Newbie from Mississauga with ???? who knows what? - Page 2 - Fiberglass RV
Old 01-11-2011, 10:23 AM   #15
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
Originally Posted by Gerry View Post
I can tell you this it's not a Boler (too Square) Any radar will be quick to pick you up hmmm maybe that's why they painted it that color.
Where are all the ports for Water, Electric and exhaust for furnace?
Looks like you got some work ahead of you but just keep pluging along and you'll get it done but most important enjoy doing it.
Great to have you along.
Gerry
After looking at bunch of pix, I'm convinced that the shell came from the mould of Trillium Jubilee. Furnace exhaust is in the back, in the middle but that's not where it originally was. Electric is on the left side, by the wheel. All others are covered. There are some remains of wiring for electric brakes but the current axle / hubs have non brakes. It's OK. My TV is Buick Rainier and when I was towing the trailer in, I had to keep remanding myself that there is something attached to the hitch. Compared to a stick and siding trailer and a pop-up I towed more than once, this thing is light like a feather and (in my head) I'll be adding not much more weight to it than removing.
Despite the relatively square look, it also offered surprisingly little wind resistance. It should be even better once I mount the axle under the leaf springs.
Ever noticed that the stealth planes have plenty of flat surfaces? I should be perfectly safe from the radar!
Andrew GPSMapNut is offline   Reply With Quote
Old 01-11-2011, 10:47 AM   #16
Originally Posted by buddy hammond View Post
Don't change the colour!!! Check out KIJI adds in Kawartha lakes here in Lindsay There is lots of used trailer parts if you need any. Good luck with the project
Oh, the colour will be changed! In July 209 we've seen, in New Brunswick (close to Hopewell Rocks) a pink Boller or maybe Trillium pulled by a pink classic, we foaled in love with the idea of having a small FG trailer in the colour of our car. Now, we have a silver Rainier so, the trailer will be silver as well. Granted, the set will not be as pretty as what we have seen but, we hope for it to be an eye candy.
Old 01-11-2011, 04:57 PM   #17
CindyL's Avatar
Illinois
I win, I win!
I actually went through all the campers in the albums and could not find that little jog in the fiberglass over the tire that your trailer has (For that matter, I could not find the picture you see, Andrew, of the Trillium Jubilee.). So I checked, using my friend Google, and found this image. This trailer has that little element in the fiberglass exactly like your camo camper, Andrew.
At some point, I must have seen a Trillium like this variety.
And, I am glad you are painting it to match your car. Someday, I hope to have a VW pickup that matches my Uhaul.
CindyL
CindyL is offline   Reply With Quote
Old 01-11-2011, 05:11 PM   #18
CindyL's Avatar
Illinois
Darn it. The hubby pointed out that I was not the first one to call Trillium. I obviously missed your post, Emily R.
CindyL
Old 01-11-2011, 10:23 PM   #19
Rusty01's Avatar
Trailer: 84 Burro 13 ft
Mmmmm! For whatever reason I am not able to see a picture ?
Rusty01 is offline   Reply With Quote
Old 01-11-2011, 10:47 PM   #20
Emily R.'s Avatar
Trailer: 1975 Trillium 13 ft (Fluffer-Nugget)
CindyL
I'm willing to share the glory!
Emily R. is offline   Reply With Quote
Old 01-12-2011, 04:55 AM   #21
The picture is not part of FiberglassRVs uploads. It's been linked from an offsite host: http://www.fotocanada.ca/Ods%20and%2...r/PIC_0144.JPG
It appears the picture(s) have been taken down from that site? Or there's something wrong with that host...
Or this could be a hiccup from the software update. I see TechAmin is currently logged in... maybe it will get fixed soon.
Old 01-12-2011, 08:58 AM   #22
>>>snip>>>
>>>snip>>>.
Sorry, it was me - I was downsizing the files and they got renamed and than I ended up with doubles on my server and than I removed wrong doubles and than it appeared OK on my computer but I didn't refresh so it wasn't OK for everybody else and than... you get the picture... I mean that now they should be displaying OK
Normally, pix that I include in forum posts I host my own website www.FotoCanada.ca but it makes sense to load some here instead.
Old 01-12-2011, 09:02 AM   #23
I see the pictures now. Yes, if the pictures are uploaded here, they will be maintained in the archives no matter what happens to your site. We've seen plenty of hosting sites go away over the years and we lost the pictures.
Old 01-12-2011, 09:53 AM   #24
FotoCanada is not a hosting site - it's my personal hobby site so, I'm not too worried about it "going away". I tried to load couple pix but my CP does not have any link to create an album as described by FAQs Going to albums as such I can but when I try to log in, it refuses my username / pass for the forums so, maybe it's something different. Maybe because I'm new here. "Gallery" displays that it's down for maintenance so... maybe I figure it out after but, it may be way easier for me to have my images hosted on my own site.
Hmm, this may work?
In the pix below, there should be a cut up frame. Front section sitting upright. The old receiver still needs to come off. Rear section sitting upside down with the middle section in the background. That middle section was the "extension" that now will be removed. Lots of grinding and welding to come.
The axle still have the springs over but the U bolts are now loosened. Need to take springs completely off and clean the rust and paint the axle.
Bearings must've been recently replaced because the grease is not too bad and after adjusting the wheel is spinning smoothly and effortlessly but, whoever put the bearings in had little clue about doing it. There was over a turn of play on the nut and the cotter pin was not secured - the grease cup was holding it in place. After I removed the grease cup, it simply slid out of the crown nut In any case, I will be cleaning and re-packing these bearings. Who knows what grease they used
Old 01-12-2011, 01:12 PM   #25
Andrew, the gallery or albums you see linked from the home page are adminstered by the moderators/admins of FiberglassRV. They're not open for members uploads. The purpose of the albums is to show as nearly stock from the factory trailers as possible, rather than one highly modified by an owner, they are brand albums, not member albums. The hope is when someone is looking to buy, they won't be disappointed when seeing a bone stock trailer.
Old 01-12-2011, 01:51 PM   #26
Thanks for the explanation. Makes sense. It was the FAQ that got me confused. At Fiberglass RV - FAQ: User Profile Features
It states
"As a member, you can create Albums of images that are linked to your public profile. Albums can be created by visiting the User Control Panel, and clicking on the 'Pictures & Albums' link, and then clicking on 'Add Album'."
In any case, I found how to post a pix as an attachment so all is fine.
Old 01-12-2011, 02:11 PM   #27
Few more pix of what I'm up against...
Most, if not all of the crappy woodwork has to come out. That includes the rotten sections of the floor and glassed in section of the plywood that covers the raised portion of the ceiling. Can't do anything now - the shell is on flimsy supports waiting for the frame.
Old 01-12-2011, 04:48 PM   #28
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
Now thats a project!...keep the pics rolling in!
Bruce Thomas is offline   Reply With Quote
Newbie- needs help Rosemarie K. Care and Feeding of Molded Fiberglass Trailers 23 03-09-2012 08:20 PM
Hello I am newbie Terri Pensacola FL Hi, I am.... 18 04-25-2011 09:01 PM
Newbie from Mississauga ON. with ???? Andrew GPSMapNut Hi, I am.... 6 02-22-2011 12:00 PM
Newbie Eric & Tam General Chat 16 06-03-2007 11:51 AM
Newbie Lisa F General Chat 13 03-31-2006 09:56 AM
