Round vs Squarish Eggs - Page 5 - Fiberglass RV
Old 05-15-2011, 08:30 PM   #57
Trailer: 1980 Burro
Are any of the below designs measurably more aerodynamically efficient than the others?
I would guess the Boler because, based on the pictures, it does not have an awning or roof vent or roof AC to create extra drag like the others and it has one of the smaller frontal areas.
Andy B is offline   Reply With Quote
Old 05-15-2011, 08:35 PM   #58
Greg H's Avatar
Trailer: 72 Boler American
Indiana
There should be a roof vent on the Boler, you just can't see it in the picture. The vent lays pretty low on the roof. GO BOLER!
Old 05-15-2011, 09:07 PM   #59
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks, Andy!
But-
We're talking about basic design differences.
For this discussion, let's leave add-ons out of the equation!
The question is,
Does the Boler's design make it more "aerodynamic" than any other fiberglass trailer of the same size and dimensions?
Francesca
Old 05-15-2011, 11:56 PM   #60
Trailer: Fiber Stream
Cool
Is it the Bigfoot that most closely represents an attempt to imitate the airplane wing model?
It does have the rounded horizontal leading edge that slopes rearward in both directions, and a repeat of same at the back of the trailer.
The Casita does have a bit more of a "Buddha Belly", but then there's the flat surface of the propane tank covers that might negate its "effect".
Plus its back is flat as a pancake, as is the Scamp's back.
Am I missing something, or wrongly interpreting what I see?
Francesca
I think you are experiencing an optical illusion re: the BigFoot. The point-of-view angle exaggerates the Lateral slope; in reality what you perceive as a slope at the back is in reality the slope of the sides. The BigFoot's back is actually just as flat as (almost) all the others.
I perceive the front (and back) of Scamp and Casita (and Boler) to be nearly identical. My tired eyes cannot differentiate what might be possibly a 1 or 2 degree difference in slope. The only "Buddha Belly" I can see is my own.
This photo of a poster gives quite a comparison. The 10 trailers pictured are:
The Bigfoot is in reality so much larger than all the rest. It will have much more wind drag.
Old 05-16-2011, 04:47 PM   #61
Trailer: 1980 Burro
Thanks, Andy!
But-
The question is,
Francesca
Lets assume we ignore the things that are mounted on the outside and we ignore the different size frontal area among the different brands, then the question is only which shape is more aerodynamic. We can also ignore propane tanks and batteries mounted up front because they are in the aerodynamic shadow of the tow vehicle. Lets also assume we ignore the underside of the trailers with all the pipes and frames shapes with poor aerodynamics.
The rounded shape has to be more aerodynamic than the square shape. The phrase "It has the aerodynamics of a brick" points out that square shaped objects do not slip through the air very well. There are no sports cars or airplanes that are square shaped. Now if you compare the shapes but not the sizes of a Boler with a Burro or an EggCamper, there may not be much difference. However comparing those more rounded campers with the square ones like a Hunter or a Play-Pac or a Companion there would be a difference.
There are brands that are somewhere in between the square and rounded because they are a square shape but with more rounded corners. Rounding the corners even a small amount can make a significant difference compared sharp corners.
The things that we are ignoring in this discussion have a greater influence on the aerodynamics than the shape does.
Old 05-16-2011, 04:52 PM   #62
Greg H's Avatar
Indiana
Ah, but there is more turbulence between the Tow Vehicle and the trailer than you think. That's the reason semi trucks have that small extension at the back of the sleeper, the closer the truck is to the trailer the less air gets in there.
Old 05-16-2011, 05:31 PM   #63
Trailer: 1980 Burro
Francesca asked that we not include factors other than the trailer shape. I don't think it was ever said that there was no turbulence between the tow vehicle and the trailer (an aerodynamic shadow is made up of turbulence). The tow vehicle size and shape and proximity to the trailer all have effects but it is only the trailer shape that Francesca asked about.
Old 05-16-2011, 05:33 PM   #64
Originally Posted by melissab View Post
With e'body watching their MPG's, I was wondering if anybody has towed both a round egg and a squarer (is that a word??) egg and can report on the MPG differences? In particular I was thinking of the Scamp/Bolers compared to the Trilliums/Escapes. I'd think the squarer FG rigs would fare worse. So is there a difference between the 2 shapes and gas mileage? And if not, why not?
Not to mention the original Poster!
Francesca
Old 05-16-2011, 05:36 PM   #65
Greg H's Avatar
Indiana
Oh, now it's a shadow. Ok, back to round versus square nothing else matters. I got it. Francesca, I like round, so I'm going to say round.
Old 05-16-2011, 05:56 PM   #66
(heavy sigh)
Melissa inquired 65 posts ago as to whether there's any significant difference in the aerodynamic design among the most common trailers under discussion in this forum.
When it comes to gas mileage, you understand.
She names the "types".
I posted pictures of the "types".
I see very little "shape" difference among them.
I say, Melissa, if you're still with us- stay within this "group of shapes", and you'll do as well as can be expected of any large object being towed down the road.
But there isn't a spit's worth of difference within the group as far as design is concerned.
This is the OTHER situation where size matters, though, so if you expect "satisfaction" at the pumps, buy the trailer with the smallest frontal area whose interior space works for you.
Francesca
Old 05-17-2011, 05:26 PM   #67
Mike Magee's Avatar
Trailer: Li'l Hauley
If I were to have a testing setup and wanted to make a prediction, I would expect the more rounded eggs to outperform the less rounded eggs by perhaps 1 mpg. I base that guess largely on the fact that my Burro beat my totally-square-edged cargo trailer by 3 mpg. A difference of, say, 16 vs. 15 mpg will only yield a savings of $21 per 1000 miles traveled, assuming $5/gallon gas. It's not much.
How to prepare Tofu
Step 2: grill some meat
Roddin' Round Doug Mager Hobbies & Passions 24 01-06-2013 05:58 PM
Casita Mods - Round Two Rob and Linda Modifications, Alterations and Updates 13 09-20-2010 10:24 PM
4 flat with 7 round?? Joan D Towing, Hitching, Axles and Running Gear 10 06-15-2008 09:05 PM
4 flat with 7 round?? Joan D Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
