Propane Frig - Fiberglass RV
Old 04-22-2008, 04:00 PM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I have a 13' Scamp.With a Domefic 211 Frig. How many HRS would a Full 20 lb propane tank last, if I run the frig on Max.
Old 04-22-2008, 05:32 PM   #2
Trailer: Quantum-5 5th Wheel 1980
Alright Kevin, I give. How long?
Ron Wrighton is offline   Reply With Quote
Old 04-22-2008, 05:36 PM   #3
Greg A's Avatar
Trailer: 2015 Escape 19
I pick April 28 at 3pm.
Seriously, would love to know this if anyone has this info. I'm on the original 20lb tank over a year, but only about 8 days boondocking where the fridge was run on propane.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 04-22-2008, 06:41 PM   #4
Trailer: Trillium 5500 1980
Don't adjust it to maximum and leave it like that as everything inside the fridge will be rock frozen in about 36 hours or so! Adjust it according to the inside (trailer) and outside temperature. It also depends on how often you will open the door and how rapidly you close it.
As an average if no propane is used for anything else and the adjustment is in the mid range I would say at least 3-4 weeks.
Normand Choiniere is offline   Reply With Quote
Old 04-23-2008, 06:19 AM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Heres what I found out. A 20 lb propane tank has enough energy for 374000 BTU's,
a propane Frig uses 625 BTU's. (Domefic 211)
TOTAL HRS 598 or about 25 Days at max setting.
I agree with Normand Choiniere-NEVER SET AT MAX SETTING. Everything will be frozen solid. You should get well over 30 Days at 3/4 setting.
Old 04-29-2008, 09:37 PM   #6
Greg A's Avatar
I just went and filled my propane tank. We've run the fridge a total of about 9 days and it only was down 1.3 gal.
So I would figure that it would make it about 25-30 days at that rate. Fridge was run on mid settings and some was last summer in the heat.
Owner:
propane
Frig venting sugermc Problem Solving | Owners Helping Owners 3 07-18-2010 05:26 AM
Which Frig Should I Install? Bud Kennedy Care and Feeding of Molded Fiberglass Trailers 4 01-22-2010 03:38 AM
3-way Frig Settings? RSchleder Problem Solving | Owners Helping Owners 7 11-05-2009 04:30 AM
Ice Box to Real Frig - any help?? Eve V. Problem Solving | Owners Helping Owners 6 10-05-2008 07:46 PM
Frig. Temp. Kevin K Problem Solving | Owners Helping Owners 5 08-22-2008 05:08 PM
