plastic cabinents - Page 2 - Fiberglass RV
Old 10-10-2017, 07:24 AM   #21
Jon in AZ's Avatar
Following up on your earlier post Gordon, I found an old thread, and several people did mention using a Dremel, so I think I'll try it first. Thanks for the tip.
Now I just have to figure out the door for the new opening in the closet. Scamp no longer sells the oak-look panels, so I have to decide whether to look for a cast-off, make one and and paint all the doors to match, or cannibalize the porta-potty door and install the pull-out drawer I have always wanted there...
Old 10-10-2017, 09:24 AM   #22
David B.'s Avatar
Google Oscilliating Multi-tool, which I believe was originally made by Fein Tools, but is now made by multiple tool makers....even Harbor Freight. This works great, especially when used in conjunction with a vacuum cleaner to collect the dust as it is being produced.
Dave & Paula
Old 10-10-2017, 07:21 PM   #23
Missouri
cutting my hole
I have a good jigsaw I can control it so that will be what I use! I have had dremels and such play hopscotch with me on stuff before! I have already used it for a fiberglass cutting project!
bob
Old 10-11-2017, 06:04 AM   #24
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Missouri
plastic cabinents
Just FYI -
If you use a jigsaw and you are cutting from the gelcoat side, there is a somewhat special blade that you might look for and use. My ACE Hardware guy recommended one to me.
Looking at the tooth orientation, you will notice that blade cuts on the down-stroke instead of the up-stroke that some wood-cutting jigsaw blades use. I'm not sure about the tooth orientation on metal-cutting blades.
I was told that any blade that cuts on the up-stroke can potentially lift and chip out larger areas of gelcoat on either side of the cut line.
Just possible food for thought. As always, YMMV. [emoji6]
Good luck! [emoji846]
Ray
rdickens is offline   Reply With Quote
Old 10-11-2017, 07:39 AM   #25
Missouri
ray thanks for the good info. I will look for those!
now what I can buy for the inside trimwork I am not paying scamp 20.00 in ups to get theirs!
bob
Old 10-11-2017, 07:45 AM   #26
Missouri
plastic cabinents
One thing I did find while installing my new countertop was the cabinent was 1in out of square. really no big surprise but was surprised!
bob
Old 10-11-2017, 08:49 AM   #27
Randy P.'s Avatar
Trailer: Casita Spirit Deluxe
Minnesota
When I installed flush mounted speakers in the upper rear cabinet of my Casita I used a high speed cutter bit on the dremel to cut the fiberglass. I used something similar to the #194 and it worked well but if I were buying the bit new I would consider the #115 as well.
Randy P. is offline   Reply With Quote
Old 10-11-2017, 08:53 AM   #28
Missouri
what i use
I use a large hole saw on my battery drill
kiss
bob
Bigfoot 17B upper cabinents removal Mountain Moma Problem Solving | Owners Helping Owners 1 02-14-2017 09:11 AM
Trillium Plastic Seams Brenda Novakovski Classified Archives 2 02-19-2006 08:47 AM
Plastic Clothespin Reminders Legacy Posts Problem Solving | Owners Helping Owners 19 08-21-2003 03:47 PM
Cleaning yellowed plastic (Casita) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 5 08-15-2003 10:17 AM
Reusing plastic bottles Legacy Posts General Chat 14 05-26-2003 09:14 PM
