Newbie from Mississauga with ???? who knows what? - Page 5 - Fiberglass RV
Old 07-03-2011, 09:20 PM   #57
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
The maiden voyage behind us and yes, there were lots of smiles. Seven months of hard labour but, (to us) it was worth it!
We would like to thank all of you on the forum. Special thanks to the ones who gave us direct advice and fed us ideas and special thanks to all who posted their ideas and experiences in all the treads all over the board. Reading these treads, including ones I never replied to) helped us a lot. It helped not just to deal with problems but, mostly to gave us strength to persevere despite many setbacks in the rebuilding process.
Thank You ALL!
I still have to make the closet doors and the dinette table cushions needs to be sown but the trailer is now officially usable!
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Andrew GPSMapNut is offline   Reply With Quote
Old 07-04-2011, 05:32 AM   #58
Andrew, thank YOU for allowing us to follow along in your rebuild. It's a thing of beauty! And, I hope you and your family have many miles of memories ahead of you.
Good job
Old 09-15-2011, 07:40 PM   #59
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
Nova Scotia
Originally Posted by Andrew GPSMapNut View Post
You may be on to something! Looking at the pix. of the Trillium Jubilee, the shell looks virtually identical. The major difference being the shape of the side windows - on mine, the windows (the marks of the original cut-outs) have rounded corners where on Jubilee the windows are rectangular. Also, on mine, there was only one window on the left side - it was at the back. The front, narrow window looks original where on Jubilee, I see it as a fair size rectangle. Than again, the shell and the raised portion of the roof seem a close match. Ah, mine has two roof vents. Not sure about the Jubilee.
I saw this listed as a 1980 Trillium. Looks like a Jubilee - but those windows!
Chris McVeigh is offline   Reply With Quote
Old 09-18-2011, 03:13 PM   #60
Wow! Where did you see it???? Any more pictures? It certainly looks like the window size that my shell had original cut-outs for yet; when I talked to the original owner of Trillium company (forgot his name) he was adamant that they never, ever made a Jubilee with such large windows!
Old 09-18-2011, 03:40 PM   #61
Nova Scotia
Listed in Alberta.
Looks like no front window? Yours was the only other one I've seen with those size windows - which could have been a mod. Still a bit of a mystery.
Old 09-18-2011, 06:22 PM   #62
The front window - looks like mine originally did not have one. Left over ribs are exactly like the ones in the photo you posted.
Another thing; a "proper" Jubilee used to have a tank under the raised floor in the rear centre. Front to back, inside there was a step and access to valve(s) was through a hinged cover at the front of that step. Mine had raised floor in the rear and a lowered molded section in the bottom, rear of the shell but there was no sign of any tank. There was a glassed in plywood cross support in there so, (I think) it never had a tank installed. Custom built? Somebody got a hold of unfinished shell when the company went under?
Old 09-18-2011, 06:26 PM   #63
AlbertaBound's Avatar
Trailer: 1976 Triple E Surfside
Surfside? Triple E?... ah nope, after a second look, too square to be a surf!
AlbertaBound!
AlbertaBound is offline   Reply With Quote
Newbie- needs help Rosemarie K. Care and Feeding of Molded Fiberglass Trailers 23 03-09-2012 09:20 PM
Hello I am newbie Terri Pensacola FL Hi, I am.... 18 04-25-2011 09:01 PM
Newbie from Mississauga ON. with ???? Andrew GPSMapNut Hi, I am.... 6 02-22-2011 01:00 PM
Newbie Eric & Tam General Chat 16 06-03-2007 11:51 AM
Newbie Lisa F General Chat 13 03-31-2006 10:56 AM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
