Old 05-27-2012, 07:51 AM   #15
Roy in TO's Avatar
I hear you Bob.
One has to also consider the cost of modifying the FG body as well.
Old 08-06-2012, 06:41 AM   #16
Jane SC's Avatar
Name: Jane and Greg
Trailer: 1985 Uhaul CT
South Carolina
Bought one of the LG portable air conditioner units. Took out the furnace and Greg successfully connected the exhaust tube to the existing furnace exhaust hole. But that is as far as success traveled us. After connecting air unit to the 30 amp, turned it on with great expectations....blah blah blah...temp said 95, it ran quietly, but pumped semi cool air for 1/2 minute then started blowing hot air. Better than a furnace. Tried everything, even had a electrician parked next to us. Greg is on his way to Home Depot with it now...hoping it was just a lemon.
Oh, trying to retro Paddy up a bit, will try to post pics of new curtains, bedding, pillows, etc.
Jane SC is offline   Reply With Quote
Old 08-06-2012, 06:58 AM   #17
Roy in TO's Avatar
What is the rating on that fire extinguisher ... is there a code for mood altering substances?
Old 08-06-2012, 08:35 AM   #18
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
"In case of fire" open outside and watch it burn!!-I like that adaptation.
Old 08-06-2012, 09:30 AM   #19
Roy in TO's Avatar
Not sure that applies Jim, the label reads "Happy Camper". Maybe it is meant for the campfire only.
Old 08-06-2012, 10:04 AM   #20
P. Raz's Avatar
Vermont
Originally Posted by mary and bob View Post
We were at Sesqui state park in April, and there was a young lady there with a new Scamp that had the crank out side windows. I measured her side and rear windows and they were very close to the size of ours, like within a quarter inch. So I've taken a chance here and ordered one side window and one rear window from Scamp and hoping I can make them work. This is about a $400 gamble, and we'll see if it pays off. Jane, that last trip south was a trip of missed connections, we also planned to meet up with Diane in Virginia, but missed her too. We are heading back south end of November, maybe it will work out then. Bob
I believe Scamp is using Hehr 8700 series jalousie windows. If so, you are going to like them. We have them in our Trillium.
http://www.hehrintl.com/pdf/8700SERIES.pdf
These use a clamping ring that is sized for the wall thickness so I would expect some improvising will occur. Trillium uses plywood. Raz
P. Raz is offline   Reply With Quote
Old 08-06-2012, 11:20 AM   #21
Trailer: scamp 13
Thumbs up
Greg took the original UHaul rental manuel driving directions literally and went about 45 mph...I counted leaves on trees and waved at everyone that passed us mouthing "d#%n camper."
lol good thing i wasn't traveling with you,,,thats about how i drive all the time.
hang in there greg,,,we are on our time off and we don't have to hurry if we don't want to.
Old 08-06-2012, 11:47 AM   #22
Trailer: u-haul ct13
Raz: the Scamp rear window fit by widening the Uhaul opening by about 1/2" on each side and installing the clamp ring backwards. Our rear window was a real disaster, all gobbed up with silicone and non opening so this new window is a huge improvement. The original side window opening in the uhaul is too big for the Scamp window, so I got a piece of 1/8" aluminum plate and made an adapter, used fiberglass resin and some stainless steel 10-24 screws to attach it to the trailer and had the correct size opening cut into it for the new window. Made a similar filler piece for the inside out of 1/4" plywood, and again installed the clamp ring backwards. One down side of this installation is that now the window unit protrudes into the trailer a couple inches rather than flush like the original. I had to make up a new curtain rod too. Haven't water tested it yet. Window is nice but I don't think we gained any on the size of the part that opens compared to the original slider window. Still undecided if I'll replace the window on the other side or rebuild the original. I just noticed that you're in Vermont, may I ask what part, ever go to the Bennington car show in mid September? And yes the Scamp windows are Hehr. Bob
Old 08-06-2012, 12:23 PM   #23
P. Raz's Avatar
Vermont
I am trying to visualize putting the clamping ring on backwards. It turns out that the side glass on that series remains the same size so as you go to a bigger window the percentage that opens increases. Scamp uses the small ones. Our front window is huge. I don't know why you can't buy those windows cheaper. Clearly Scamp is making money selling them to you so why they are so expensive elsewhere is a mystery.
We are in central VT just south of the Capitol. Not a car guy but we have been through Bennington a number of times. Since its all secondary roads heading west we often stay in Woodford State park as a jumping off point. Raz
Old 08-06-2012, 04:02 PM   #24
The clamp ring; I think it is made for a thick wall whereas the largest area of the ring would set against the inner wall, the inner edge of it against the wall. Then the smaller diameter goes toward the window, the screws through that part into the window frame. Kind of hard to describe without a picture. I installed mine with the smallest part of the ring toward the inside of the trailer, the outside of the larger diameter against the wall. So I believe that is backwards from normal, but if so, Scamps must have about a 3 or 4 inch thick wall at the window area. I didn't get inside the Scamp that I measured the windows on so I don't know how it looked in there. Now that I know the windows are Hehr, I still haven't found a better price. Other windows that I researched were from Atwood & Pelland and a side window was close to $400!! The way I did this installation didn't alter the original opening so the original windows could be put back in. Now to get a little off topic: I asked about the car show because we take our 76 pickup & '46 teardrop to it. We drove through Woodford State Park but didn't care for it that much, we usually camp at Emerald Lake. A couple weeks ago we went to the KOA in Brattleboro because they did a vintage camper weekend, went to Curtis' Barbecue too. Do you know anything about Orvis in Manchester having a teardrop camper in their place? Bob
New UHaul Owners, the rPad2 Jane SC Hi, I am.... 25 02-09-2012 07:34 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
