Redo of 1984 Companion (U-Haul) Trailer - Page 9 - Fiberglass RV
Click Here to Login
Old 09-22-2020, 07:21 PM   #161
Joan of Shark's Avatar
Trailer: Companion
Yes, I used Citrustrip on the entire trailer. It did the job- more work required in some places that others. But it did not damage the fiberglass, and didn't make me want to pass out from the fumes. It also was gel-like so that it would adhere to the vertical surface quite well.
It sounds like you've found the pertinent posts, but here's the index to the whole trailer saga- which is still in progress.
My Quality Day: Index for Fiberglass Trailer Refurbish
Good luck!
Joan of Shark is offline   Reply With Quote
Old 09-23-2020, 09:12 AM   #162
Trailer: Ventura 1973
Calgary
Thanks for the info. Much appreciated.
Brian
Parallel49th is offline   Reply With Quote
Old 07-16-2021, 12:41 AM   #163
Trailer: Companion
I've been busy! Forgot to post some things here, so I'll catch up. I rehung the door and it is better, but not all the issues are solved. It's as good as it's going to get for now.
Improving the door
Old 07-16-2021, 12:49 AM   #164
Trailer: Companion
Extensive Bondo work- better than I thought I could do
Bigger Bondo
The Big Hole
Old 07-16-2021, 12:54 AM   #165
Trailer: Companion
Painting Complete
The exterior painting is complete!
Scrub-a-Dub
Undercoat
First Coat
Details about the painting process
Final Coat and additional comments
Old 07-28-2021, 01:24 PM   #166
Trailer: Companion
I’m going to try to lay out my dilemma with my trailer lights more clearly with the options. First, I’ll list them and then add commentary below. Please note, that except for replacing one clearance light fixture (options 1 or 2) I’ll need to order everything else, so I’d like to get it right the first time. I am very frustrated with this need because I know almost nothing about automotive lights. My first choice is 2, if possible.
1. Keep the original incandescent fixtures.
2. Keep the original fixtures and just put LED bulbs in the sockets
3. Change all the fixtures to LED fixtures. (There are two sub-options to this)
Comments on Option 1
Pros- definitely easy. I need to replace one clearance fixture, but that’s super simple.
This is the time to make any changes before I finish the interior.
Cons-The lights are not bright. I have thought ever since I bought the trailer that someone was going to run into me, not realizing I was braking because they are not visible enough in daylight. I want LEDs
Comments on Option 2
Pros- definitely easy if it works.
Not too expensive, and quick, if I can get the right bulbs. (I do have to replace the one clearance light fixture which I can get locally)
Cons- Trying to figure out which bulbs are correct. The clearance light bulbs are CE 193. I can apparently replace them with CE 194s, and I have found this set as opposed to my local store that wants $7.99 for ONE bulb. https://www.amazon.com/LED-Extremely...ense-Clearance
The taillight bulbs are CEC 1157 (assuming someone put the correct bulb in last time it was changed), and I think I can replace it with these
https://www.amazon.com/dp/B073S46PX4
Then I discovered this video, so now I’m thinking I shouldn’t do option 2
Comments on Option 3
3a- For this sub option, I would keep the taillight fixture boxes and just put in new sockets. They would need a little bit of jury-rigging, but I don’t have to remove the old boxes, fiberglass the holes and paint.
3b- For this sub option, I would remove the old taillight boxes, fiberglass the holes, paint, etc. and then mount surface units.
Pros- all new equipment would be nice, and would forestall future issues
3b makes adding a license plate light easy, which the trailer does not currently have.
Cons- Time and cost. Con specific to 3a- trying to figure out which sockets are correct.
Extra comment: 3a doesn’t save me any money. By the time I buy all the parts separately, the cost is nearly as much as 3b. The only thing 3a does for me is save the days it will take to do fiberglass and coats of paint.
Any advice welcome.
Old 07-28-2021, 04:59 PM   #167
A suggestion on the lights. On both our Uhaul CT13 and our Casita 17 I installed a LED light bar over the rear window that is a combination marker / turn / stop light. The reason I did this is because the original stop / turn lights are mounted low on the rear of the trailer, and a vehicle following close, especially a big truck, can't see them. Most important in heavy stop & go traffic.
Old 07-28-2021, 05:12 PM   #168
Trailer: Companion
Thanks for the suggestion. Will price one.
Old 07-28-2021, 08:08 PM   #169
The one I installed on our Casita came from superbrightleds.com, part # TLB-R11. Think of it as like the high mount or "third" brake light on newer vehicles. With the tail lights on it lights up to look like 3 individual marker lights, turn lights show up on what side you select, and stop light is both turn lights on, same as a car. The one on the other camper came from Amazon but I don't have the brand or number for that one.
Old 09-21-2021, 06:57 PM   #170
Trailer: Companion
I have gotten behind the 8-ball in keeping this thread up to date. However, before I went on my summer trip with the trailer, I did finish the bench on the other side, installed new exterior lights and more interior electric. Worked on the interior walls, and made a new table. You can see all these things at My Quality Day: Index for Fiberglass Trailer Refurbish Days 127-146
Old 09-25-2021, 06:57 PM   #171
Trailer: Companion
I'm getting the rest of the insulation figured out. Barely made a start.
See My Quality Day: My Trailer Redo - Days 147, 148 - Insulation Experiments
Old 09-27-2021, 06:32 PM   #172
Trailer: Companion
Finally, the curved beadboard walls are done! My Quality Day: My Trailer Redo - Days 149-151 - Beadboard Walls Finished
companion, re-do, redo, refurbish, u-haul
Another Stolen Trailer - 1984 U-Haul Donna D. General Chat 0 09-04-2014 09:01 PM
Our Perris Pacer Redo--and Upcoming Vintage Trailer Show! LagunaDirt Modifications, Alterations and Updates 6 01-11-2014 04:10 PM
OK: 1984 Companion Ken C Referrals: Molded Fiberglass Trailers 0 11-01-2013 05:15 PM
1984 13' U-Haul for sale in western NC Tina W Classified Archives 5 07-31-2006 05:20 PM
SOLD - 1984 u haul Tom Stewart Classified Archives 4 07-03-2006 09:18 PM
