Oliver Legacy Elite II - Twin Beds - Page 2 - Fiberglass RV
Old 11-14-2014, 08:25 PM   #15
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Floor level view of the nightstand drawer and the storage areas beneath our twin beds. The hatches that are open lead into the basement. A small electric heater will keep the interior nice and toasty all Winter. Leaving the basement access hatches open will keep all the plumbing warm.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 11-14-2014, 08:40 PM   #16
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
Steve,
Why do your twins look so different from all the pics I've seen, including Kathy's? I wasn't aware there were access doors in the side of the beds.
Kathy,
What color name are your countertops? There are a few that are very similar in the samples I received.
Follow my blog - http://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 11-14-2014, 08:47 PM   #17
Trailer: Oliver Elite II (had Casita SD, Bigfoot 21FB, & Lil Snoozy)
Kentucky
Hi Ron, the countertops are the lightest color (think the sample was painted white on the back). Our most difficult decision was the decals...everything else was easy.
Kentucky is offline   Reply With Quote
Old 11-15-2014, 11:36 AM   #18
Mississippi
Originally Posted by Ron Merritt View Post
Steve,
I had asked for storage space under our beds. Working with Steve Parsons (Oliver's resident fiberglass guru), we came up with a raised bed platform with access doors in the side that gives us some 15 additional cubic feet of storage space under each bed. They had to construct two new molds to make these. They have worked out really well for us.
At Walmart, I found some totes made by Sterilite that were a perfect fit. You can fit 4 of the large or 8 of the small ones (or various combinations of the two) under each bed.
Sterilite 10 Gallon Stacker Box- Mica, Set of 6 - Walmart.com
Sterilite 4 Gallon Stacker Box- Mica, Set of 6 - Walmart.com
Old 11-15-2014, 01:38 PM   #19
cpaharley2008's Avatar
Not sure I'd want those beds up that high, appears that you will be sleeping at window level, maybe a bit colder vs the insulated walls.
Jim
Never in doubt, often wrong
Old 11-16-2014, 01:47 PM   #20
trumpetguy's Avatar
Trailer: Airstream International CCD 28
We are in countdown mode to our December 1 delivery. I hope the Ollie really is a four season camper because it is cold in Hohenwald.
2007 Airstream International CCD 28
2016 Dodge Ram Sport 5.7 Hemi 4WD
trumpetguy is offline   Reply With Quote
Old 11-16-2014, 02:45 PM   #21
Rob Outlaw's Avatar
Trailer: Oliver Legacy Elite II, #70
Montana
Mid 40's, that ain't cold. Thats mild winter weather, the Oliver should be just fine.
Rob Outlaw is offline   Reply With Quote
Old 11-16-2014, 02:49 PM   #22
Trailer: Oliver Legacy Elite II Hull #63
Virginia
David
We picked up our trailer last Wed and stayed over at the Fall Hollow Campground and it was quite cold. We set the thermostat at 67 and were right comfortable.
We have no plans to do any "cold weather camping", we is too old for that crazyness. Afraid it will be a long winter waiting for spring. Maybe next winter we will head south for some of the winter.
Stan
Stan and Carol is offline   Reply With Quote
Old 11-16-2014, 03:05 PM   #23
trumpetguy's Avatar
Hey Outlaw,
They have had nigh time lows in the 20s. That'll freeze your pipes for sure. Here in N.Florida we will drop to 28 tomorrow with 20 mph wind. That is about 30 degrees below normal night temps here.
Our plan is to spend a few extra days in TN after the delivery, but I will head South if itis bitter cold.
Old 11-16-2014, 03:09 PM   #24
trumpetguy's Avatar
Stan. How long was the delivery walk through? I want to be set up at Fall Hollow before dark and we will need to fill the propane tanks, and provision at A local grocery.
Old 11-16-2014, 03:11 PM   #25
trumpetguy's Avatar
Stan. Post a photo of your Oliver at delivery if you are able. We all like to share the experience of a new trailer.
Old 11-17-2014, 06:43 AM   #26
Virginia
We spent most of the day going over things, which included going to lunch with Robert,Alicia, Sherry,and Paul up at the Junk Yard Dog. Had a really nice visit with Sherry and Paul. Went to Tractor Supply to get bottles filled and their system was down so went across town to the lumber yard and filled up there. There was still enough time to go out to Fall Hollow and get setup with Roberts help. Make sure you bring about 6 pieces of 2x6 lumber to put under the jacks.
Next morning Robert stopped by and since we decided to not stop in Missouri, he walked us through the black/gray water dumping and then we went to the plant and they winterized it for us. Thank full for that since we were coming home to weather in the teens and it was about 11pm when we got home.
Don't have any pics at pickup but took some here at home. Will have to figure out how to get them on the forum.
Stan
Old 11-17-2014, 07:04 AM   #27
trumpetguy's Avatar
Stan, Thank you for the reply. When you say bring some 2 x 6s I assume that is to keep the jacks from sinking into the ground when not on a concrete or gravel pad. We have always used the yellow lego style plastic blocks for that with our Casita. Do you feel that additional support is needed for the Oliver?
Old 11-17-2014, 07:05 AM   #28
South Carolina
I would assume that is what he's suggesting. I'd think there is plenty of throw on those jacks, as I've seen pics with the wheels off the ground.
On trailers I've had in the past, I've liked to use a 6x6 block on the front jack to give a bit more travel. Often these are only good for 24" total, which may not be quite enough if you have a full size truck or SUV.
oliver
2007 Oliver Legacy Elite - SOLAR $45000 Cherie Ve Ard Referrals: Molded Fiberglass Trailers 14 08-16-2013 04:37 PM
2007 Oliver Legacy Elite / Solar Powered (Reduced Price) Cherie Ve Ard Referrals: Molded Fiberglass Trailers 0 09-26-2012 12:45 PM
2008 Oliver Legacy Elite - For Sale - Rare Opportunity! Cherie Ve Ard Referrals: Molded Fiberglass Trailers 5 04-08-2012 08:46 PM
08' OLIVER LEGACY ELITE for Sale Larry Harmon Classified Archives 2 05-02-2010 06:09 PM
Oliver Legacy Elite BobB General Chat 0 03-14-2009 04:42 AM
