Nest Caravans — Building a new FG trailer, step by step - Page 18 - Fiberglass RV
Old 11-14-2014, 02:16 PM   #239
Originally Posted by Robert Johans View Post
Looking for more of your excellent feedback regarding design and options...
Question #1:
If forced to make a choice, where best to provide the most counter space: with the cooktop, or the sink?
Sink we use the sink every day and since no water heater we boil water on the cook top when we need hot water. My pet peeve with the Scamp there is no provision to keep water on top of the cabinet. Sink is close to the bed with no berm on the top cabinet to keep water from running down the side where the bed is. Minor issue but it shouldn,t be that way.
Question #2:
How much cooking is actually done inside your compact trailer? Almost none but when we do its usually with 120 volt using the new wave oven. No smell or mess in the trailer to clean up or worry about. Provide 120 volt close to the cabinet top. recess the cook top so with a flat cover you have much better counter space. we also use a cover over the sink.
Question #3:
Best 12VDC refrigerator? And by "best" I mean most efficient and nicest looking. (We've recently discovered the Vitrifrigo product line. Beautiful designs, but very expensive. Any one with experience with these refrigerators?)
No experience but if stuck with a 12 volt only refrigerator you best have a pre-wired complete plan for solar to accommodate it. I prefer to run with propane since most of our camping is with no hook-ups. This if properly planned for could be optional depending on customer purchase you just have to plan for it.
My Question #4 What are your plans for an awning over the back door? As I see it now you will be stuck using an easy-up to cover over the door. Too elegant a trailer for that. I picture a self contained roll-up much like window shades with a couple of side polls. Is a person needing to have 2 pop-ups one for the back and one for the side? Out here in the west we almost always put out our bag awning or easy-ups. Too much sun and most campgrounds don't have shade at every site.
Old 11-14-2014, 04:04 PM   #240
Trailer: 77 Scamp 13
Have had both 3 way (absorption) run primarily on propane and 12 volt compressor type before solar became common or affordable. The compressor type was pretty good, got cold faster, and switched automatically to using shore power if I was at a site that had it. But it did make a large demand on my battery bank so planning for how many amp hours of battery storage you need and solar panels to keep up should be a big part of your planning. Unless you over capacity your solar rig you might want to even think about a small generator otherwise you risk finding yourself with flat batteries and food getting warm or hauling a lot of solar capacity as insurance that won't happen.
Propane just worked and ran forever on a tank so for extended camping that would be my choice.
Old 11-14-2014, 04:11 PM   #241
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Roger, was the 12 volt ref. You used a "danfoss" style compressor?
Dave & paula
Old 11-20-2014, 09:44 PM   #242
Robert Johans's Avatar
Trailer: Nest Caravans
Thanks to all for playing at home! We will do what we can to comply with the general consensus:
1. Max space around the sink.
2. Pre-wire for an optional microwave.
3. Danfloss compressor 12vdc refrigerator. (No LP hassles, or ugly through-shell wall venting required!)
4. Pre-wire for solar power options.
5. Accommodate "light" cooking inside.
Thanks to "mtnwater" for the link to Isotherms.
Old 11-21-2014, 12:06 AM   #243
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Robert we should be thanking you for asking for our ideas/comments and you concidering and using some of them. Kind of makes me feel like we have had a small hand in this new design . As the moulded market is a pretty small market, long time moulded owners have a bunch of expirience with them and real world user time of what works and what really doesn't very well. No RV is going to be perfect for everyone but I think by asking for input from this market you're a big leg up with the Nest.
Old 11-21-2014, 03:13 AM   #244
Roger C H's Avatar
Smile Our experience
1. We have a Cramer stove/sink combo.
Name:   Cramer stove sink.jpg
Stove cover up.
In the morning, we have our toaster oven on the sink cover while heating water for tea on the far left burner.
Both covers up
When doing dishes, we heat water in our biggest pot over the front burner, pour part into the sink with detergent, wash the dishes in the sink and use the pot for rinsing.
2. We do breakfast, if the park doesn't provide coffee and bakery, which more are doing now.
We will heat soup, and make a meal occasionally.
3. I often thought a microwave would come in handy.
While looking for Cramer, I found this:
Compact Kitchen with Stove, Refrigerator, and Sink
Looks interesting
$823 where the Cramer is $709. But wonder if it could take RV duty
Old 11-21-2014, 07:22 AM   #245
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
We have that same one, put in by Escape, and love it. The sink is just big enough to put our largest plates or pots in, the stove works good, but I will it was only a two burner, and heated water faster. Getting the extra counter space with lids closed is bonus.
I have never heard it called a Cramer though. It was originally a SMEV stove/hob combo, and now mostly referred to as a Dometic, as Dometic bought out SMEV. Maybe it is made by them, but allowed to be resold under another name?
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 11-28-2014, 06:13 PM   #246
Finally got our first set of molded fiberglass wheel well flares delivered and mounted to the trailer. Very happy with the the fit and finish, as well as the aesthetics. They look very cool!
Also, concurrently hand-fitting the interior with fixture templates. Measurements and calculations from these templates will be "digitized" by the cabinet maker for the programming to run their CNC cutting machine.
Old 11-28-2014, 06:22 PM   #247
cpaharley2008's Avatar
I'm liking this more and more each day.......
Jim
Never in doubt, often wrong
Old 11-28-2014, 08:41 PM   #248
FTTRV's Avatar
Trailer: tp
Anything Robert does is a class act. I have seen two of Roberts trailer rebuilds. The trailers were better than the day they were made.
Old 11-28-2014, 10:46 PM   #249
carlkeigley's Avatar
NE Oklahoma
Those flares give a touch of elegance............
Old 11-29-2014, 08:01 AM   #250
One more suggestion Robert (as if you need any more) can the Fulton jack be turned 90 degrees, this can allow more room at the tongue for clearance of tailgates.
Jim
Old 11-29-2014, 11:32 AM   #251
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
WOW!
brian
2003 Casita SD 17'
http://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 11-29-2014, 02:10 PM   #252
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Attachment 78743
Stove cover up.
Both covers up
Looks interesting
Attachment 78744
Does this unit come in a "left handed" version? That is, can you get it with the sink on the left?
Froggie
Green Frog is offline   Reply With Quote
Introducing Nest Caravans Robert Johans Hi, I am.... 155 04-08-2016 06:23 AM
Questions for Start-up "Nest Caravans" War Eagle General Chat 4 12-17-2013 09:19 AM
