Scamp Axle Alert - Fiberglass RV
Old 03-29-2013, 06:55 PM   #1
carlkeigley's Avatar
NE Oklahoma
Scamp Axle Alert
This is a 2009 report, but thought some may be interested:
http://kamperbob.com/eggcentral/ScampAxleAlert.pdf
Old 03-29-2013, 08:07 PM   #2
Brian B-P's Avatar
Bob's alert document is great. There was substantial discussion of this issue at the time it occurred; that discussion was part of determining the nature of the fault.
Old 03-29-2013, 10:13 PM   #3
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
my '84 had that problem, so don't go off year, either.
Old 03-30-2013, 08:54 AM   #4
Trailer: 1989 19ft 5th Deluxe Scamp
I was told by the PO that my '89' had the axle replaced around 8 years ago and it is a problem axle . No cracks yet but I will weld in some reinforcement anyway .
shooter_41 is offline   Reply With Quote
Old 03-30-2013, 10:03 AM   #5
GMike A's Avatar
Possible ALCO axle issue
After all that I have gone through on my build I am not sure that the trailer gods are happy with me. I read the attachment and I do have the ALCO axle. Mine is mounted sideways via bolts and was not welded. I decided to take some pictures and am a bit concerned with the disparity of the two sides. I am not sure if this is normal or not and would appreciate any input from the guys who have had first hand experience on their axles. I dont see any un-natural bends but I am not sure about how the gaskets look to me after I snapped some pixs. Not sure if the gap is normal or not. Regardless I will probably end up taking it to a true trailer guy for review and wont hold anyone's feet to the fire here - but would appreciate some input if you have seen similar. Again it might be normal or not.
Please feel free to take a closer look at these pixs. After I spent days doing the mod to increase my step height Im a bit frustrated now.
GMikea's Library | Photobucket
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 03-30-2013, 01:11 PM   #6
Brian B-P's Avatar
Mike, all but last photo show where the arm goes into the axle crosstube... which is not a problem area. The last one is fuzzy and I don't see the potential problem area. I realize that this is tough area to photograph well.
The problem is where the axle brackets are welded to the frame. In a bolt-on installation with horizontal bolts like this, it would be where the part that axle bolts to is welded to the frame.
Old 03-30-2013, 01:15 PM   #7
Brian B-P's Avatar
By the way - just to help those doing searches - it is "AL-KO", not "ALCO"...
AL-KO Kober USA
Old 03-30-2013, 01:28 PM   #8
GMike A's Avatar
My bad. I had Alco electronics on the brain. I will still take it in to be looked at. One of my concerns was on the what appears to be rubber gaskets in the headspace between the axle parts. I of course was using my magnification to blow up the pictures in my sw to look at it not thinking about just the post. Yep it was dark under there and a flash close up wipes out any picture at all.
thanks Brian.
Mike
K5NAN
"Miss Adventures"
Old 03-30-2013, 01:46 PM   #9
GMike A's Avatar
Here is the picture from the PDF alert file. It almost looks like there is a cap that holds a gasket in place and that the cap has slipped off or is loose. This looks similar to mine .
Mike
K5NAN
"Miss Adventures"
Old 03-30-2013, 03:27 PM   #10
Brian B-P's Avatar
That looks like the end of one of the rubber rods; ideally these should be flush with the end of the crosstube but as long as the arm isn't pulling out of the crosstube, I don't think there's any harm in this position. AL-KO probably just didn't slide that rod in quite as far as intended. That's only a tiny fraction of the rod, if that's what it is.
There wouldn't likely be a gasket, but that does look like a cap plate which was welded on at a few spots and has come apart at one weld. I assume that the cap would be to keep stuff out of the axle internals, rather than for any mechanical retention purpose; better information is welcome from anyone who has the details.
UCF's Flexiride axles have a round shaft coming out of the rubber, so they can use a seal or bushing around it. They do apparently use a plastic (nylon, Teflon, polyurethane, something like that) bushing, which sometimes causes squeaking. With their three-lobed or square shafts, AL-KO and Dexter Torflex axles can't easily close up the opening this way.
axle, scamp
Medical Alert!!! Pam Garlow Jokes, Stories & Tall Tales 2 12-01-2012 01:06 AM
**ALERT** Scott B. General Chat 11 08-26-2009 12:46 PM
Hello! Newb Alert! Angie E. General Chat 4 08-08-2008 06:20 PM
Alert!!! Scamp with Kiddee Kamper Rentals graphics missing Donna D. General Chat 12 10-07-2007 09:21 PM
Scamp Alert on Ebay! General Chat 0 01-01-1970 12:00 AM
