New Blog Educate me on the 16 Foot Scamps - Page 3 - Fiberglass RV
Old 09-04-2013, 06:39 AM   #29
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Or in the case of some----like my Perris Pacer----it's fiberglassed in.
1988 Perris Pacer
2010 Honda Ridgeline
2013 Winnebago Minnie 2101FBS
Vickie B. is offline   Reply With Quote
Old 09-04-2013, 06:44 AM   #30
Pam Garlow's Avatar
Trailer: U-Haul 1985
Originally Posted by RV NUT CASE View Post
A sticky trailer ? I find that amusing . Never heard that one before. What ever you do dont show up at one of your tours with a sticky trailer. Those guys will run you out on the rails!
Na, we have no issue with people that want a different camping home. They're very welcome to join in. There are members in this group that own 'stickies' and are also admirers of fiberglass. Its all good.
Old 09-04-2013, 07:13 AM   #31
Vickie B.'s Avatar
Nebraska
And some of us crazies have BOTH kinds!!!!!!
1988 Perris Pacer
Old 09-04-2013, 10:39 AM   #32
Trailer: Nomad
Nevada
Originally Posted by Frederick L. Simson View Post
Since Carol is offline at the moment I'll answer. The furniture is either just screwed where it is attached to wood, and pop-riveted where it is attached to an adjoining piece of fiberglass.
Is the flooring ply wood screwed to the frame of the trailer or its it glassed in like a boat? Does the wood stay inside the trailer or do they put the top section down on the outer edges of the wood like a pancake? Thanks
RV NUT CASE is offline   Reply With Quote
Old 09-04-2013, 10:48 AM   #33
Trailer: Nomad
Nevada
Originally Posted by Bob Miller View Post
As the President might say, there is a Red Line that shouldn't be crossed, and if someone refered to our FGRV's as a "Plastic" trailer, that just might be that Red Line.
As almost all on here would agree, finding a used FGRV, more often than not, is a lot of work and, if one should fall into ones lap that can be had at a low price, the best of luck on that.
And if someone doesn't care if they get one or not, so be it, I will devote my time to helping those that are interested in making the usual and expected efforts to find what they want.
BTW: Many FGRV's, as were the last three sold at my abode, are sold by a "She".
Bob don't get your butt hurt if I call it a plastic trailer it was not ment to be offensive. If I jump on here and called sombody's trailer a POS that would be different. Its just an expression not be taken as offensive towards anybody's trailer. You guys love your trailers and there is quite a following here. So what I have gathered is these are very good trailers and if taken care of properly will last for years. Easy to tow with a light vehicle . You all have been very helpfull to me. I have only been on here since Saturday and to be quite honest I am very impressed with most of you. You have been very kind and respectfull and helpfull.
Old 09-04-2013, 10:54 AM   #34
Trailer: Nomad
Nevada
Whew I am glad of that I could see some Southern boys comming over the hill with the old Model A running off us Stickys with scatter guns!
Old 09-04-2013, 12:16 PM   #35
Depends on the brand. Some of the trailers have fiberglass floors & some have glassed in bottoms covering a wood floor above.. Scamp used wood only for the floors but its been covered in resin.... no signs of water on the under side of my 21 year old trailer which has traveled many many miles on wet roads The wood edges of the floor on mine are contained within the trailer and up about 5 or so inches form the lowest outside edge of the trailer.
Old 09-04-2013, 01:06 PM   #36
Trailer: Nomad
Nevada
Cool good to know. Can you emagine what is would of done if the factory had pancake the top section on top of the wood floor and left if exposed? What a mess that would of been.
So its my understand the belly of the trailer is one peice and totally inclosed? Is this correct?
Old 09-04-2013, 04:21 PM   #37
cpaharley2008's Avatar
Scamps belly is open, Casita's and some others are enclosed.
Jim
Never in doubt, often wrong
Old 09-04-2013, 04:50 PM   #38
Brian B-P's Avatar
Bolers came both ways - mine is open (the fiberglass shell does not extend under the floor). There don't seem to be problems from having plywood flooring exposed on the bottom - trouble comes from above, as mentioned earlier.
Old 09-04-2013, 06:05 PM   #39
David Tilston's Avatar
Trilliums have a fibreglass bottom, and the fibreglass furniture includes a fibreglass floor. There is a piece of plywood between them. If water pools on the floor, or in the bins, the wood may rot. I have no idea how this could be fixed. So it is a good thing that this is quite rare. I suspect that the best way to replace the plywood, that is sandwiched between the bottom of the trailer and the floor of the trailer, would be to cut a hole in the bottom of the trailer large enough to remove the plywood. Then fibreglass the cut out section back in.
Also, the furniture is neither riveted, or screwed to the inside of a Trillium. It is fibreglassed in.
I quite like the design of Trilliums. I now have four of them.
New Scamper, new Blog Garycamper Hi, I am.... 3 12-26-2011 12:47 PM
Blog from the Gathering Nancy in Oregon Oregon Gatherings 60 09-01-2008 05:59 AM
Gathering Blog Gina D. Oregon Gatherings 30 07-30-2007 05:25 PM
Check out the BLOG Mary F General Chat 5 07-22-2007 11:49 PM
