ParkLiner & Ford Escape - Page 3 - Fiberglass RV
Old 09-15-2014, 05:13 AM   #29
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by frank_a View Post
Dave, I installed this system on a new car that is garaged day and night. No corrosion I can see. It has not towed the trailer at all as the P3 cannot find trailer brakes. All the Ford garage will do for free is make sure the factory 4 pin works. It does. Next is me opening my wallet for somebody else to figure this out, but who?!?
Frank
Bypass all the factory/computer stuff with the wiring from etrailer as I posted before. The 4 pin does nothing when you are adding brakes. I use the P 2 not the P 3, that may be part of the problem with plug and play working, just saying. When I was looking for a controller I didn't see any advantage using a P3 over a P2. There may be some reason why the P3 is better and a menber or two will chime in.
Old 09-15-2014, 05:40 AM   #30
Raz
Raz's Avatar
Vermont
To make a long story short, it still does not recognize the trailer brakes.
Frank
Hi Frank. I'm not sure what you mean by this statement as there is really only one connection between the controller and the trailer brakes. I assume you are saying the controller is not activating the brakes. If I had that problem here's what I would do:
-unplug the plug from the controller.
-there are 4 wires; white, black, red and blue.
-with a voltmeter measure the pins that go to the white and black wires. Is there 12 volts? Check the polarity, black is positive, white negative. That is, red probe on black and black probe on white you see +12.
-finally with red probe on red and black probe on white, step on the brake. You should see +12 volts.
-If all that works plug back in and go to the 7 pin at the back of the vehicle. Measure between the pin with the brake signal (blue) and ground. Now have a helper activate the manual control lever on the controller. You should see a volt although it may not be 12 volts.
Raz
Old 09-15-2014, 06:12 AM   #31
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Since I believe that you previously said everything worked until the Escape went through a car wash, I wonder if water got into the plug or wiring somewhere. If the Escape saw that as a dead short, I wonder if the onboard computer shut the whole trailer braking anti-sway system down?
Still .... If the 4-pin works .... .??? I would still call the toll free phone number for the etrailer.com folks. Just my $.02 worth. Good luck! :-)
rdickens is offline   Reply With Quote
Old 09-15-2014, 06:19 AM   #32
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Raz
We've done all that, and I kept notes. It still doesn't work. Maybe Dave is right, the P3 is not the way to go. If I wasn't so busy at work, I could play with it more, but even on my days off, life continually interferes!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 09-15-2014, 06:21 AM   #33
frank_a's Avatar
We took it to the Ford garage and they fixed the problem. It was the 4 pin. I honestly don't remember the Escape working with the brakes. Guess I'll have to go back and look at earlier posts.
The Escape is a nice car to drive, but like my nearly new trailer, has been driving me nuts with problems.
Thanks,
Frank
2012 ParkLiner #006
Old 09-15-2014, 07:16 AM   #34
Raz
Raz's Avatar
Vermont
Frank
Thanks,
Frank
All within two minutes. Wow
Old 09-22-2014, 11:08 AM   #35
I am confused as well - does it work or doesnt it???
Those of us who have been following your attempt to get it up and running want to know please Frank - If its fixed what was the issue? Was the factory 4 pin missing or had a faulty modular or something like that?
Old 09-22-2014, 11:40 AM   #36
frank_a's Avatar
It is unfigureoutable (new word I just made up - whadya think?). I don't know what else to say. Gonna have to hire somebody to assess it and tell me where I went wrong, and that will be interesting, as usually people come to me for help with stuff like this. Hours and hours of diagnosis, swapping parts, etc, have only made me more and more frustrated. That, plus endless check engine lights on this car have made me VERY unhappy we bought it.
Frank
2012 ParkLiner #006
Old 09-22-2014, 12:38 PM   #37
frank_a's Avatar
Thanks
2012 ParkLiner #006
Old 09-22-2014, 12:56 PM   #38
IllAnnoy
Thanks
Sorry, I was just in the process of deleting my post, upon rereading it and anticipating your reaction. Wish you lived close, I would be glad to help.
I know things like this can be frustrating.
Old 09-22-2014, 01:18 PM   #39
frank_a's Avatar
Thanks Floyd. I wished you lived close too. Somebody looking over my shoulder would be helpful.
This 7 pin kit was not difficult to install. It took some time to do a nice neat job, but could have been done quick if I wanted. It was certainly easier than wiring my hot rod! I've done all sorts of 12V wiring stuff over the decades (not just trailers, but lots of them too), and have a rolling tool box just for all my 12V stuff. In general I enjoy it.
I've checked continuity of wires (especially the brake wire), made sure I had a good ground, checked voltages at pins on the connectors behind the controller and the 7 pin, and just cannot figure it out.
Yes, eventually it will go to somebody else, but I wonder how they will do. I just about have to take it to an RV place that has something with a 7 pin to test it. My plug-in testers do not work with this Escape.
My F150 was so easy to hook up (plug & play). My wife is well aware of my interest and skills in 12V stuff, and agrees that we need to look at another vehicle at some point, and in the meantime, just keep using my fuelish F150.
I have other reasons for not liking the Escape at this point (check engine lights and not even 20,000 miles on it). This 7 pin thing though is very frustrating.
Frank
2012 ParkLiner #006
Old 09-22-2014, 09:27 PM   #40
Alabama
Frank, I think I mentioned this in a prior thread somewhere, but I had a 7-pin receptacle that drove me crazy - it would work, then didn't, then work, then didn't. I did all kinds of single wire-by-wire testing, and all tests were good. Finally took it to a trailer repair shop with high-dollar testers, and they discovered that I definitely problem - thankfully a low-dollar one to fix. The internal plastic housing of the receptacle was broken such that, some times, when you plugged the trailer plug into the receptacle, contacts were made properly = work. But sometimes, the trailer plug would simply push the electrical contact in the broken section deeper into the receptacle rather than make contact = not work. The trailer shop simply replaced the broken receptacle with a new one and the problem was solved. I hope your problem is as simple as that. Frustrating to find, but once found, easy (and relatively cheap) to fix.
Old 09-23-2014, 03:30 AM   #41
frank_a's Avatar
Thanks Dale, but I've already replaced the 7 pin connector and the plug that goes in the back of the controller with no change. Norm has suggested some tests via PM I need to get at when I can. It's always something!
Frank
2012 ParkLiner #006
Old 04-17-2015, 06:08 PM   #42
frank_a's Avatar
I'm looking over threads with my Escape problem to see if there's anything I missed. A few folks made specific comments last fall and darn if I can find them. Norm (of Norm & Ginny fame) suggested something, and someone else did too, and I can't find the threads.
Spring has sprung here in the NE. Tomorrow I hope to re-plumb the wastewater system that attaches to the tank. Once that is done, I'm hauling it 40 miles north to one of my best friends who owns a big repair shop and he is going to see if he can figure it out. I will keep you posted.
After reading through this old thread, I wonder about software in the car that might have been damages somehow in the car wash. But how do you figure that one out?
Thanks again for all the help, thoughts, encouragement and support. It IS appreciated!
Frank
2012 ParkLiner #006
escape, parkliner
Ford Escape or Mazda Tribute? Ron Stewart Towing, Hitching, Axles and Running Gear 11 06-23-2009 05:53 PM
Ford Escape or Suburu Outback? Paul Kaplan Towing, Hitching, Axles and Running Gear 9 07-09-2008 05:28 PM
Ford Escape as a Tow Vehicle Booker B. Towing, Hitching, Axles and Running Gear 9 05-04-2008 10:42 PM
