Really crummy Scamp shower fitting - Page 2 - Fiberglass RV
Old 02-13-2006, 08:02 PM   #15
Trailer: Fiber Stream
Thumbs up
I'm confused. I thought that all of the trailers had plastic faucets. In fact, the whole plumbing system in my Fiber Stream is made entirely out of plastic. Plastic pipe, plastic compression fittings, plastic faucets, plastic drains, plastic tanks...
Old 02-13-2006, 11:39 PM   #16
I don`t think that anyone mentioned gas fittings as yet.......I mentioned gasoline and high pressure lubricating grease....suppose I could have also mentioned black pipe threaded fittings used in industrial applications such as hydraulic hoist systems which are relatively low pressure (350 psi or so) .......on my bus conversion I ran 3/8" black pipe from the propane regulator to the tee offs for the appliances, then single flared copper from there on and it was approved........anyway this is pretty far off the topic of plastic faucets so back to the topic I go.......Benny
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
custom fitting a memory foam mattress Phillip Modifications, Alterations and Updates 12 06-02-2009 05:00 AM
thoughtful engineering and fitting-out? Richard Davis Care and Feeding of Molded Fiberglass Trailers 13 08-08-2008 07:37 PM
Shower in 13 Scamp LeBoutillier Modifications, Alterations and Updates 6 03-10-2006 03:42 PM
want Scamp with shower Craig,B Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
