Nest Caravans — Building a new FG trailer, step by step - Page 23 - Fiberglass RV
Old 01-16-2015, 07:01 AM   #309
Green Frog's Avatar
Trailer: '83 Burro
Virginia
An eagle's nest is called an eyrie. This might be a good name for a trailer from a company using the name nest, but then again you might want to save it for your extra large super deluxe version later(??) Just thinking with my keyboard here...
Froggie
Green Frog is offline   Reply With Quote
Old 01-16-2015, 07:46 AM   #310
Spelling has gotten so bad these days thanks to spell-check and auto-correct I'm afraid half the world would think it was haunted!
Old 01-16-2015, 07:49 AM   #311
Trailer: small
State
It can also be spelled aerie. I think that has a better feel.
Mr. W. is offline   Reply With Quote
Old 01-16-2015, 08:43 AM   #312
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Also spelled ayrie, but I think aerie is the most common. The one I use anyway.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-18-2015, 11:09 AM   #313
Robert Johans's Avatar
Trailer: Nest Caravans
We are drilling down into the fine details of assembly, including wiring and plumbing. This 20-gallon fresh water storage tank from Trionic is marine quality, and features wall construction nearly 3/8" thick! Very robust. Custom fittings (including that for PEX) and "deck plate" access for inspection and cleanings as needed in the future.
Old 01-18-2015, 11:26 AM   #314
Our proprietary steel undercarriage components — towing deltas and axle brackets — returned from powder-coating looking great. Both bolt directly through the reinforced lower shell body. The torsion axle bolts through the axle brackets.
BTW, as you may know, the torsion axle tube is not powder-coated because the inner rubber cannot withstand the heat required for PC curing. Nevertheless, we still made the axle tube look pretty — primed and painted to match.
Old 01-18-2015, 11:28 AM   #315
cpaharley2008's Avatar
They look like aluminum, nice job.
Jim
Never in doubt, often wrong
Old 01-18-2015, 02:36 PM   #316
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Wow, that's one thick tank.
Old 01-18-2015, 05:16 PM   #317
Having the ability to stick a fist, hand or arm down into a freshwater tank to clean it is GREAT!
Old 01-18-2015, 06:28 PM   #318
carlkeigley's Avatar
NE Oklahoma
I agree!
Old 01-18-2015, 10:52 PM   #319
Roger C H's Avatar
Smile A possible headlight solution
When I had my 1991 Plymouth Laser with the pop-up headlights, I was worried about stone damage. What I did was cut two clear 2 liter pop bottles and they fit nicely over the headlights. I just used the center cylindrical section of the bottles.
Oops. I was answering Post 300 and didn't notice how the thread had progressed from there. My bad.
Old 01-19-2015, 03:52 PM   #320
MCDenny's Avatar
Trailer: Lil Snoozy
Regarding names, if Lil Snoozy can sell trailers then names surely don't matter.
MCDenny is offline   Reply With Quote
Old 01-19-2015, 05:40 PM   #321
charlsara's Avatar
Trailer: 2014 Lil Snoozy
I second that emotion. I own and love my LIL Snoozy. Our little trailers shouldn't taken to seriously 😁
charlsara is online now   Reply With Quote
Old 01-19-2015, 06:55 PM   #322
Lora's Avatar
Trailer: 89 Bigfoot 17G & 73 Compact II
Northern Neck, VA
How 'bout Nessie?
Lora is offline   Reply With Quote
Introducing Nest Caravans Robert Johans Hi, I am.... 155 04-08-2016 06:23 AM
Questions for Start-up "Nest Caravans" War Eagle General Chat 4 12-17-2013 09:19 AM
