Roof Seam Leak? - Fiberglass RV
Old 05-15-2011, 02:04 PM   #1
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
Roof Seam Leak?
Hello! I was looking at the Burro on ebay and it said it had a roof seam leak in the past and now was fixed. I hope he didnt patch it with Silicone. But what I am really wondering is unless the roof was damaged how is it possible for the seam to leak when it's suppose to be Fiberglassed together? Is this a regular issue with Eggs assembled this way like Uhauls as well so this needs to be inspected upon purchase? How would you even check for something like that as the carpet covering the seam may hide it. Is it really something to be concerned about?
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 05-15-2011, 06:02 PM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Even the belly band trailers occasionally leak at the seam.
Old 05-15-2011, 06:44 PM   #3
CindyL's Avatar
Illinois
You can buy the stuff that covers the seam I think.
CindyL
CindyL is online now   Reply With Quote
Old 05-15-2011, 07:41 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
From the photos, the trailer looks pretty clean, but there are also no closeups of the exterior. Maybe they'll post more photos for you. You can usually ask questions about the item being auctioned. Ask the seller to describe how it was repaired.
Sometimes you can get a good feel for the seller by how he communicates with you.
Old 05-15-2011, 08:24 PM   #5
Trailer: 1980 Burro
I have a 1980 Burro that I am restoring. The seam on mine was cracked where it meets the floor in both the front and the rear about 8 to 10 inches long. The cracks may have occurred because the floor was rotted and sagged. During construction, when they glued the right and left half together they just used thickened resin. They did not use fiberglass cloth, mat or tape, so there is no reinforcement across the seam and resin alone is brittle without reinforcement. It is possible for the seam to have cracked in the roof causing the leak, although a leak around the roof vent would be more likely and could be misinterpreted to be a seam leak.
I would suggest checking the floor for rot very carefully. When my Burro was built, they did not seal the plywood edges of the floor at the wheel wells very well and water gets into the plywood and can not evaporate because of the fiberglass on both sides of the plywood.
Andy B is offline   Reply With Quote
Rubber roof leak at seam Cngdad General Chat 4 02-26-2011 09:29 PM
Roof Vent Leak barryra Problem Solving | Owners Helping Owners 8 08-04-2010 02:27 PM
Leak Around Roof Vent of 78 Trillium 4500 susan s. Problem Solving | Owners Helping Owners 13 06-17-2010 01:28 PM
roof window leak in Compact Jr. Tami Problem Solving | Owners Helping Owners 5 02-10-2009 08:44 AM
Roof Vent Leak Fred G. Problem Solving | Owners Helping Owners 3 08-31-2006 11:08 PM
