Opinions on Tent - Page 2 - Fiberglass RV
Old 05-22-2014, 10:04 PM   #15
Trailer: '07 Scamp 16' SD
Wisconsin
It was setup time that pushed me into spending the money on the clam. When you have a 1 yr old who doesn't want to stay in the truck anymore after being in it for hours, and a campsite full of mosquitoes. That 1 min setup time makes all the difference.
As to the structural stability of the top. I'm sure an engineer could set me straight, but I'm fairly sure the pressure differential actually pushes the top of the tent out in a good wind, not in. Those upper supports are beefy, and under a fair bit of tension.
As to the size, attached you'll find the collapsed unit in the bottom of our scamp, it is 6ft long collapsed. The length us essentially the radius of the top, as those spars do not collapse beyond the center pivot. Huge downside, but the setup time got me
Name:	ImageUploadedByFiberglass RV1400817798.468950.jpg
ID:	71391Click image for larger version
Name:	ImageUploadedByFiberglass RV1400817816.617234.jpg
ID:	71392Click image for larger version
Name:	ImageUploadedByFiberglass RV1400817834.984002.jpg
glennco is offline   Reply With Quote
Old 05-22-2014, 10:23 PM   #16
Mike Magee's Avatar
Trailer: Li'l Hauley
Paul, thanks. It was the sides, not the top, that I was mostly wondering about in wind. But I suppose the wind wouldn't have much to push on, unless the optional panels were attached.
6 feet, wow. I did notice that the Coleman is a bit less than 4.5' long when folded, and only 17 lbs shipping weight... vs 34 lbs listed weight for the Clam. There were some videos showing setup for the Coleman and it went up in about a minute and a half. They did not show the takedown, though. I do think the Clam's shape will be better if a picnic table is situated inside. Overall I think I would be happy with either one, but money is an object for us.
How to prepare Tofu
Step 2: grill some meat
Old 05-25-2014, 12:45 PM   #17
Trailer: ParkLiner
Virginia
Clam 1 Huck 0
I got the clam yesterday and decided to set it up today. Took it out of the bag, laid it out, found the top, and started popping the sides. After about 6 sides, I realized the tent was inside out. An hour and a half later, I still haven't been able to undo the sides and get it right side out.
It's like a Rubik's cube.
The problem is it collapses on itself and you lose track of where you are. Time to see if I can find a neighbor to help.
Huck is offline   Reply With Quote
Old 05-25-2014, 12:54 PM   #18
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
But.....
Originally Posted by glennco View Post
It was setup time that pushed me into spending the money on the clam. ...snip... That 1 min setup time makes all the difference.
Sorry- couldn't help myself!
Have you seen this video? It's setup demofor the 1660 you mentioned in the threadstarter.
Old 05-25-2014, 01:08 PM   #19
Trailer: ParkLiner
Virginia
But.....
They neglected to say the lettering should be up. I did exactly what they said to do but the lettering was down.
Old 05-25-2014, 03:57 PM   #20
pwdohio's Avatar
Trailer: Casita Spirit
Ohio
We have the Pah Ha Que and love it! Goes up fairly quick if you know what you are doing, so practice at hone before you leave. It held up to very high winds, when we had to close our awning.we generally put our awning our and then position the Pah Ha Que close enough to sort of iverlap awnings.
Barb and Joe (the humans), Kiva and Taz (the furfooted ones).
http://www.flickr.com/photos/1783186...7622359716549/
17' Spirit Deluxe, TV Chevy Traverse
pwdohio is offline   Reply With Quote
Old 05-25-2014, 05:09 PM   #21
Night Sailor's Avatar
Connecticut
Originally Posted by Mike Magee View Post
Hmm, I guess the Coleman is pretty darn easy, too! And the 10x10 is under $70 right now at Amazon. I ordered one just now. Can't beat the price. We're headed to Michigan to help care for my MIL, who just had heart surgery, and from what I hear the mosquitos are terrible up there this spring. Now we can spend some time sitting outdoors without getting eaten alive.
BTW, I did spot the Clam for $229 at LandMSupply.com . It appeals to me quite a bit, but not enough to spring for 3 times the price of the Coleman. Oh well.
I use a fan to keep the mosquitos away. They are weak fliers and a fan makes their nuisance blow away.
Old 05-27-2014, 09:07 AM   #22
Trailer: ParkLiner
Virginia
Tent 2
Huck 0
Had to remove the rods from 4 side panels to get the tent right side out again. Starting putting the rods back in and was abut half done when a gust of wind flipped the tent and most of the rods popped out as I hadn't screwed everything back down yet.
May try again today if the thunder storms hold off.
Old 05-27-2014, 07:36 PM   #23
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
Originally Posted by Huck View Post
Tent 2
Huck 0
Good Luck on getting it right and on thunder storms holding off.
Happy Camping
Lynn Musgrave is offline   Reply With Quote
Old 05-27-2014, 08:02 PM   #24
Trailer: ParkLiner
Virginia
Happy Camping
Thanks. It's Tent 2 Huck 1 today.
I got all but 1 rod back in place. The last rod had the head break off, so I repaired it. Will replace it tomorrow and see if it holds. If it does, should be smooth sailing.
Old 05-28-2014, 07:49 AM   #25
Trailer: ParkLiner
Virginia
Huck 3 Tent 2
I'm 6' and I can walk to the edge without my head rubbing on the roof. At the widest, it is about 10'. I'm going to leave it up and see how it handles a thunderstorm. I've got it tied to 2 fence posts in case the stakes pull out.
I ordered 3 side panels for keeping out sun/rain, auger tent stakes, kiwi water repellant, and a 9x12 floor mat.
Old 05-28-2014, 07:11 PM   #26
Trailer: Chalet
Very good Huck! Glad you got it up and are conducting a test,let us know how it turns out.
Happy Camping
Old 06-03-2014, 04:18 PM   #27
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Less than 2 minutes to shelter
This screen tent is really cool. We saw it set up at L&M Fleet in Bemidji. It looked stronger than I expected. Went back today to purchase one.
Warehouse person said they get 10 in at the beginning of the week and by Friday they are out.
It was slick to put up, really fast. Fred is 5'8. I am only 5'2". I would need a stool or hooked stick to bring the top back down if I had to pack it up.
will bring it to June Egg Harbor, WI gathering. Sure wish I had seen this before we purchased the Paha Que.
Now if we all chime in after using this thing in real conditions.....
Nancy
Nancy is offline   Reply With Quote
Old 06-06-2014, 09:42 PM   #28
Wisconsin
We've never had issues with ours in a storm. It comes with stakes for every corner, and guy out points in case things get really bad. Like I said earlier, really the only negative downside I've seen is the collapsed size
Screen Tent for 13ft Scamp jamessue Problem Solving | Owners Helping Owners 19 10-20-2013 09:46 AM
Electrical opinions wanted. Dave Mc Problem Solving | Owners Helping Owners 18 07-05-2009 08:34 PM
I'll not sleep in a tent while the grandkids sleep w/Grandma John Wells Problem Solving | Owners Helping Owners 12 05-13-2009 02:21 AM
Shower tent use in the Smokies Parker Buckley General Chat 13 05-12-2009 07:20 AM
Opinions on renting out Scamp and popup brendaross General Chat 11 12-31-2008 11:24 AM
