Newbie tow scare - Fiberglass RV
Click Here to Login
Old 09-04-2007, 11:27 PM   #1
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
What do you think happened? We were coming back from a favorite campground yesterday afternoon, I was traveling over an almost level, kind of bumpy road, at about 15 mph, maybe a little slower, when suddenly the truck and trailer each started bucking UP and DOWN (independently of each other it seemed) and the brakes briefly shrieked twice on their own (I'm quite sure I didn't hit them). Scared the living daylights out of me and I pulled over right away, checked the hitch, looked fine, checked all the tires and they looked fine. It drove fine the rest of the way down the mountain, still at a fairly slow pace, particularly over the bumpy patches. When we got home and went into the trailer it looked a wreck! The fridge had come open and dumped food and liquid all over the floor, a cabinet had come open and stuff spilled out all over. I'm not sure what happened. Could the three sets of wheels (two sets on the truck and one set on the Casita) have ended up in a bad combination of holes/bumps and the same time and caused it? That's all I could figure. Has anyone had this happen before? Thanks for the input!
Lisa M. is offline   Reply With Quote
Old 09-05-2007, 12:46 AM   #2
CharlynnT's Avatar
Trailer: Boler 17 ft
Welcome!
Re fridge door, cupboards coming open: no worries: good camping!
We admired the clever mod on the fridge door (tick-tock double-lock!) when we bought our 25 year old Boler.
We named one drawer The Flying Drawer, as it regularly spewed its contents on the floor during travel, then we installed a simple "privacy lock" (like on the inside of the stalls of a Girls bathroom in school) and it stayed shut.
We take our unit on some very rough roads, and so have installed more locks and straps as the Boler informs us. An old curly telephone cord keeps the top two cupboards togther, but with enough flex to not maim the wood.
Oh, and Sway Bars! Search on this site for info.
CharlynnT is offline   Reply With Quote
Old 09-05-2007, 08:04 AM   #3
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty Deluxe 17 ft / Honda Odyssey
Sounds like you found a road and speed that activated the natural haromic vibration of your towing rig, much like the famous Tacoma Narrows Bridge.
Patrick M. is offline   Reply With Quote
Old 09-05-2007, 08:07 AM   #4
Gina D.'s Avatar
Now you have the name for your trailer.. Galloping Girtie!
Old 09-05-2007, 09:55 AM   #5
Brian B-P's Avatar
Yes, I suspect that's it. While I have not had this problem with my trailer, I have seen tractor-trailer rigs (semi trucks) bucking very badly on some concrete highways: the concrete is in slabs of consistent size, and if they all tilt a bit, and the spacing of the slabs, the length of the truck, the natural frequency of the suspension, and the speed of travel all combine in an unfortunate way, it's a bad ride.
A friction type sway control device should do nothing for this situation, but a weight-distribution system (weight distributing hitch) will change the frequency that the combination likes to bounce at. One with lots of resistance to pitch motion (maybe a Reese Dual-Cam, or Equal-i-zer without lube on the bar ends) will also tend to resist the pitching motion. I would just slow down a bit on that particular section of road...
Old 09-05-2007, 10:09 AM   #6
I've had that bucking thing happen. I immediately applied the first, second, third, and forth rule of towing when something doesn't feel right.
RULe 1. Slow Down
RULE 2. Slow Down
RULE 3. Slow Down
RULE 4. See RULES 1 through 3 above.
Did I say slow down?
Old 09-05-2007, 10:52 AM   #7
CarolnJim's Avatar
Trailer: 2002 17 ft Casita Liberty Deluxe
We had the same experience last year while boondocking. We took the road which didn't look bad, but it was a washboard. No matter how slow we went the trailer and van just bucked ... no place to turn around. It was a miserable ride.
When we stopped and looked in the trailer it was a disaster. Even the stove burners were on the floor. Refrigerator was opened and everything spilled - the cupboards didn't open - we have good latches.. of course everything was all over cushions, bedding, it was a mess.
Just a few minutes and everything was close to being back in order. We have decided no more washboard roads we'll take the long way around.
CarolnJim is offline   Reply With Quote
Old 09-05-2007, 11:28 AM   #8
Patrick M.'s Avatar
We did a washboard road two years ago. NEVER, EVER AGAIN unless they're giving away free generators, trucks or tvs at the end of a short road!
Old 09-05-2007, 06:20 PM   #9
Pete Dumbleton's Avatar
Washboard roads can be really tricky, esp with a trailer, because at some speeds the vehicle(s) just float from top to top and can easily drift.
BTW, I have discovered, in my travels on '..the road less graveled..' that when going uphill, the uphill lane may be washboarded from tires digging in, but the downhill lane is usually in better shape. Of course, one must pay attention when in the downhill lane going uphill, esp near the top
Old 09-05-2007, 07:14 PM   #10
CindyL's Avatar
Trailer: 16 ft U-Haul VT
And watch washboard interstates. Interstate 90 near Rushford, MN and in western MN are awful. There was a road in Colorado (76?) when I was driving and Kevin was sleeping that was an awful washboard. Must have been like sleeping in a vibrating bed for those not driving. For me, it was rattling the teeth in my head!
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is online now   Reply With Quote
Old 09-05-2007, 10:45 PM   #11
Thanks to all of you for your responses. I guess with some roads it will happen. I will slow down, though I didn't think 15mph was that fast for that road, but it may have been. I don't think I"ll ever get the root beer out of the carpet! The other food didn't make quite as much of a mess.
Old 09-07-2007, 09:46 AM   #12
Kenny&Jackie's Avatar
Trailer: 13 ft Scamp
Sorry about the scare, I actually bounced the trailer right off my Tahoe on my first trip out on a horribly bumpy road. I'm pretty sure I didnt have it hooked up correctly. Thankfully I had been stopped at an intersection close to home and was just proceeding through it when it happened. A surprised passer-by helped me lift it back up and get it hitched properly.
As for your fridge problems, after dumping the contents of our fridge all over the floor on a recent trip I found this solution.
It's a child safe lock (for a fridge if I remember right) that just double sticky tapes to the fridge and has a little clip to keep closed. I just tuck the latch up and out of the way when we are not under way. It has worked well for us. I found it at our Lowes hardware store.
Safe travels. Jackie
Kenny&Jackie is offline   Reply With Quote
Old 09-07-2007, 10:07 AM   #13
Attachment 9970
I think one the ways to keep the fridge door closed is to stuff from banging into from inside. I use friction bars made to do just that. You can get them from Camping World (click here). I make sure everything is tight and can't move around and so far haven't had any problems with the door coming open.
Old 09-07-2007, 01:52 PM   #14
Both are great ideas, I'll check them out! Mostly I was worried about what I had done to cause the bucking, the mess was the least of the problem. But now when I look at the carpet and think how it's going to need to be steam cleaned or something (which makes me sick because my Casita was in A1 condition when I bought it) I realize a fridge door lock would be a good investment. What if we were on our way TO a campsite when it happened, instead of on our way home?
Old 09-10-2007, 08:06 PM   #15
CharlynnT's Avatar
Boondocking at Work Channel --
We were in Washboard Wonderland last weekend (worth the trip!) and lost our Poop Tube! The cap came off the bumper, the hose fell out. Rock n roll!
We actually found it on the way home, but someone had driven over it, breaking the important bits. We stuffed it in the big orange garbage bag in the back of the truck, which contained our own garbage as well as the garbage from our site's previous occupants and the garbage from the next-door site.
This is what I don't understand: people who travel long and then slow over wild roads to get to pristine wilderness with fabulous fishing -- and then leave plastic bags full of cans and wrappers and bear-bait. What the Hey?
Oh! And three sites down, they left a smoldering fire (not a huge deal on the wet coast) and four sites down, they left a BLAZING fire, not in a fire ring. These people also left behind lots of nice dry firewood, so we're good for all of next year. Waste not.
Newbie- needs help Rosemarie K. Care and Feeding of Molded Fiberglass Trailers 23 03-09-2012 09:20 PM
Our first trailer scare ted saxton General Chat 5 01-23-2008 10:10 AM
Newbie just saying hi John Fazio General Chat 8 01-13-2008 07:42 PM
Newbie Eric & Tam General Chat 16 06-03-2007 11:51 AM
Newbie Lisa F General Chat 13 03-31-2006 10:56 AM
