Originally Posted by AliceGardner
It makes enough noise so I can't sleep next to it. Seems to be an internal fan in it. Scamp is replacing because it is a new trailer.
It is an easy swap if you are comfortable with the
electrical work.
But be advised that most RV converters have fans to cool them off under heavy load. If the converter is undersized in its capacity, then the fan might run a lot. If it is properly, or oversized, then generally speaking the fan wont run much at all. Since it is a new trailer we should assume that the converter is the right size (capacity). So unless you are running a lot of 12 volt stuff including charging a well depleted
battery, I would not expect to hear the fan come on often. In fact I have a
light load on my converter and I dont think I have heard the fan come on once in two years. If your converter fan runs continuously there might well be something wrong with it. But if its only occasionally then that is likely normal operation.
