RV that will fit in a sea container? - Page 4 - Fiberglass RV
Old 10-13-2015, 07:34 AM   #43
Originally Posted by John Linck View Post
If the trailer is a tight squeeze in a container how would you protect it from rattling around inside during storms, crane mishaps, etc? How carefully and securely do they tie them down? Seems even the flex in the trailer suspension would allow bumping against the container wall. Do they tie them down on solid blocks? Maybe you could use about 500 cans of spray foam or 5000 Beanie Babies to sell in NZ as padding?
I do know that much NZ and Australian wine is shipped in thousand gallon plastic bags inside containers and bottled in America; read the label. Saves weight and container space and American bottles are much cheaper.
John
The Sunrader that I helped get ready for ocean shipping was protected by stuffing two very used mattresses on each side, between the RV and the walls. The shipping company provided them.
Old 10-13-2015, 10:07 AM   #44
Normal practise is when loading a car into a container is to put wooden blocks that run the full width of the container down in front & behind the vehicles tires. Then they use the vehicles tow hooks and run straps through them and tie them down to D rings located on the inside of the container and ratchet to tighten it down. On RoRo ships they also tie the cars down to rings on the deck using the tow points on the car and tighten down the nylon slings with a ratchet.
As we all know the frames on most of our trailers or the fiberglass would not take kindly to be secured in the above fashion.
As a trailer is taller than a car if it was loaded into a container it would need protection between the outside walls of the trailer and the container, as the container will rock side to side both when being loaded/unloaded as well as while at sea. We communally used airbags inside containers but with the fiberglass trailer one would need to be carefull not to over inflate & put to much pressure on the fiberglass. Bottom line is ships roll side to side while at sea and the weather will determine just how much side to side roll you have. Have eaten more than one meal on a large deep sea vessel while sitting on the floor in a hallway with my back against the wall and my feet braced on the other in order to keep from sliding around while eating, as using the dinning room table is impossible!
RoRo ships will have some fairly large flat container beds with wheels under them so they can pull it on and off the ship that they use for large pieces of non conforming cargos as well as boats, which are normally loaded into custom built cradle first that is used as the tie down. They could use the same for a trailer but again how they secure the fiberglass trailer to the flat deck container would be my biggest concern.
If it were my trailer going onto a ship - ether on a container ship or a RoRo I would want to make sure I had come to an agreement with the company doing the loading of the trailer as to what points of the trailer they were going to use to secure it and what points of the trailer could not be used for securing it. Would also ask to be present when they did the actual loading to make sure they actually followed those instructions.
1st picture is how cars are secured on the deck of a RoRo ship. Second photo is a fairly typical way of securing a car in a standard container. Third photo is a specialized flat deck with wheels used on RoRo ships for odd ball cargo and often boats.
Old 10-13-2015, 10:17 AM   #45
Trailer: Biod X2
Airstreams are exported to Holland also. Alas not light trailers. I don't know if you could find an Eriba, they are loved everywhere. Meerkat is a USA knock-off. They're light and low so would go into any sea can
marijke is offline   Reply With Quote
Old 10-13-2015, 05:50 PM   #46
Trailer: Biod X2
Wow Carol, neat to see how it is done. I did not get pics of the trailers once loaded. Talked to SCL on phone a few times, they were very reassuring, saying it would get done right (They do their own loading at their warehouse) Both trailers got here without a scratch.
Thank you for posting the pictures!
Old 10-13-2015, 06:00 PM   #47
For more, see Let the fun begin! - Escape Trailer Owners Community
which shows loading an Escape fifth wheel into a container for shipping to the Netherlands.
If you follow the thread to the end, you will also discover there were considerable modifications to the trailer and the tow when it arrived to conform with requirements 'over there'.
Old 10-20-2015, 12:27 PM   #48
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Cool
"RV that will fit in a sea container?"
Yea, yea.. I know...
1) It's not a "trailer" (though it is fiberglass!) and,
2) You'd need to sell the farm and any kids ; )
But it will do this:
And it is quite livable...
and the original design is all over Ozland and NZ.
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Salton Sea camping ThomasE Camping, Campout Reports 8 03-05-2012 02:12 AM
Sea Cow's First Adventure with Li'l Scamp 2yax2go Jokes, Stories & Tall Tales 5 04-26-2011 05:24 PM
garbage container up off the floor Peggy Care and Feeding of Molded Fiberglass Trailers 3 09-14-2010 08:14 PM
Salton Sea Gina D. Camping, Campout Reports 11 11-26-2007 09:13 AM
land & sea international Erik J General Chat 5 02-26-2006 06:38 PM
