Repairing Fiberglass hole. - Fiberglass RV
Old 06-21-2015, 12:37 PM   #1
Trailer: R-Vision
Hello All. I have a 2013 travel trailer that I put a hole into on the bottom rear panel. I'm pretty sure I can repair this in my driveway but the answers that I am getting from my local hardware store are a little confusing. The hole goes all the way through to the aluminum frame and I'm not able to access the back side of the hole.
So my questions are:
Do I repair with a fiberglass patch and then gel-coat or can I use just the gel-coat?
Can I use a body filler or putty then use gel -coat?
How thick are you able to apply gel-coat and have it work?
How should I proceed with this?
I was able to add a piece of 1/8" vaneer for a backing which matches the factory. I am not wanting to use the fiberglass patch unless I absolutely have to. If I'm able to patch the spot to keep moisture out and make it look half way descent I will be happy. I currently
have a 16oz can of Evercoat Marine Premium Gel-Kote #105673, Evercoat mold release agent #105685, Evercoat Fiberglass patch kit #100637, a brush, and a putty knife.
Thanks for your time and help.
Jasonc is offline   Reply With Quote
Old 06-21-2015, 01:05 PM   #2
Photos help
Old 06-21-2015, 01:14 PM   #3
Trailer: R-Vision
I'm new to this forum and I'm trying to post a picture. Not sure how.
Old 06-21-2015, 02:39 PM   #4
Would it be possible to form some aluminum flashing, secure it then fiberglass over that?
Old 06-21-2015, 02:49 PM   #5
Trailer: R-Vision
I made up some 1/8" pieces of wood to fit in as backing. That is how the factory did it and the gel-cote directions says to use on wood. Do I have to use fiberglass or could I use filler putty and then gel-cote over that? After installing the wood backing there is only a thint layer that would need to be filled.
Old 06-28-2015, 09:42 AM   #6
What is the outcome of the patch project?
Old 06-28-2015, 10:26 AM   #7
Trailer: R-Vision
Thanks for the interest. I used a piece of 1/8" vaneer as backing and applied a good amount of Evercoat's type 27 body filler. I Let that cure and sanded it down to just below the edge where the existing fiberglass meets the type 27. Today I will brush on a layer of Gel-Coat and wet sand to finish.
Repairing a large hole in fiberglass shell Ming Modifications, Alterations and Updates 7 01-24-2014 04:31 PM
Repairing a tear in fiberglass peterh Modifications, Alterations and Updates 5 10-06-2013 12:35 AM
Repairing cracks in green fiberglass MadgeW Care and Feeding of Molded Fiberglass Trailers 15 03-06-2012 07:23 AM
Repairing a large hole. Derrick719 Care and Feeding of Molded Fiberglass Trailers 9 01-28-2012 05:57 AM
Repairing fiberglass chips? Greybeard Problem Solving | Owners Helping Owners 8 10-29-2011 08:48 AM
