07-25-2015, 07:25 AM
Trailer: Bigfoot 25B21RB, 2004
Quebec
New Super-Light fiberglass-VR, Qc
To see, from Quebec province, 15 min from my home.
Helio | Roulottes ultra-légères novatrices, durables et écologiques
Have a good week-end,
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
07-25-2015, 07:42 AM
Trailer: Class A Motorhome
Hmmmm. My French is somewhat limited, but it looks like the base unit is, at 1200 lbs, about the same as the base weight of most eggs.
The "Mini-roulette" is mentioned at 500 lbs but there are no pics, I suspect that it is a teardrop, but 500 lbs is about the weight of an empty teardrop shell.
Interesting, but no cigar..... lol
07-25-2015, 08:25 AM
Looks like it is aluminum-framed with a fiberglass panel skin, so not molded.
Still, it is always good to see new small, lightweight designs come to market.
07-26-2015, 05:48 AM
Quebec
I use this translator,
Reverso | Traduction gratuite, Dictionnaire, Grammaire
It is not completed but that helps me...
Gilles
Bigfoot 25B21RB.
07-26-2015, 06:01 AM
Quebec
You can see photos here :
https://www.facebook.com/heliorv/pho...=photos_stream
And you can download the brochure, from the Web front page of heliovr.com , a small compartment appears at the top to the right, under the phone number, (Download our brochure).
It's a pdf file with details.
Have a good day,
Gilles
Bigfoot 25B21RB.
07-26-2015, 06:14 AM
Quebec
This week, I'll go to visit on the spot to obtain more details.
If you have questions which you would want that, You can make them to me follow on this blog...
Gilles
Bigfoot 25B21RB.
07-26-2015, 07:35 AM
Does not look like molded fiberglass to me.
07-26-2015, 07:43 AM
Quebec
Originally Posted by Ken C
Why?
If it's in one molded, aerodynamic, light, etc...
Gilles
Bigfoot 25B21RB.
07-26-2015, 08:01 AM
The square (aka will Leak) edges indicate that it's not molded fiberglass construction. And, it's not really any lighter than a Scamp.
Interesting, but not in the same family.
07-26-2015, 10:01 AM
Different strokes for different folks. These are the two things that immediately struck me. Whether bad or good, it depends on your opinion about such things.
07-26-2015, 10:36 AM
Quebec
I'll ask on these two things, Donna, when I'll go to see it, probably this week....
07-26-2015, 10:49 AM
Gilles, while you're there checking it out be sure to check out the wall frame construction. Is it wood or is it metal? Or, something else?
07-26-2015, 11:03 AM
Trailer: 93 Burro 17 ft
This thread raises an interesting question in my mind. (Of course, maybe it's interesting only in my mind... lol) Here goes...
Molded FG trailers are generally made in 2 pieces which are joined by fiberglassing across the seam; the added thickness built into the seam can make that section even stronger than the rest of the shell, and it becomes as if it were one continuous piece.
Ok, couldn't FG trailers be more economically built by molding several pieces and glassing them together? Let's say, for example, that one built a rectangular trailer out of flat panels. Flat panels for front, rear, both sides, top, and perhaps bottom. The panels would be molded with extra thickness at the edges, and the edges would be joined by fiberglassing across. Wouldn't those seams be just as water-resistant as the belly seam on a Scamp, or the vertical seam on a Burro? The advantage would lie in the ease and cost of interior build on a conventional assembly line, and possibly less complicated, less expensive molds.
The other thought I had was whether current non-molded (so-called "fiberglass sided") trailers could have their seams glassed over. But I doubt that would work, because the 'fiberglass' is really a very thin layer that is more gelcoat and probably very little fiber content. It would lack the strength to avoid forming cracks along the area where the seams were fiberglassed over, I think. Thus the water leak danger and subsequent delamination issues would still exist. Gilles, I think the Roulotte falls into this category: a stick built trailer with thin gelcoat laminated to a core of some other material (probably wood).
But if companies just molded some flat FG panels with thicker edges and then glassed them together into a box shape, it seems like a better trailer would result. I mean, better (more leak resistant) than the stickies they currently make. And more plentiful and affordable than our current selection of eggs.
07-26-2015, 11:59 AM
"Why?
If it's in one molded, aerodynamic,"
You can see a truck camper shell, made with a chopper gun on youtube. That's one example of molded fiberglass. What's in the cross section of your trailer example posted? Looks like the mass produced rv industry Fiberglass panel bonded with glue to Luan substrate famous for delamination? That type of RV is usually discussed on RV.net or irv2.com
Quebec
When I'll go visit, I'll look all these details, if it's possible and I shall transmit to you my vision.
Gilles
Bigfoot 25B21RB.
07-26-2015, 12:01 PM
Quebec
Yes Donna, thank You to guide me.
Gilles
Bigfoot 25B21RB.
