New Fiberglass camper - Fiberglass RV
Old 03-12-2007, 10:25 PM   #1
Its more of a construction/utility type encloser that slides into a bed of a pickup, but alas add a flat utility trailer frame, and wala, a fiberglass camper with some exterior side storage.
Made by Horizon Fibermold, this particular model is the 6000SI. Rather tall and wide, its similar to a Compact design with the rear door. Web site is http://www.horizonfiberglass.com/index.html. Don't get me wrong, its a slide in design so there is limited interior space on the base. But slide-ins are usually outfitted pretty well. And yes, the sleep area of a slide-in is over the cab, but setup this camper like a Compact and it should work well. Could this be the next generation Compact? Add a little pop-up center section and have room with the smaller ligher 5'er version.
I have sent an email requesting more information for a bottom tub box (site states custom fab) to work with a flat bed layout rather than the slide-in or bolt on canopy styles. Look at the tech specs. This one weighs in at 650#s only. Add maybe 400#s for rolling trailer and you are still really light for the size.
5000SI model
6000SI model
If the regular slide-in campers are particularly well suited with shower/stall, cooking area, dining, then I can't see why this wouldn't work just as well sitting on it's own frame work. The trailer's tires can be cut out of the mold and a splash well added in, just like any other fiberglass campers.
Any thoughts? I've also asked for a cost sheet and a brouchure.
Mike jagular is offline   Reply With Quote
Old 03-12-2007, 10:50 PM   #2
Trailer: Fiber Stream
Talking
Any thoughts?
One of these in a Pick-up while towing a Scamp or Casita might make a nice family sized rig and add more sleeping capacity...
wanted 13-16 ft fiberglass camper in arizonia jerry hork Wanted: Molded Fiberglass Travel Trailers 1 01-18-2009 11:52 PM
Two Story Camper (Not Fiberglass) Adrian W General Chat 7 11-07-2008 11:11 AM
Inside Fiberglass Camper Getting Wet Behrouz Care and Feeding of Molded Fiberglass Trailers 6 07-29-2008 07:30 PM
Fiberglass camper wanted matt scott Wanted: Molded Fiberglass Travel Trailers 0 09-17-2007 09:59 AM
HI...seeking fiberglass camper in Il, IA, WI EJLydic Wanted: Molded Fiberglass Travel Trailers 0 04-27-2006 08:03 AM
