Removed the stinky slinky tube - Fiberglass RV
Old 04-04-2016, 06:06 PM   #1
BillE's Avatar
Trailer: 2016 Scamp 13 Deluxe Birch w/front dinette
Wisconsin
Here are the before and after...never did gel coat before...but hey ..I'm not the sharpest tool in the shed..and I have seen dull tools do it..so I said why not
A three egg family..
(2) Big Green Eggs for cooking..(1) Egg for camping
BillE is offline   Reply With Quote
Old 04-04-2016, 06:37 PM   #2
Great job Bill!
Old 04-04-2016, 06:44 PM   #3
MarkyVasquez's Avatar
What did you use to plug up the holes and redo the gel coat.
Sent from my Nexus using Fiberglass RV
MarkyVasquez is offline   Reply With Quote
Old 04-04-2016, 07:02 PM   #4
BillE's Avatar
Wisconsin
Here's what I did..and why
Marky
I don't like how the hose tube will yellow (and collect dirt) on the front of the camper....so I took it off. I never did any type of fiberglass before..but I have patched drywall ..and have frosted cakes before ...so how much different can it be...drilled off the head of the rivet...removed the tube holder..scraped off the caulk...cleaned with acetone...filled holes with a marine epoxy patch....ground surface so gel coat would adhere....filled....sanded...wet sanded with 2000 grit...
Old 04-04-2016, 08:32 PM   #5
sokhapkin's Avatar
SW Florida
What was the reason to remove the tube?
Sergey
www.callwithus.com
Old 04-04-2016, 08:42 PM   #6
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
Really good job, Bill. As good as a pro. Congrats for removing that silly, prone to yellow, tube.
bpfick is offline   Reply With Quote
Old 04-04-2016, 08:46 PM   #7
Those tubes are just flat Fugly. IMHO one of the worst decisions Scamp has ever made and they've done it for years. Like THAT thing should be some focal point of beauty?
Old 04-04-2016, 08:48 PM   #8
[QUOTE=BillE;
Marky
I don't like how the hose tube will yellow (and collect dirt) on the front of the camper....so I took it off. I never did any type of fiberglass before..but I have patched drywall ..and have frosted cakes before ...so how much different can it be...drilled off the head of the rivet...removed the tube holder..scraped off the caulk...cleaned with acetone...filled holes with a marine epoxy patch....ground surface so gel coat would adhere....filled....sanded...wet sanded with 2000 grit...[/QUOTE]
Just there, in the post previous, Bill answered your question.
Old 04-04-2016, 08:51 PM   #9
Agreed.
Old 04-04-2016, 09:25 PM   #10
I removed mine as well a number of years ago for the following reasons:
1) Its UGLY
2) Dysfunctional - not large enough to hold the hose and fittings
Old 04-05-2016, 08:32 AM   #11
Trailer: R-Vision Trail Lite
Question: Now where do you store your stinky slinky with the storage tube removed?
Uplander is offline   Reply With Quote
Old 04-05-2016, 09:00 AM   #12
I put a square fence post with end caps on hinges, under the trailer and it takes a long hose with the attachments on it.
Old 04-05-2016, 09:09 AM   #13
BTW if you want to keep the removal of the old hose holder real simple you can simple fill the holes left with rivet and snap cap. Use some 3M marine compound to shine up the area behind where the tube was (it will be discoloured due to lack of cleaning waxing behind the tube) to clean up the area and your done.
Old 04-05-2016, 10:43 AM   #14
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
Carol, how did you attached your fence post to bottom of trailer? I like this idea as I've been storing my stinky slinky in the Scamp's original holder in the bathroom while traveling...the hose holder was removed by my trailer's original owner.
M Scott is offline   Reply With Quote
Where to store the stinky slinky in a Parkliner? frank_a Modifications, Alterations and Updates 70 05-31-2016 12:59 PM
Stinky slinky hose brands? BatDude Problem Solving | Owners Helping Owners 26 02-26-2016 05:56 PM
where do you put the stinky slinky? Christi V. Problem Solving | Owners Helping Owners 25 08-14-2013 10:08 PM
Still stinky! Yamaha_gurl Problem Solving | Owners Helping Owners 6 07-18-2011 10:08 PM
Mounting 13" (Regular, Tube) TV Tirah Problem Solving | Owners Helping Owners 17 01-26-2007 04:51 PM
