Scamp Bed Weight Capacities? - Fiberglass RV
Old 04-09-2014, 06:45 PM   #1
JALEE's Avatar
Anybody know the weight capacities for the beds in a 2011 Scamp 16. Particularly the bunks and side dinette.
Thanks!
JALEE is offline   Reply With Quote
Old 04-09-2014, 06:51 PM   #2
sokhapkin's Avatar
SW Florida
Upper bunk capacity is 100#. Lower bunk and dinette are strong and should keep 300# I believe.
Sergey
www.callwithus.com
Old 04-09-2014, 07:07 PM   #3
There have been numerous posts about folks exceeding the upper bunk weights on the front goucho (in bunk bed mode). I certainly wouldn't want to be the person on the botton if it falls. It would ruin a camping trip where you should be making good memories not someone recovering from injuries.
Remember, the front portion is just fiberglassed to the front wall and there are hinge points. You are trusting the builder was having a good day.
Old 04-14-2014, 02:22 PM   #4
Virginia
When I picked up my Scamp from the factory, they told me the top bunk was good for 120 lbs. I'm paranoid about breaking it, so I just use it as a shelf.
mmcwhort is offline   Reply With Quote
Old 04-14-2014, 03:14 PM   #5
JALEE's Avatar
Thanks for the feedback. I wasn't going to attempt it myself but I was wondering about my oldest (130 lbs) and my wife (who is lighter yet). I guess I'll just reserve the top bunk to my 2 youngest this season and worry about supports another year.
Has anyone put a body on the floor? Outside of the obvious obstruction to movement, are their any creative and stowable on the floor sleeping set-ups?
Old 04-14-2014, 03:50 PM   #6
Only once intentionally - unintentionally is a good story
Just use a good camping mat and its no different than sleeping on the ground in a tent - just smoother.
Old 04-14-2014, 04:22 PM   #7
Scamp should have drilled the lower support through the fiberglass and ran the supports all the way down to the floor or at least run a brace up from the floor to the bottom of the socket. Then they should have run beams under the top bunk to the poles for a more ridged structure. And maybe add a full length piano hinge. Then you could rely on it carrying some real weight.
Old 04-15-2014, 07:36 AM   #8
Another thread a few weeks ago brought up an often overlooked factor: the glassed-in wood shelf that supports the front of the bunk. It, not the hinge, carries the weight. It was noted that undetected or neglected leaks in the window can cause the wood to rot inside the fiberglass.
I'm unable to find/post that link right now, but it did have some good ideas re strengthening the bunk set-up. If you use the Google search for "Scamp bunk" it should show up.
Old 04-15-2014, 08:11 AM   #9
Here are links to a couple of threads that might help the OP:
This one is probable the one Jon was thinking of : Bunks in a 13' Scamp
Scamp Front bunk modification to support Adults
scamp, weight
'89 19' Bigfoot holding tank capacities? Brian in Poulsbo Problem Solving | Owners Helping Owners 5 11-19-2013 07:40 PM
Boler B1700 tank capacities? Rene Care and Feeding of Molded Fiberglass Trailers 8 05-24-2012 07:35 PM
Top bunk bed weight - '77 Scamp??? Kevin J Problem Solving | Owners Helping Owners 3 11-23-2010 11:40 AM
boler 1700 tank capacities. Herb P Plumbing | Systems and Fixtures 7 07-22-2007 04:35 PM
Bigfoot 17' Tank Capacities Norm Wyndham General Chat 5 07-14-2007 10:35 PM
