Questions on Truck Engine Size - Page 2 - Fiberglass RV
Old 09-13-2007, 02:55 PM   #15
Jeanne and Steve's Avatar
Trailer: Casita 16 ft 1984 and U-Haul CT13 1985
Roger nailed the [b]manual-versus-automatic issue in general. In the 2007 Ford Ranger specifically, as published by Ford, there is a difference (yes, 7000 lb manual versus 9500 lb auto, or 2500 lb) only with the 4.0 L. I suspect that the same transmission comes with both V6 engines, and its clutch can only withstand the stress of getting 7000 lb moving; that's not an issue with the 3.0 (the engine is good for only 6000 lb anyway), but becomes the limiting factor with the 4.0.
Thanks Roger and Brian for the explanation! The question has been plaguing me since seeing the difference printed up in the owner's manual of our - you guessed it - manual trans 4.0 L Ranger. We did lots of research before buying it, but somehow never realized the manual trans would make a difference in load capacity. The good news for us is that we are within our GCWR with our loaded Casita (just barely!), and the good news for me (but not Steve) is it offers a solid reason why we shouldn't bring so much stuff!
Jeanne
less stuff, more fun
Jeanne and Steve is offline   Reply With Quote
Old 09-13-2007, 05:40 PM   #16
Brian B-P's Avatar
More good news: once you're moving, and no longer slipping the clutch, the weak link the drivetrain is no longer an issue. If you are careful about how you use the clutch, maybe being right at the rated GCW is not such a concern, since you know the rest of the truck is good for 9500 lb.
Old 09-14-2007, 11:24 AM   #17
Trailer: 84 16 ft Scamp
For pleasant towing I prefer to stick with GM, i.e., generous motors.
Also, if you've never tried one, diesel engines just love to pull.
TV - Pickup Truck, SUV, or even a Full Size Van? Karalyn Towing, Hitching, Axles and Running Gear 27 11-12-2009 07:16 AM
Tacoma 2.7 4cyl. engine Paddy Morris General Chat 15 04-21-2008 10:45 PM
TRUCK SIZE? billpool General Chat 16 05-01-2007 04:37 PM
