Scamp front end repair - Fiberglass RV
Old 09-22-2015, 12:44 PM   #1
Trailer: Currently Shopping
Ohio
I'm looking at Scamp 16' where the floor and front end have separated and the fiberglass is split along the tow hitch. I'm pretty handy....but is this type of repair fixable? If I had to hire out would it be crazy expensive?
Photo attached
biotic007 is offline   Reply With Quote
Old 09-22-2015, 01:14 PM   #2
Timber Wolf's Avatar
North Florida
Interesting. I would venture to say that it is absolutely fixable, and also that it would probably be crazy expensive to hire it out. Unless you "have a guy" of course. The curb side of my Scamp's shell has dropped about 3/8" to a 1/2" and somebody in the past cut some relief over the tongue on that side but it seems to have been stabilized and does not cause any problems. I would be curious to know what caused the damage to the Scamp in your picture.
Edit: I had an idea. Without even seeing it I bet the frame is cracked through at least on the street side of that trailer, can you look underneath and see?
Old 09-22-2015, 01:32 PM   #3
Ohio
I havent looked at first hand yet. The owner said there was water damage to the floor and when it rotted out, let the shell drop down. I'll ask about the frame.
Old 09-22-2015, 02:06 PM   #4
North Florida
Ah, yes the front window has leaked in the past on mine and partially rotted the upper bunk support board and the floor below so I believe it. That seems like a lot of damage though so that was why I suspect the frame had given way also. The frame tubing is thin on the older Scamp's and rusts from the inside out from water getting in and collecting at a low point just back under the shell. I have watched my Scamp bounce and this area flex going down the road. This stress coupled with the rust weakening the tube allows it to crack. Not a big deal if you weld though. I jacked it up and "sistered" the area with a piece of angle iron. Good luck, hope you can save the old Scamp.
Old 09-22-2015, 02:54 PM   #5
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
I would take a very close look at the frame in that area. Not just ask. Where the parallel tubes (front to back) are bent to make the "A" toward the hitch is the area that is vulnerable.
Old 09-23-2015, 10:45 AM   #6
Yes this can be fixed and even created stronger. Look into Epoxy fiber glassing using , "West Systems Brand". Its tested. you can find at ant West Marine store. It is the best of the best. I have a Sailboat I've worked a lot with this kind of repair. I would take care of the floor issue at the same time.
AyoLane is offline   Reply With Quote
Old 09-23-2015, 11:00 AM   #7
Paul raises a good point - Looking at the picture it may not just be a rotten floor issue.
Common failure point of the frame on the Scamps is where the frame starts to go under the trailer (two frame channels welded together at that point). Also a a few feet further under the trailer where the frame takes a bends is a common point for frame failure.
If you do not already have pictures of the underside of the trailer showing the state of the frame you may want to ask for them. Then again it looks like you will need to remove the shell from the frame anyways to replace the floor and do the needed fiberglass work and repaint the trailer after fiberglass work is done, so repairing or replacing the frame may not be a big issue. Just more $$$$'s.
Old 09-23-2015, 12:32 PM   #8
Ohio
Thanks for all the advice regarding the frame. I'll have it checked out. I can't even imagine the expense of have the shell lifted off the frame. Yikes. I was hoping that the front end that's sagging could be jacked up, floor fixed and reattached to shell, and fiberglass repaired, and I'd be good. Think that might work?
Old 09-23-2015, 01:59 PM   #9
Be real surprised if you could fix the floor and that extent of fiberglass damage in that location without detaching it all from the frame, even if the frame is not broken.
5er Front Jack repair Earl E. November Problem Solving | Owners Helping Owners 1 03-15-2014 06:14 PM
Boler Front End Dinette Bonnie and Claude Modifications, Alterations and Updates 10 10-11-2012 01:36 PM
Grease Leaking from Metal End Cap on 2005 Scamp 5th Wheel jcellis54 Towing, Hitching, Axles and Running Gear 11 03-09-2012 01:49 AM
End of the rainbow Legacy Posts General Chat 1 09-26-2002 06:28 PM
