Porch Light - Fiberglass RV
View Poll Results: Porch Light
NO 10 11.36%
Yes 65 73.86%
Going to add one. 12 13.64%
I have more than one. 1 1.14%
Voters: 88. You may not vote on this poll
Old 08-04-2008, 11:29 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Porch light with a switch.
I plan on having a switch, on the inside also.
Just curious how many people have a porch light.
Old 08-04-2008, 12:34 PM   #2
I also have my external porch light connected to the switch in the interior light.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 08-04-2008, 02:27 PM   #3
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I added one because it was on sale at Farm and fleet for about 6 bucks.
So far we have used it to find the door lock at night ( the best thing ever) and find something that we dropped in the screen room. ( we out the screen room right up to the Burro.
I don't leave it on even tho I have the yellow lens on. Only camped twice since installing so maybe more uses will come up.
Old 08-04-2008, 05:47 PM   #4
I installed a remote control on mine.
12 Volt Remote
It took all of 10 minutes. I pulled back the rat fur in the curbside closet of the Scamp and used doublestick tape to attach the receiver to the fiberglass. I then drilled a hole through the shell to run the wiring and the antenna.
The red and white wires are from the unit. I attached these on either side of the existing switch. The thin blue wire is the antenna. I also ran this through the hole and wrapped it around the inside of the light housing. There is a third white wire that I attached to the ground on the inside using a crimp connection. The range is about 40-50 feet. It can still be turned on and off from the light itself or via remote.
With this set-up, one can use the remote or the hardwired switch. The problem is that if the switch is on, the light can not be turned off with the remote and vice-versa.
If I get fancy one day, I may open the receiver and see if I can wire in a pushbutton switch so that the unit can be turned on and off from either source.
This actually came in handy coming back to the trailer in the dark. We were with a group of people who enjoy playing musical chairs (and move the cooler) so I didn't know where anything was. I could turn on the light before I tripped over anything.
Todd Sleeman is offline   Reply With Quote
Old 08-04-2008, 08:07 PM   #5
Trailer: Fiber Stream
Talking
The Fiber Stream did not have a porch light when I bought it, so I added one. Mine is switched on the inside ONLY.
I also placed it between the upper fridge vent and the window, away from the door, but centered under the awning.
The night time bugs are away from the door when I go in and out.
Old 08-05-2008, 01:55 AM   #6
Joseph Domingos's Avatar
Trailer: Hunter Industries
Send a message via AIM to Joseph Domingos Send a message via Yahoo to Joseph Domingos
My Compact II did not have a porch light when I got it, but I recently added one as I had wanted one for some time. Sadly I have yet to USE the trailer to see how I like or do not like the porchlight. It wasn't very tough to add, once I got brave enough to pull the inner fiberglass panel away from the wall some. I actually also did some other electrical work at the same time, adding a 12 volt plug in the sink area of the kitchen, and a lighted switch for the water pump. What can I say, I kind of got a wild hair to do some things...hehe
Joe
Joseph Domingos is offline   Reply With Quote
Old 08-05-2008, 07:44 AM   #7
Lizbeth's Avatar
Yep, porch light switched only on the inside. It's hardly ever used. Last week I used it to check out what the dog was fussing about, a raccoon.
Old 08-05-2008, 07:51 AM   #8
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Todd Sleeman
Thanks for the tip.
Old 08-05-2008, 09:23 AM   #9
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
When we first got our Trillium, there was NO porch light in it. It was installed by Reace (with Tammy supervising, I'd guess) at Escape Trailers while the trailer was out there for other retro-fits. Its a 12 volt unit with built in (outside) switch. After using this deevice for about a week, I got tired of it being 'usual', so I pulled out the bulb and wired in about 9 12 volt blinking led mini lights. (car people just can't leave ANY THING alone, LOL) Now in the dark (and from a short distance away) it almost looks like F I R E!!!! Still bright enough to do the trick of the BORING old porch light!!
Old 08-05-2008, 10:21 AM   #10
This is something like the adapter I plug the 7-pin Bargman umbilical into that routes 12 Vdc to the running lights. Hadn't really thought of adding a blinker to the circuit to make everything flash!
Can't miss our Casita when returning after dark from a night at the Casino.
Old 08-05-2008, 12:15 PM   #11
Gina D.'s Avatar
West Coast USA
I have one.
I rarely use it.
It gets turned on for a few seconds when light is needed for keys, etc.. but it's never left on. (On purpose anyway)
I turn it on when backing in the dark. Thats a good use for it. Mine is white.
Old 08-05-2008, 12:19 PM   #12
Adrian W's Avatar
Trailer: Lance 1985~'Casita de Campo' ~23' 4"~Dinette Slide Previously: Scamp 16 ft Side Dinette, Front Bath
New Mexico
We have a white one, rarely use it.
DesertHawk- Las Cruces, NM USA
2015 Lance 1985 ~ Casita de Campo ~23' 4"
~Previously ~ 2005 16' Scamp
2009 White Ford F-150 Reg. Cab Longbed ARE Topper
Adrian W is offline   Reply With Quote
Old 08-05-2008, 07:26 PM   #13
Paula Bindrich's Avatar
Trailer: 1987 13 ft Casita
Have one.
Rarely use it.
When giving tours I flip it on. That's about it.
Paula
Paula Bindrich is offline   Reply With Quote
Old 08-06-2008, 06:46 PM   #14
Trailer: 2008 16 ft Scamp
we have one, it came on our '08 scamp
RachelW is offline   Reply With Quote
lighting, lights, porch light
3-Way Porch Light peterh Modifications, Alterations and Updates 23 01-21-2011 04:43 PM
What do you think of this as a porch light? Donna D. Care and Feeding of Molded Fiberglass Trailers 18 09-21-2010 07:50 PM
Solar porch light Mike Taylor Modifications, Alterations and Updates 21 08-28-2010 12:48 AM
Added a Porch Light Jayson Wall Modifications, Alterations and Updates 6 07-11-2007 07:42 AM
Porch Light Legacy Posts Problem Solving | Owners Helping Owners 8 06-10-2003 10:21 AM
