No wood, no rot... - Page 2 - Fiberglass RV
Old 07-09-2017, 01:59 PM   #15
Mike Magee's Avatar
Trailer: Li'l Hauley
Originally Posted by David B. View Post
Mike, you are wrong about Lil Snoozy not having drain holes. There are two under the bed and one under the sink. There may be others, but those are the 3 that are easily noticed from the inside.
Dave & Paual
Really?? Wow! I assumed, since my Hauley has no drains.... I wish it did....
How to prepare Tofu
Step 2: grill some meat
Old 07-09-2017, 07:06 PM   #16
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Mike, they would be easy to add. Just drill a 1/2 hole and glue a piece of plastic screen over it to keep the insects out. Voila you have factory drains.
Old 07-09-2017, 07:23 PM   #17
likeair2me's Avatar
Trailer: 1981 SCAMP 13
Sounds like the "factory" weep holes I had to install on my '68 Catalina's rear quarter panels. The seals were bad on the trunk lid so they would collect a couple of gallons on each side. No problems after the drains were installed.
It was a gas sucking beast. I didn't feel a bit bad drilling holes in it at the time.
likeair2me is offline   Reply With Quote
Old 07-09-2017, 09:53 PM   #18
Mike Magee's Avatar
That's it? No one-way valve or anything to keep out splashup when driving in rain?
How to prepare Tofu
Old 07-10-2017, 05:23 AM   #19
charlsara's Avatar
I have never noticed any water coming in. We have 22,000 miles on ours. The floor is 1/2 inch thick plus the screen so that should work unless the floor is underwater.
Old 07-10-2017, 06:30 AM   #20
Trailer: 1980Trillium 1300
Floor drain holes.
I bought my Trillium with rotten floor which is under fridge's bottom. It could be result of front window leak or fridge drain hose. Anyway, after replace new plywood with resin covered I replace fridge's drain hose going thru floor. Also drill 4 drain holes at 4 corners of Trillium. Each hole is glued with a hard plastic pipe about 2 inches going thru floor to prevent splash while driving in rain. No water condensed, no moisture ever since...
Old 07-10-2017, 03:37 PM   #21
US
If buying new, Parkliner, airstream Nest, and armadillotrialers.net no wood floor.
Old 07-21-2017, 10:00 AM   #22
US
I guess that makes the thread total 7 so far. Livin' Lite, Oliver, Happier Camper, Snoozy, Parkliner, airstream Nest, and armadillotrialers.net
Wood rot interior wall squatch-lover Problem Solving | Owners Helping Owners 5 04-19-2015 07:48 PM
Wood Rot in Scamp 13 Floor. Bill Nolen Problem Solving | Owners Helping Owners 22 04-12-2015 07:34 PM
Burro Floor Rot laura dawn Problem Solving | Owners Helping Owners 20 12-17-2005 01:38 PM
Sealand toilet removal / leaking / flakeboard rot Legacy Posts Problem Solving | Owners Helping Owners 6 06-09-2003 06:13 AM
Dry Rot! Legacy Posts Problem Solving | Owners Helping Owners 8 05-12-2003 07:23 PM
