without a spare tire, not even a "donut," in a move to improve fuel efficiency stats.
My sister-in-law found out the hard way that her daughter's car didn't have one. With a blowout on the interstate, miles from a gas station, all she had in the trunk was a fix-a-leak kit--useless in her situation. Made changing the flat a two-trip process into town.
Sherry
Old 10-18-2014, 09:30 AM   #153
honda03842's Avatar
What brand of car comes without a spare?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-18-2014, 09:33 AM   #154
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
My 2010 RAV4 Sport. Came with run flat tires, no spare, no "bump" on the back door for adding one. Tires were very expensive, terrible ride & useless in snow. Switched to standard tires & carry a spare on the roof...
Introducing Nest Caravans Robert Johans Hi, I am.... 155 04-08-2016 06:23 AM
Questions for Start-up "Nest Caravans" War Eagle General Chat 4 12-17-2013 09:19 AM
