Question on Scamp repair person/shop in southern bay area CA - Fiberglass RV
Old 10-12-2017, 04:00 PM   #1
AliceGardner's Avatar
Trailer: 16 'Scamp Trailer
Hi All,
I need to get someone to put on a sway bar and put in a new converter on my new Scamp 16S. Does anyone recommend anyone in the Bay Area, like maybe in San Jose area? I live in Los Altos so on the peninsula.
Alice
AliceGardner is offline   Reply With Quote
Old 10-12-2017, 06:14 PM   #2
Gilda's Avatar
Trailer: 2011 Scamp 13'
Perhaps a U-Haul center (yes, the same people you rent a $20/day van from) could install a sway bar. They installed our hitch system and they frequently do this.
The Gleeful Glamper
Gilda (Jill-da)
Old 10-12-2017, 06:33 PM   #3
Whats wrong with your converter?
achang001 is offline   Reply With Quote
Old 10-13-2017, 10:37 AM   #4
It makes enough noise so I can't sleep next to it. Seems to be an internal fan in it. Scamp is replacing because it is a new trailer.
Old 10-13-2017, 02:06 PM   #5
If you drag it over to my place, I can put it in for you.
Old 10-13-2017, 06:14 PM   #6
It is an easy swap if you are comfortable with the electrical work.
But be advised that most RV converters have fans to cool them off under heavy load. If the converter is undersized in its capacity, then the fan might run a lot. If it is properly, or oversized, then generally speaking the fan wont run much at all. Since it is a new trailer we should assume that the converter is the right size (capacity). So unless you are running a lot of 12 volt stuff including charging a well depleted battery, I would not expect to hear the fan come on often. In fact I have a light load on my converter and I dont think I have heard the fan come on once in two years. If your converter fan runs continuously there might well be something wrong with it. But if its only occasionally then that is likely normal operation.
Old 10-17-2017, 10:26 PM   #7
tua
tua's Avatar
Trailer: Happier Camper
Try Eyers Hitch Center in Santa Clara
Trailer Hitches - Eyers Hitch Center Inc., the Trailer Hitch Experts, located in Santa Clara CA.
tua is offline   Reply With Quote
Old 10-18-2017, 07:13 AM   #8
can I drag mine over too?
bob
Old 10-18-2017, 12:40 PM   #9
Sure.
Here is a repair person in Chilliwack, BC stude Care and Feeding of Molded Fiberglass Trailers 7 11-08-2016 01:47 PM
Upholstery shop reccomendation in Southern Ontario JasonE General Chat 2 11-17-2015 01:19 PM
Boler Service/Repair Shop Recommendations Red-Dwarf Care and Feeding of Molded Fiberglass Trailers 1 11-01-2011 05:48 PM
Clipped by a semi, does anyone know of a good repair shop near Madison CeliaL Problem Solving | Owners Helping Owners 0 07-21-2009 09:32 AM
gas heater overhaul - RV shop or HVAC shop? jack maloney Care and Feeding of Molded Fiberglass Trailers 1 04-20-2008 01:58 PM
