New Camping Unit Called a TAG - Fiberglass RV
Old 09-05-2008, 12:40 AM   #1
Adrian W's Avatar
Trailer: Lance 1985~'Casita de Campo' ~23' 4"~Dinette Slide Previously: Scamp 16 ft Side Dinette, Front Bath
New Mexico
Unhappy
Just saw this on another Forum: http://www.longdogent.com/
Another way to skin a cat for sure. Kind of a trailer.....and fiberglass as well. SUV type is molded.
Neat idea, but I'm keeping the Scamp.
DesertHawk- Las Cruces, NM USA
2015 Lance 1985 ~ Casita de Campo ~23' 4"
~Previously ~ 2005 16' Scamp
2009 White Ford F-150 Reg. Cab Longbed ARE Topper
Adrian W is offline   Reply With Quote
Old 09-05-2008, 05:08 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Cool
Old 09-05-2008, 07:50 AM   #3
Benita's Avatar
Trailer: Fiber Stream 16 ft 1982
Send a message via Yahoo to Benita
Benita is offline   Reply With Quote
Old 09-05-2008, 11:08 AM   #4
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
that rear end would sure swing out when cornering.
Scott S. is offline   Reply With Quote
Old 09-05-2008, 12:08 PM   #5
US
This has been going around the RV forums for some years now. Company was founded in 2005
Old 09-05-2008, 02:39 PM   #6
Gina D.'s Avatar
West Coast USA
uhm...
How do you get in the door?
Old 09-05-2008, 02:42 PM   #7
james kent's Avatar
Trailer: Boler 1984
When on a ferry or a toll road do they treat, cost wise, it as a dually or as a fith wheel trailer???
Old 09-05-2008, 03:39 PM   #8
Trailer: Trillium 4500 and 17 ft Eggcamper
If it has been around since 2005, I wonder why their web site has U-Tube info on the truck trailer, but nothing (that I can pull up) on the SUV model? Does anyone know what these trailers cost/weigh?
Vi Turner is offline   Reply With Quote
Old 09-05-2008, 05:53 PM   #9
hummm, looks like it bolts to the frame.... and they say it's detachable in 2-3 minutes??
Bolts to frame???
Old 09-05-2008, 07:18 PM   #10
Trailer: Escape
Interesting concept. The distance between the centerline of the two rear axles is worthy of consideration. During a turn, one or both sets of tires of a dual axle vehicle has to scrub or slide sideways along the ground. The distance between the centerline of the truck/TAG two rear axles is more like an aircraft bogey than a road vehicle. Tire scrubbing can put a high side load on the tire sidewalls and some aircraft allow for tire castering to reduce this load and the associated tire wear. If the TAG wheels castered then this problem could be reduced but that would add complexity and require bigger wheel wells.
The video on the TAG website shows low speed maneuvers on a wet surface, this would reduce the amount of tire sidewall deformation and tire scrub during these turns. It would be interesting to hear how much tire noise it makes during a tight turn on a high friction surface.
Driving up a ramped surface, like a steep driveway from a flat road, could result in the truck/TAG combination being supported by the front wheels of the truck and the rear TAG wheels, this could put an unusual load on the truck frame, I assume the TAG attach brackets are designed for this loading.
Hooking up the truck/TAG combination on a less than flat surface could be difficult. Getting the blades of the TAG to mount with the truck mounted lock pins may be tricky but perhaps only the left to right alignment is a concern. Maybe the truck pitch is not a significant concern and most RV camp sites are pretty flat anyway.
I hope they do well, it is a good idea.
Thane is offline   Reply With Quote
Anyone know what this trim might be called? Stacy Crotser Problem Solving | Owners Helping Owners 2 06-11-2009 03:18 PM
What is this window channel trim called? Kevin A Problem Solving | Owners Helping Owners 8 07-23-2007 12:26 PM
My kitchen is full of smoke, no one has called the fire dept. Lizbeth General Chat 4 09-02-2006 08:22 PM
What's it called and how do I.... Doug Mager Problem Solving | Owners Helping Owners 2 08-01-2006 07:59 PM
