ParkLiner & Ford Escape - Page 4 - Fiberglass RV
Old 04-18-2015, 06:05 AM   #43
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Frank,
I did not cut into the Ford wiring at all.
I used an adapter (Hopkins Multi-tow) to plug into the Ford 4 - pin flat and adapt it to 7-pin round (I think Curt might make a similar adapter?).
I then ran a 12v hot wire to the battery for charging and 12v fridge operation.
I had a couple of trailer shops look into mounting a controller on the ODB2 port door (left side), but they weren't keen on the idea. I eventually went with the Tekonsha Prodigy RF brake controller mounted on the trailer tongue and the little hand-held controller that plugs into the cigarette lighter.
This combo didn't require cutting into the Ford wiring or choosing a sub-optimal in-cabin controller mounting location.
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
rdickens is offline   Reply With Quote
Old 04-18-2015, 12:08 PM   #44
frank_a's Avatar
Trailer: 2012 ParkLiner #006
There's a good chassis ground behind the "D" pillar in the back of the car. That is where the ground is now. Will test it later today or tomorrow. Right now doing wastewater plumbing inside the trailer after repairing a leak in the tank last fall. Just about done!
By the way, our 2013 Escape with only 28,000 miles on it developed a leak where the right front axle goes into the front differential. Had it fixed last Wednesday. At least it was covered by warranty, but really?
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 04-18-2015, 10:14 PM   #45
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
I have a 2014 Ford Escape 2.0L Ecoboost 4WD. It's a great tow vehicle.
But the computer in it is very particular with what it wants for trailer wiring. It does not like LED lights at all and will throw all kinds of error codes and erratic behavior. There is a TSB on this - but the fix is basically to rewire the car and to eliminate your proximity sensor on the BLIS system.
What happens is the computer, when a trailer is attached, wants to do all kinds of monitoring and diagnosis - but it can't really read anything and gets confused.
I found, quite by accident, that it will behave correctly if I run with the headlights on - turn off automatic mode. For some reason it clears up the issues.
I don't run with a brake controller. If you've wired that and a charging circuit separately to a 7 pin connector, and use the 4 pin wiring as-is. You should be fine, unless it is still conflicting with the trailer wiring thru the 4 pin. You might try my fix and see if it helps.
Good luck!
Follow my blog - http://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 04-18-2015, 10:20 PM   #46
IllAnnoy
Originally Posted by frank_a View Post
I'm getting to the point that I wish I had not bought either!
No doubt that both of these fine product manufacturers of would concur!
Old 04-19-2015, 06:45 AM   #47
rdickens's Avatar
Ron,
Thanks for the tip about the headlights! :-)
I bought my 2014 Escape right at the end of the model year (just as the 2015s were about to come out) and, luckily, I've not experienced any of these computer problems (knock on wood!).
But, you never know if/when that tip might come in handy.
Ray
Old 04-19-2015, 09:24 AM   #48
frank_a's Avatar
Hooked the Escape up. Everything works except it still does not see the brakes. This will get rectified one way or dee udder soon!
Frank
2012 ParkLiner #006
Old 04-19-2015, 09:28 PM   #49
honda03842's Avatar
Name: Norm and Ginny
frank
Have you measured the resistance of the brakes at the trailer's connector?
Have you activated the brakes manually using the trailer's connector?
I assume you've done these two things. If you have not this is the first step.
where do you live in ny?
The sim[lest test. Go to radioshack and buy a 10 ohm resistor with a 5 watt rating ot antthing like that.. Stick the resistor in the hole of the tow vehicles 7 pin connector in the brake line connextion. Connect the oyjer end of the resystor to ground using either the connectors gnd pin or the chassis. manually axctivate the prodigy's controller with it's lever (i'm typing in the dark sorry.
if this diesnt work contact me and i'll give you a next step.
norm
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-20-2015, 03:38 AM   #50
frank_a's Avatar
I don't think I have done either of those top 2 things Norm, but the trailer brakes do work fine with the F150. Wouldn't that mean they work fine, and it's the Escape with the problem?
We live just off exit 22 on I-87, about 15 miles south of Albany.
I think we still have a Radio Shack in Catskill (where I work). I'll see if I can find what you're suggesting I buy, and let you know.
Thanks for the help!
Frank
Originally Posted by honda03842 View Post
frank
norm
2012 ParkLiner #006
Old 04-20-2015, 04:20 AM   #51
honda03842's Avatar
Frank
I have a simpler test I will perform on our vehicle today that should help. Don't do anything until I try it. I'm just waiting for Ginny to wake up.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-20-2015, 04:28 AM   #52
frank_a's Avatar
Okay Norm, just let me know. I'm off to work anyways, and planned on hitting the Radio Shack in Catskill on my noon hour. I'll hold off till I hear from you.
Thanks!
Frank
2012 ParkLiner #006
Old 04-20-2015, 05:13 AM   #53
honda03842's Avatar
Frank,
I'm trying to isolate the problem. Since the trailer works with your truck. it indicates to me that something is miss wired.
The brake controller, when using the controller's lever and not using the Escape's brake, is an independent device. The only information it gets from the Escape is brake pedal depressed.
This test has two parts, first to check the wiring to the tow vehicle's connector. Using a resistor to simulate the brakes at the connector should test the wiring to the connector and the controller.
We can perform a similar test at the controller's connector that will test the controller.
I went out to the tow vehicle connector and put a clip lead between the connector's brake pin and chassis ground. On my connector this is between pin 1 and 2. This causes the brake controller to overload, but shows that the wiring is correct to the connector.
If you used a resistor between these two pins, using two clip leads it would simply show 'connected' on the controller.
This would prove the wiring is correct from the controller to the connector. If this is correct the problem is between the trailer and tow vehicle connectors
The controller should show 'connected to the brakes' regardless of the state of the Escape.
If the controller is not showing connected with the resistor between the brake's connector pin and chassis ground, it indicates miss-wiring.
You can also perform the same test at the controller. Simply insert one end of the resistor into the blue wire's pin at the back of the controller's connector and the other end of the resistor into the white wire's pin. (You can use a piece of a paper clip in each pin and a couple of clip leads if you like. A piece of a paper clip into each pin, a clip lead off each piece of paper clip and a resistor between the two clips. This eliminates all wiring to the connector.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-20-2015, 05:41 AM   #54
Raz
Raz's Avatar
Vermont
Perhaps he should just check his notes. See post 32 I doubt Radio Shack will have anything. Not many play electronics these days. But if you are looking to load the circuit, a 12 v. lamp will work. Raz
Old 04-20-2015, 05:46 AM   #55
Trailer: Escape 21 Nov.2016
brakes
Is this normal to have problems with brake wiring or is this a ford escape problem ? Would'nt a RV place handle this easily ?What does Ford say about their car ?
We have a Snoozy and have surge brakes but no elec connection but thinking about a bigger trailer down the road
jennykatz is offline   Reply With Quote
Old 04-20-2015, 05:59 AM   #56
honda03842's Avatar
Raz,
This should not be a Ford issue. The controller is really an independent device. It should see the presence of the trailer brakes, mine does even with the engine off. Yes an RV shop should be able to fix this problem.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
escape, parkliner
Ford Escape or Mazda Tribute? Ron Stewart Towing, Hitching, Axles and Running Gear 11 06-23-2009 05:53 PM
Ford Escape or Suburu Outback? Paul Kaplan Towing, Hitching, Axles and Running Gear 9 07-09-2008 05:28 PM
Ford Escape as a Tow Vehicle Booker B. Towing, Hitching, Axles and Running Gear 9 05-04-2008 10:42 PM
