Over the weekend... - Page 2 - Fiberglass RV
Old 08-06-2015, 08:41 AM   #15
US
"I run LT truck tires, not trailer tires."
Like Ron, a great option many people choose.
Old 08-06-2015, 09:33 AM   #16
I know this has been rehashed many times but is there truly a reason we con not run good quality car or truck tires on our trailers . It seems that specific for trailer tires are not as good quality and seem to blow or disinagrate often and have lower speed ratings . I know of some people using car or truck tires with out issues. Some say they will bounce less but on a small trailer they seem to bounce a lot anyways . I think I'd rather spend more on a good longer lasting tire not trailer specific than replacing tires constantly after little use but being a manufacture of a trailer and renting out trailers of course we must go the proper and legal route .
Mikmay is offline   Reply With Quote
Old 08-06-2015, 10:02 AM   #17
US
rv.net has plenty of threads on that if interested.
Old 08-06-2015, 10:36 AM   #18
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
New tread holds more heat, high speed retains more heat, and of course hot pavement conducts more heat into the tire.
I wonder if the new, thicker tread also stresses the tire more due to centrifugal force.
Old 08-06-2015, 10:41 AM   #19
This might be a better source for up-to-date vehicle laws, the link will take you to towing speed limits but there is a whole list on the right of other concerns:
Trailer Speed Limits | AAA/CAA Digest of Motor Laws
Old 08-06-2015, 11:41 AM   #20
Roger C H's Avatar
Cool RPM at 80mph
80mphx5280ft/mile=422400fph
422400fph/60min/hr=7040fpm
7040fpm/60sec/min=117fps
117fpsx12in/ft=1404ips
24.1in (ST175/80R13dia*)x3.14159265(pi)=75.5in(circumference)
1404ips/75.5in=18.6rps
18.6rpsx60sec/min=1116rpm
80mph=1116rpm
*tires on my Trillium
BTW, sunny side or shady side also makes a difference in tire heat.
Speed limit sign in Arizona.
Old 08-06-2015, 01:12 PM   #21
Trailer: 77 Scamp 13
Road hazard that causes tire to slowly lose pressure can lead to a blow out pretty fast. Lower pressure causes tire to overheat which causes more tire squirm which creates more heat.
Something that gives you a flat causes you to pull over, on the other hand a nail that takes you 5# under pressure might not be felt by the driver but cause the tire to degrade rapidly to a blow out. Which I believe is generally the pressure blowing out the side bead rather than the tire itself popping. However at speed the tire just disintegrates from the total loss of pressure.
Old 08-06-2015, 02:02 PM   #22
Hmmmm... We still haven't gotten an Age Date report on the tire that failed or at least it's matching twin (?) on the other side.
Old 08-06-2015, 02:42 PM   #23
Paul O.'s Avatar
ex VT, now CO
80mph=1116rpm
Another troll here playing with numbers:
centrifugal acceleration on the rim of a rolling wheel is v^2 x R
(velocity of travel squared times radius of the wheel)
80 mph = 35.7 m/s
radius 12.05 in = .306 m
acceleration = 35.7^2 / .306 = 4178 m/s^2 = 425 g's
(I like metric units for this stuff.)
Every gram of that tire tread "weighs" 425 grams!
As Homer Simpson would say: Tires, is there anything they can't do?
Slowing down to 60 mph takes the forces down by a factor of .56 - now that feels much better.
Old 08-06-2015, 03:22 PM   #24
honda03842's Avatar
Name: Norm and Ginny
The very reason we have continuous pressure and temperature read out on our trailer tires. Though it has alarms for low/high pressure the read out is right in front of Ginny and she can see trends.
Once a tire on the CRV started to slowly lose pressure. We stopped and it was one of 'Roger's' nails. We put the spare on and we stopped we plugged it.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-06-2015, 03:45 PM   #25
MC1
MC1's Avatar
Originally Posted by Ron Merritt View Post
FWIW, I run LT truck tires, not trailer tires. Another reason I like the Oliver so much. It would probably tow fine at 90, but I'd never try it.
I'm in a similar boat Ron but using Extra Load P's. They work great and at 38lbs pressure provide a plush ride for our vintage 43 year old trailer.
I too believe we could tow at 90MPH but will leave that kind of fun to the pro's at the test track.
Old 08-06-2015, 05:26 PM   #26
Ohio
Speed
If I go over 60 its purely by accident. You kinda blow any time you save changing a tire.
cmartin748 is offline   Reply With Quote
Old 08-06-2015, 05:54 PM   #27
The reason for this is that heat build up is the primary enemy.....
A tire at full inflation runs cooler...
Then can anyone tell me why you would not run a trailer tire at full inflation? After all, no one is riding in the trailer and expecting a smoother ride.
Old 08-06-2015, 06:01 PM   #28
I'm tying to understand why, when the tire companies employ a R&D department to design a tire specifically for use on trailers, that anybody would decide they know better than these companies and use a light truck or passenger tire instead.
Visited our Scamp over the weekend Jeremy Witt General Chat 7 03-14-2006 07:24 PM
Canadas Camping Season Starts This Weekend Legacy Posts General Chat 7 05-18-2003 11:02 PM
Celebrating Veterans Day Weekend! Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 3 11-08-2002 02:37 PM
May 2003 long weekend Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 5 10-13-2002 12:51 PM
