Roof Mounted A/C or Front/Side Mount ??? - Fiberglass RV
Old 12-02-2012, 01:01 PM   #1
Trailer: 2015 Oliver Legacy Elite II 23' 6"
Hi .... Puting off ordering our new Scamp til Mon. , can't decide which way to go with the A/C ....... need help ..... Thanks , John & Gwen
John Cole is offline   Reply With Quote
Old 12-02-2012, 01:32 PM   #2
Trailer: Fiber Stream
I would at least order it with the roof structure strengthened for one even if you do not get the Air Conditioner itself right away. Normally if you order it without, the roof structure cannot support the weight and you have no choice but mount a Window unit in a window or under a bench or in the closet.
Old 12-02-2012, 01:51 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I live in the Pacific Northwest so thankfully will never be faced with this decision!
However, if I was:
I think I'd opt for roof-mount since inside storage/wall/window space is already so limited on these little trailers. I'd hate to give up one square inch of such space if I didn't have to!
Francesca
Old 12-02-2012, 02:13 PM   #4
It's far cheaper to replace a storage/wall/window air conditioner than roof mount. But, I'm with Francesca. Get it up and out of the way. Cold air sinks.
Does the roof model A/C Scamp offers come with a heat strip? I'm very impressed with the heat strips I've seen in Casitas. Plenty warm and no roaring heater fan. Of course, you have to be hooked up to power.
Old 12-02-2012, 10:13 PM   #5
IllAnnoy
The roof mount is the way to go. The only drawback would be if it interfered with door height in your storage building.
The price difference is more than offset by the quality difference.
Also if you order the roof A/C , consider adding the heat strip, it's a great option!
Old 12-02-2012, 10:43 PM   #6
Administrator
Mary F's Avatar
As I've said many times, I wouldn't want roof mount, because I don't want to give up the Fantastic Fan in the vent above the bed (in our Casita). YMMV with a Scamp. (Casita puts a FF in the forward vent when there's the roof mounted AC. I'm sure that helps, but I like the FF over the bed.)
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 12-02-2012, 10:57 PM   #7
Name: Carl & Lynda
Idaho
Neighbor bought a new Casita with AC in the right front corner. I am very happy with the roof mount on our Scamp --- The storage room is very important in the front corner.
Carlynda is offline   Reply With Quote
Old 12-02-2012, 11:24 PM   #8
I bought a Polar Cub 9200 BTU from another member that he had for his Scamp and never put it in.
I put it in my 17 foot Bigfoot works great in 100 plus temps.
Roof mount may not be the cheapest way but is the best way.
Old 12-03-2012, 01:38 PM   #9
IllAnnoy
My 13 Scamp has a front bath, a roof mounted A/C, A fantastic fan above the bed, and a roof mount antenna.
Old 12-03-2012, 02:33 PM   #10
What- no rooftop boat?
Francesca
Old 12-03-2012, 04:32 PM   #11
IllAnnoy
Francesca
I was only pointing out that... if there is enough roof space on a 13 Scamp then there certainly would be enough room on a much larger 17 Casita.
Although this boat (Portland Pudgy) might fit just fine!...
Old 12-03-2012, 08:38 PM   #12
Borden's Avatar
Name: Borden and Carole
Swampy design for the offline camper
We can not put a roof mount on our boler roof is not strong enough but they make a side mount rv unit that will fit under seat.
Will consider making one using a cooler, 12 volt pump, heater rad, 12 volt fans and some hoses.
Got the idea from a web site, place ice in cooler with a little cold water close it, hose runs from bottom of cooler through lid up to rad through it and then pump back to cooler closed loop with fans blowing air through the rad; this swampy being closed will not add to much moisture.
We have no power most of the time while we camp except battery, also can use extra hoses to power rig from cool stream with filter for times near one. (may require second battery)
1978 Ontario made Boler
New roof-mounted solar panel peterh Modifications, Alterations and Updates 13 09-13-2012 07:13 AM
Roof Mounted Shelf/Cabinet Kurt in BC Problem Solving | Owners Helping Owners 41 10-14-2009 07:41 PM
Roof Mounted Fiber Glass Shelf Kurt in BC Modifications, Alterations and Updates 10 03-24-2008 09:34 PM
Roof Mounted A/C Units Butch H Care and Feeding of Molded Fiberglass Trailers 3 03-25-2007 03:09 AM
Roof vs. Front Mounted AC Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-20-2002 09:41 PM
