Question about the Scamp flooring - Fiberglass RV
Old 01-18-2017, 10:30 AM   #1
TWelch's Avatar
Trailer: 2011 Egg Camper #101, the Abel Egg, pulled by 2016 Honda Odyssey
Alabama
This is an information-seeking question, only. I do not want to start an argument and I am not trying to denigrate Scamp. I am trying to make a well-informed decision regarding which fiberglass travel trailer to pursue.
My question:
How many of you Scamp owners have had to replace/renovate the flooring in your Scamp? I am wondering what repercussions the wood content in the flooring may have. . . .
I know the Casita does not have any wood in the flooring, but I prefer the wider aisle in the Scamp. . .
I love the Lil Snoozy but I am looking at the price difference. . . and wondering if I will ever find a used one. . .
Thanks in advance for your input. I value the knowledge found in this forum.
Tonie and Abel
(I tried the search option, but couldn't get it to give me what I wanted.)
TWelch is offline   Reply With Quote
Old 01-18-2017, 10:56 AM   #2
Both Scamp and Casita have a wood subfloor. Scamp protects the underside with a coating of fiberglass resin. Casita protects the bottom with a fiberglass underbelly. It is thin and non-structural. From a floor rot standpoint, there is little advantage either way, since most rot is caused by water infiltration from above. Floor rot is not uncommon on older trailers of either type.
A few manufacturers completely encase the structural wood in fiberglass above and below- Trillium and Escape (I think). That approach does seem to reduce the likelihood of floor rot, but it can still happen- cracks or screw holes in the top of the fiberglass can admit water- and when it does, it is a more complex repair.
Right now the only manufacturers that have completely eliminated wood in the floor (substituting structural honeycomb fiberglass) are Oliver, Lil Snoozy, and Happier Camper.
Old 01-18-2017, 11:02 AM   #3
TWelch's Avatar
Alabama
Wood in subflooring
Thanks, Jon. I had no idea there was wood in the Casita flooring as well.
Tonie
Old 01-18-2017, 11:08 AM   #4
None
One more point, meant to negate concerns over the Scamp floor, not denigrate the Casita, is that since water damage occurs in both, having the underside of the Scamp floor visible and accessible for evaluation, can be an asset.
Plus, if the time comes (as it has for me) to repair a small section of floor, it seems the accessibility of the Scamp is again an advantage.
LyleB is offline   Reply With Quote
Old 01-18-2017, 11:16 AM   #5
Escape deals with leaks this way:
In the event of a water leak or condensation build-up, there are areas in the bottom shell designed to channel water through the drain holes to the outside.
Old 01-18-2017, 11:46 AM   #6
TWelch's Avatar
Alabama
Lyle, that is great to know. . .
Thanks
Old 01-18-2017, 11:49 AM   #7
TWelch's Avatar
Alabama
Escape
Glenn, the Escape looks wonderful. It kills me that its weight (17 is above my vehicle's capacity (Odyssey van = 3500). . . . I just ran the conversion rate for the CAD -> Am $$, and it comes out actually less than the Lil Snoozy. . . . Big sigh. . . .
Thanks,
Tonie
Old 01-18-2017, 11:52 AM   #8
TWelch's Avatar
Alabama
Escape
. . .and I have no idea why that emoticon came up. . . I typed in 17' in parentheses!
Tonie
Old 01-18-2017, 12:06 PM   #9
Are you sure? Here's what the data says (click to enlarge):
Name:	Escape 17 Weights.jpg
Old 01-18-2017, 01:02 PM   #10
TWelch's Avatar
Alabama
Escape
Oh, my goodness! I would love for this to work out!
I was looking at the website chart at:
The 17 Foot Escape
for the "Gross Vehicle Weight Rating" listed in the table. . .
What does that mean?
Thanks for the help,
Tonie
Old 01-18-2017, 01:05 PM   #11
Gross vehicle is how much you can load it to.
My Escape 17B weighs about 3,200 # at most, with a 325# tongue weight. I tow it with a RAV4, which has tow/tongue of 3,500/350.
Old 01-18-2017, 01:13 PM   #12
TWelch's Avatar
Alabama
Glenn,
Thanks! That makes a difference!
Old 01-18-2017, 01:29 PM   #13
Tonnie, you may be confusing GVW (gross vehicle weight), which is the total weight of a vehicle or trailer as actually loaded, with GVWR (gross vehicle weight rating), which is the manufacturer's upper limit on the most it can weigh. The column labeled "TOTAL" in the chart I attached shows gross trailer weights. All are below your vehicle's tow rating, and only one even comes close.
The tongue weights in the chart are pretty variable, and a couple exceed your 350 pound rating. That tells me you would have to pay attention to where you store stuff in the trailer as well as how much stuff you bring. You want 10-12% of total weight on the hitch for stable towing.
One other factor needs to be considered. How many people and how much cargo will you carry in the vehicle? If you plan to load up the vehicle, you cannot pull as heavy a trailer. Things like axle weight ratings and gross combined weight ratings (total weight of vehicle plus trailer) come into play.
Old 01-18-2017, 01:36 PM   #14
TWelch's Avatar
Alabama
Ron, thanks so much for the info. I am scrutinizing and absorbing, and will be using all this. . . . I am sure my van will be loaded. . .
I really appreciate the explanations and help.
Tonie
92 Scamp stove and flooring question staciw02 Problem Solving | Owners Helping Owners 6 09-16-2014 10:42 AM
Flooring question James Bar. Problem Solving | Owners Helping Owners 5 07-14-2010 09:27 PM
Another Flooring question Bonnie Problem Solving | Owners Helping Owners 0 03-03-2008 05:22 PM
A flooring question Bonnie Problem Solving | Owners Helping Owners 6 02-10-2008 10:21 PM
A Flooring Question Bonnie Problem Solving | Owners Helping Owners 12 10-14-2007 05:49 PM
