03-12-2014, 04:14 PM
Repose fire logs Test
Repose fire logs
Since my last post I have obtained the re-loadable Repose fire log to use in our home potbelly stove.. This fire log looks almost exactly like the closed fire log except it has an opening on top where you can add pellets at any time provided you have a safe scoop to do so.
I can tell you this, I have used both the end loaded and open face fire logs and found they are of the highest quality and burn most efficiently.
I highly recommend both of them and assure you that you will get the utmost enjoyment out of using them.
As you know, in some states it is against the law to bring your own firewood along and with these fire logs all you need is a bag of wood pellets like they use in pellet stoves and you’re set for an enjoyable time around the fire pit.
03-13-2014, 07:33 PM
Trailer: 2012 Escape 19
Thanks for the review.
Incidentally, anyone buying these should plan on buying their wood pellets NOW. Stores around my area have run out and will not restock until late autumn. I did get a 20 lb bag of Hickory pellets for cooking, but they cost $19/bag versus about $5 for a 40 lb bag of common fuel pellets.
07-04-2014, 08:21 PM
Repose fire logs aren't marketed for cooking use, but I decided to try anyway.
This July 4th I cooked with the Repose fire logs. I was curious to see how they would work in a Weber round BBQ kettle grill. So I loaded hickory pellets into the smaller 3 (left out the biggest one) and started them with a fire starter near one end. This did not work out ideally; one end was nearly done burning by the time the other end began burning. But by moving burger patties around every few minutes, I was able to grill a bunch of patties in about 20 minutes.
The nearly smoke-free flames would lick out beyond the cooking surface if the grill cover was up. With the lid closed, the fire lacked oxygen somewhat and therefore produced tremendous amounts of smoke. After 20 minutes the burgers were juicy, medium (pink inside) and well laden with hickory flavor. Everyone but my wife said they were very good (my wife hates wood-smoked anything).
My conclusion is that this method is not ideal by any means but the end result was still really tasty (to me and to our guests). I can see now that the wood pellet grills must have this thing honed to a science, with their temperature-controlled pellet feeds and everything.
I'm not sure how well the Repose logs would work for cooking in an open campfire, but one of these days I hope to try that out too. First, though, I will need to get a grate positioned high enough to take advantage of the flames' heat; one does not truly get a bed of coals from pellets, the way one does from a real log.
07-04-2014, 08:31 PM
A camping friend in the site next to us has a set of the pellet burning logs. I didn't get to see them burn start to finish, only at the end of their burn, so not familiar with how they work overall. But for cooking over a fire, we bought at Walmart a tripod setup that has a 16" or so round grill that hangs on a chain and can be raised and lowered over a fire. Made by Coghlan and cost about $20. We cooked a couple steaks one time and burgers another time and it was OK. Should work with the Repose logs too.
07-04-2014, 09:38 PM
Not marketed for cooking?
They show cooking over them on the website:
Repose Fire Logs
07-04-2014, 10:32 PM
Hmm, roasting hot dogs. I guess they do, at that!
Bob, thanks for the tip on the tripod.
07-05-2014, 04:24 AM
We often cook or heat our lunch over a fire when deer hunting in MI's Upper Peninsula. We use a swing grill. Simply pound a pole into the ground at the edge of the fire, and attach the grill to the pole at the elevation you want. You load the grill with whatever your cooking and swing back over the fire. It adjusts easily to the fires changing heat. Here's a link:
Amazon.com : Texsport Heavy Duty Swivel Grill : Freestanding Grills : Sports & Outdoors
Tom
07-05-2014, 09:36 AM
New Jersey
Interesting....might invest in one this fall for next year. How long does a basket of pellets last burning?
deryk
07-05-2014, 09:44 AM
I cooked a batch of burgers, then a second batch, and still had fuel burning. I would say close to 1 hour of burn time.
07-05-2014, 09:46 AM
we use them in the winter in our pot belly stove and they really work well. I ordered 3 of the large ones and one open type for the fire place. I think they are well worth the price because they are made of the best material and the pellets eliminate the need for fire wood.
In many states you are not allowed to bring in your own wood so the pellets and the Repose fire logs would be the perfect way to have a camp fire without the hassel and high price of campground wood.
07-05-2014, 09:54 AM
I've never used the repose logs. We use dead trees found near our lunch site. The swing or swivel grill was in response to Mike's post #3
"First, though, I will need to get a grate positioned high enough to take advantage of the flames' heat; one does not truly get a bed of coals from pellets, the way one does from a real log."
It's just a very good way to cook over an open fire. We typically heat soup, make coffee, burgers, or set pie irons on it. It will hold quite a bit of food at the exact height you want it.
Tom
07-05-2014, 10:08 AM
You might want to ask what substance is holding the pellets together ( whatever you buy ) before using them for cooking.
07-05-2014, 12:57 PM
Glenn, I used hardwood hickory pellets from Traeger, sold specifically for grilling. No added substances in them. But I agree that standard heating pellets can have additional substances included.
07-05-2014, 04:50 PM
When the cheese is gone the holes go on hold, but next piece of cheese and "magic" There back!!
Black magic (or Black Diamond Cheese ) ???????????
07-05-2014, 05:49 PM
Where does the holes go when U Cut The Cheese?
07-05-2014, 11:20 PM
Glenn, I've been heating my home with a pellet stove for 10 years and according to the bags labels it's all natural with no additives.
I buy them at Lowes or Home Depot.
I guess the high pressure extruding holds them together.
John
07-05-2014, 11:51 PM
It's OK.
I use a propane grill and don't ask what's in the gas.
Just curious. Some fire logs have paraffin in them and would make a marshmallow taste awful.
