Sandcastle purchase? - Fiberglass RV
Old 04-25-2006, 09:43 AM   #1
Trailer: Sandcastle
I am about to purchase, based on a picture, a 1997 Sandcastle travel trailer (not 5th wheel) made by R-Vision. I can't find anything about it at the R-Vision site, and even in the NADA blue book I can only find the brand in a 96 model in a travel trailer not a 5th wheel. It is supose to be a fiberglass body. The owner thinks this makes it heaver than the normal TT (travel trailer), but is seems the fiberglass models you folks have are lighter than normal. Are there different fiberglass types that would make this one heaver than yours? I have a 4X4 crew cab 2005, Chevy 1500 not HD. Will this be stong enough to pull it? I dont have a weight distribution bar, and dont know which size to purchase, since I cant find out the tongue weight (all of the paperwork is in the trailer). We are traveling about 2 hours, to pick up the trailer tomorrow 4-25 and pull it back. Are we making a big mistake not having some kind of weight distribution hitch when we pick it up? I hate to purchase a 1000 lb hitch and find out it needs a 1400 lb hitch. On the other hand I hate to spend the extra money for the larger hitch if I dont need it.
Denise J is offline   Reply With Quote
Old 04-25-2006, 10:17 AM   #2
Trailer: Casita Spirit Deluxe 17 ft
Denise, why are you purchasing something you know nothing about. It is no mistake to be un-informed about RV's or anything else but you might want to educate yourself before handing over your money. I cannot give you any advice about the unit you are contemplating but if it was manufactured by R Vision it probably is nothing remotely like a molded fiberglass trailer. I owned a Trail-Lite by R Vision and is was your typical screwed together box rv that depreciates faster than a sled going down a slippery slop. Purchase and make quality as your first priority and it will be there long after you have forgotten about the money you spent. Martin
Martin D is offline   Reply With Quote
Old 04-25-2006, 10:30 AM   #3
Suz
Suz's Avatar
The reason ours are lighter is the way they are made. You are looking at a trailer that is manufactured like a typical travel trailer. Ours are made more like boats. They have no framing in the body as they are molded fiberglass.
Since you live in Dallas, a quick trip to the Casita Factory just above Corsicana in Rice, will probably explain it better than any of us can.
Suz is offline   Reply With Quote
Old 04-25-2006, 10:35 AM   #4
Chester Taje's Avatar
I agree .
Old 04-25-2006, 10:36 AM   #5
Suz
Suz's Avatar
Although a few of our members do or have pulled larger trailers, generally, I'm really afraid we don't have the information you need since our trailers are so much smaller. You'd probably do better at a forum like Good Sams.
Good luck!
Old 04-25-2006, 10:39 AM   #6
Suz
Suz's Avatar
Denise, you also make no mention of the length and/or the weight of this trailer. You will need to know all of this before you will know how to set your truck up.
Old 04-25-2006, 10:44 AM   #7
Suz
Suz's Avatar
Oh, my, Denise. I think you better look into this a little further. A quick google gave me this information on the 1997 Sandcastle when it was apparently new.
midrange Sandcastle (27- to 35-foot, $22,000-$29,000) travel trailers
If your trailer is THIS big, you're gonna need a WDH and you better get some info pretty quick.
If this trailer weighs as much as I think it might, your 1500 might not be enough. Depends on the engine, transmission, etc.
Old 04-25-2006, 10:52 AM   #8
Trailer: Sandcastle
It is 27 ft. I saw the info you refered to about the original cost. But that seemed to apply to the 5th wheel trailer. The NADA says the weight of the 96 trailer, which I would assume would be the same in the 97 is 7,640 but I dont know if that is refering to the tongue weight or not. The money wont change hands until we have actually brought it back to town. That is a favor we are doing for our friend who owns the trailer.
Old 04-25-2006, 10:52 AM   #9
Suz
Suz's Avatar
Denise - Is this the trailer you just purchased?
This one is listed as sold in Murphy, TX Here.
If it is, it's a lot of trailer and I fear is it WAY to much over your truck's capacity. You will not be able to tow it home without a WDH. Before you buy one, fine out what your truck's tow capacity is.
Old 04-25-2006, 10:55 AM   #10
Trailer: Sandcastle
Thank you for the feedback. Now I understand the difference. I believe this trailer has metal supports with fiberglass exterior. But not the same type of construction as the molded. But wouldnt it still provide the same R value as the molded trailers and be lighter than a traditional metal trailer?
Old 04-25-2006, 10:58 AM   #11
Suz
Suz's Avatar
Denise, check your owner's manual for the truck. I think this is too much trailer for your truck. This looks and sounds like it would take at least a 2500. It could exceed your tow limits by up to 2,000 lbs.
Regardless, you will need a big hitch for this one, but find out about your truck before you spend the money.
I'm thinking these two aren't a match.
Old 04-25-2006, 10:59 AM   #12
Trailer: Sandcastle
I looked up the tow capacity for the truck and it is 14,000 lbs. I did not purchase the one in Murphy, however that is the picture I am going on since I can not find any other pictures or discriptions anywhere else. We are bringing it back from Thurber to Dallas for the friend who ownes it and then we will decide whether to buy it. But I am concerned it may be dificult to manuver home with out a WDH. The owner has been hauling it with a 1 ton and no WDH but he sold his truck before he moved the trailer.
Old 04-25-2006, 11:06 AM   #13
Suz
Suz's Avatar
14,000 lbs for a 1500 that's not an HD and is a four wheel drive?
Okay, but I still wouldn't do it without a WDH, but that's just me.
Please, be very safe, stay off the freeways and keep your speed DOWN.
Old 04-25-2006, 11:15 AM   #14
Trailer: Sandcastle
I got my info from the Trailer life, towing guide. It only refers to 1500 Crew Cab and a 5.3L V-8. It makes no special differences for 4 wheel drive. We also have a 1995 GMC 3/4 ton standard that we have pulled an old 78, 21 ft Shasta behind in the past. At the moment it is running well and we may use that to bring it back and then if we decide to purchase the trailer we will definatly get a WDH. We had one for the old Shasta and wouldnt have pulled it the places we went without it. We do plan to drive 55 or under considering the lack of the WDH.
Airstream Purchase Steve R General Chat 12 09-23-2007 08:23 PM
Wanted to Purchase Robert Meyer Wanted: Molded Fiberglass Travel Trailers 1 07-30-2007 05:42 PM
My new purchase Chris Ennever General Chat 14 05-13-2007 12:49 PM
Looking for advice on new purchase garfield ross General Chat 9 10-08-2006 10:17 AM
Pre-purchase questions Taylor Problem Solving | Owners Helping Owners 17 10-01-2006 12:22 AM
