Ordering a 16' Scamp, what are the must have options? - Fiberglass RV
Old 04-10-2013, 10:29 PM   #1
chuyler1's Avatar
New Hampshire
Just curious what others like about their Scamps and if there are specific options or add-ons I should ask for. I already put a deposit down but construction won't start until the end of May so I have some time to decide.
chuyler1 is offline   Reply With Quote
Old 04-10-2013, 10:42 PM   #2
Have you ever been camping?
Do you imagine you'll be spending all or most of your camping time at RV resorts with full hookups or in the back woods boondocking?
Options from Scamp are many and the places you intend on using the Scamp determine the best options for you.
My guess is that from this group you'll get lots of things like Microwave Oven, Air Conditioner, bath with shower, etc.etc. Which is fine if you intend to spend the money for RV resorts.
If you intend to boondock get rid of all 120 volt stuff. Reduce all battery operated stuff as much as possible.
We boondock and spend an average of about $7.00 per night. Those that use RV Parks (resorts) spend $30.00 to $40.00 per night.
Your choice.
Old 04-10-2013, 11:19 PM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
We rarely camp in an RV park, and mostly are off the grid for free. We use solar and propane. We have NO 110 volt except for a battery charger, which we use when storing the Scamp in our garage. We do use the screen door, but rarely use the awning as wind is usually always a problem.
Have fun.
Old 04-11-2013, 04:38 AM   #4
honda03842's Avatar
Name: Norm and Ginny
Chris, WE're located in NH. If you'd like to see ours, drop me a PM and I'll send our phone number and address.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-11-2013, 05:13 AM   #5
If I was ordering new, I'd get all the overhead cabinets, a screen door, plugs everywhere inside! And one outside at the rear area to plug in stuff while outside. I WOULDN'T get curtains! (four holes through the shell for every window... there are better options without all those extra holes). Also, if you're ordering a trailer with a front window get the gravel guard.
Exciting time for you! Good luck in your decision
Old 04-11-2013, 08:15 AM   #6
Trailer: 2008 16 ft Scamp
We like the porch light and exterior outlet. Screen door if it's not standard.
I'd skip the hitch in the back for a bike rack, we had so much sway when we put bikes on it. The awning is ok, no strong feelings one way or the other.
Which layout did you get?
RachelW is offline   Reply With Quote
Old 04-11-2013, 08:37 AM   #7
Choices
If you are married it really doesn't matter in most cases what you want but what she wants . I have several items in my 16 ft Scamp that I could remove and live without but that ain't going to happen . Secondly We bought our Scamp used and it does not have a furnace . This Spring? we were thinking of selling the Scamp. We met with 2 prospective buyers and the first question we got was "Where's the furnace or Who would buy a Scamp without a furnace living in Minnesota" The sales went downhill from there. (NO AC is the same problem in the south) If you plan or think you may sell or upgrade in the future I would be leery of ordering a bare bones trailer.. If you ask Jim C at Scamp he will tell you what are the most popular options that are sold on new Scamps I like the bigger 4.0 cu ft refrigerator myself.
Old 04-11-2013, 09:12 AM   #8
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I think you should shoot for MSA or multi-situational adaptability. Sort of belt and suspenders, one from column Boondocks and one from column Creature Comfort. Most trailers are set up this way, for example, propane and batt for when you leave the electric grid behind, 120 juice for batt charging and those hearth side luxuries (AC) when you return. I don't know that "loaded/all accessory groups" is the way to go nor would I advocate the Spartan barebones approach. Only you can decide if you're a glamper or a desert rat and whether to take your bike. Your blank slate; your chalk.
jack
Old 04-11-2013, 09:41 AM   #9
Trailer: 2015 Escape
We bought our EggCamper as all electric. We have since had a furnace and propane cooktop installed. The all electric was ok in spring, summer, and fall but could not use the trailer this winter until we got several days south of Michigan. One of the issues was that no heat was available while on the road. All day without heat made our memory foam mattress like a block of concrete.
Old 04-11-2013, 11:05 AM   #10
Are you telling us you run your furnace while towing?
Old 04-11-2013, 11:19 AM   #11
Screen Door, 3 way Fridge, Fantastic Fan, Exterior Electrical outlet, awning, furnace and a hot water heater, awning, gravel guard for front window and all the overheads bins they offer for the layout you want.
Old 04-11-2013, 11:35 AM   #12
The fan is a must. We skipped the A/C and heater and instead bought a small space heater with a thermostat for about $20 on clearance. We have a hot water heater too and it's handy for doing dishes.
Old 04-11-2013, 11:39 AM   #13
chuyler1's Avatar
New Hampshire
Thanks everyone for all the responses. As for what we plan to do with it, it will be mixed use. I am an eagle scout that has taken a 15 year hiatus from camping. I used to tent camp once a month so I don't necessarily "need" everything, but Steve hit a very valid point. It's what SHE wants.
We like to hike and bike. We will use it for weekend outings to Northern New England, park it and use it as a base camp for day hikes. I enjoy XC mountain biking and my wife is starting to learn so we will be making trips to some of the resort areas too...and I hope in the future when her skills improve that we can travel the country and try new places to bike and hike. So there will be times that we are off the grid.
We also like auto racing and plan to use it for one of the NASCAR races at NHMS and maybe catch a race down south. I meet a group of friends every year at Limerock Park. We've always grabbed a hotel but I'd rather stay on site. I have family spread out over the east coast so we will likely make trips between NH and FL. There will be times (probably less often) that we have full hookups.
So as of right now the furnace and A/C are on the "yes" list. I'd rather have them and not use them than be stuck without. I see this as a long term investment so I don't want to end up wanting a new trailer because I didn't think I'd need A/C. We are ordering the floor plan with the front bathroom. I'm 6'3" so any extra space in that department will be helpful and I can barely stand in the side bathroom. Not sure about the microwave. We do eat a lot of frozen meals at home but if we didn't have one it would force us to actually cook...and that's not a bad thing. The larger fridge sounds like a good idea too and would come in handy on longer trips.
As for the awning, I was going to say yes. I see lots of photos where people are using them. There must be plenty of times where wind isn't an issue.
I was also going to say yes to the rear hitch. However that's not the first time this week I've read something about the bikes causing sway. I can put them in the bed of the truck instead. Anyone use the hitch for anything else, perhaps one of those platforms to store coolers and supplies? If not, I might as well scratch that option.
So anyway, if there was an option you said no to, then regretted it. I'd love to know! I don't mind a little extra weight if it will ensure we are happy with the TT in the long run.
Old 04-11-2013, 11:52 AM   #14
So as of right now the furnace and A/C are on the "yes" list. I'd rather have them and not use them than be stuck without. I see this as a long term investment so I don't want to end up wanting a new trailer because I didn't think I'd need A/C. .
Even though you are ordering A/C you should seriously consider getting the Fantastic Fan as well if flexibility is what you are after. A/C will drain a battery dead fast but a Fantastic Fan takes little power to run, so its great for those times when you dont have power to plug into.
ordering new hinges Ted Problem Solving | Owners Helping Owners 9 10-05-2012 05:16 AM
Help with Scamp 13 options oldchinahands Problem Solving | Owners Helping Owners 19 02-02-2012 08:12 AM
Ordering parts from Scamp adriemel83 Problem Solving | Owners Helping Owners 5 06-16-2011 05:04 AM
76 scamp rim options jimtesla General Chat 2 08-28-2009 08:34 PM
Ordering Pizza Frederick L. Simson Jokes, Stories & Tall Tales 2 12-15-2005 07:36 PM
