Scamp Weights - Fiberglass RV
Old 07-31-2015, 06:47 PM   #1
Trailer: T@B
Scamp Weights
I wrote to the company (Scamp) and told them about my limitations : 3500lbs towing capacity with a 165lb TW limit ....and just for a lark asked if they had a trailer with a wet bath that would fit that bill.
I got a letter back saying: "I received your inquiry and have attached a copy of our brochure and price sheets for you to view. Scamp 13' with shower and stool approximate weight 1300-1400#. Tongue weight 120-130#. Please let me know if you have any questions or concerns."
What is a stool?
ORshepherd is offline   Reply With Quote
Old 07-31-2015, 06:59 PM   #2
Toilet, I'd guess, in Minnesota-speak, perhaps?
Their weight is a dry weight, meaning without any other options, battery, propane, water, clothes, kitchen equipment, food, Likely reprints an approximation, because I doubt they have weighed every different build configuration. Figure several hundred pounds more loaded with proportionate tongue weight.
Old 07-31-2015, 07:41 PM   #3
Yep, our Scamp 13 was a front bath and 200-225 lbs on the tongue was more like it, and we didn't have the shower stall option, only the loo...
When they add the bathroom they add two walls, a closet and a marine toilet with holding tank. With the shower they add a waterproof surround and a shower pan, all in front, In back they have to add a water heater or it will be cold showers for everyone, There is also a grey water tank added for the shower & sink drain.
But they do take out a window, a rock shield and a couch/bunk bed.
Shame on Scamp.....
Old 07-31-2015, 07:46 PM   #4
IllAnnoy
What is a stool?
3500 with only 165 on the tongue?
If it is just for a Lark you must know that a Lark 6 with a 140CID flathead won't have enough power to pull much, heck in my Lark 6 (car) I couldn't even use overdrive with three passengers in the car.
If it is a Lark 8, the engine will be strong enough but the brakes will be iffy at best.
My friend's Grampa used to tow his 14ft fishing boat with a Lark 6 , but he had to slip the clutch to pull it up the ramp.
Are you sure you even have a Studebaker?... below is a Lark based Studebaker Champ...a newer Toyota truck looks a lot like one!
You will find a Scamp13 standard front bath moderately optioned could weigh about 1600# and loaded properly could make 165 on the tongue.
Old 07-31-2015, 07:46 PM   #5
Joke reply: Well the more stools you leave in the trailer, the more it weighs.. until you dump the tanks at least..
Serious reply #1: Scamp (Eveland Inc) is not real good about maintaining or spell checking their web site and email.
Serious reply #2: Please see the real world weights thread, and the customized spreadsheet for an idea of what the trailers will really weigh with options and gear.
This was average for Scamp 13s (sample size: 5 trailers):
Axle Wt, Tongue Wt, Total Weight
1508, 226, 1734
Old 07-31-2015, 08:05 PM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
[QUOTE
I got a letter back saying: "I received your inquiry and have attached a copy of our brochure and price sheets for you to view. Scamp 13' with shower and stool approximate weight 1300-1400#. Tongue weight 120-130#. Please let me know if you have any questions or concerns."[/QUOTE]
Just checked Fredrick's real world measured weights. Great list that shows how much difference there is from what under weight sales ads say to what is a fact of real road use weights are by owners. Sorry, with your tugs tongue weight limits you're not going to find a trailer with a bath that even comes close. There are units that you can tow safely but your wants/needs will have to be revised or.....a better tug.
Old 07-31-2015, 08:12 PM   #7
Trailer: T@B
Dave, there is no better tug. Even if it doesn't tug a lot...
Old 07-31-2015, 08:14 PM   #8
.... Sorry, with your tugs tongue weight limits [165] you're not going to find a trailer with a bath that even comes close. There are units that you can tow safely but your wants/needs will have to be revised or.....a better tug.
Yes 165 is really low when the tug is otherwise rated to 3500. Are you sure thats the right number? My tug has a 3500 limit also, but with a tongue weight limit of 10% of that (350).
Is it possible that you get a higher tongue rating with a weight distributing hitch?
What is the exact make model year and options list of your tow vehicle?
Old 07-31-2015, 08:14 PM   #9
Trailer: T@B
I really am not a dim wit.....but how is a person supposed to buy a trailer?! WHo the heck goes around weighing TW before they buy??
He also said the weight was 1300-1400 #.
(and the T@B is always a last resort.)
Old 07-31-2015, 08:17 PM   #10
Trailer: T@B
It's saga of the Volvo xc70. A salesman I talked to (RVs) said it had to do with the Volvo's suspension being soft in order to soak up bumps. It is a SWEET ride.
Old 07-31-2015, 08:56 PM   #11
Who Checks?
For new trailers, that part depends on the dealer. My local dealer won't sell a trailer to a customer without a suitable TV, an appropriate hitch and a brake controller if required.
As far as used trailers... If you read through the posts you will see that a lot of buyers are clueless about trailers and towing and, unfortunately, only come here after the fact trying to do everything from finding an appropriate TV to finding out how to turn the lights ON. We have heard some real horror stories that started out with "The seller told me...."
When we sold our trailers we advised potential buyers that they had to be able to safely and legally tow it before we would sell it to them. That cost us one sale and set us back 2 whole days in selling the Lil Bigfoot. One of the advantages of selling used FGRV's is the seller is usually in the Catbird Seat.
As for as the T@B, I too would find some owners and get some actual weights.
Old 07-31-2015, 09:34 PM   #12
I wish I had recorded how many times I've posted this... But I DO have a Scamp 13 with shower AND "stool" (Dometic commode to be exact which includes its own black tank with valve assembly etc.). Of course it's going to come with a fresh water tank, grey water tank/water heater, kitchen sink. It's basically "loaded" with awning, screen door, A/C. Those last 3 items that you might want to do without which could save you apx 150 lbs....with my configuration. Mine does NOT have a furnace but it did have propane. I've since removed the tank and gone all electric.
From the factory stock with the above described options- 1700 lbs with a 225lb tongue weight- and that is with a full propane tank. With a propane furnace, it would probably weight 1740ish?
What is a stool?
Old 07-31-2015, 09:35 PM   #13
I didn't say it wasn't a good tug, just not for what you said you wanted in a trailer. You can spend a lot of time trying to get a number that shows on paper will work but in reality it's pie in the sky. As Bob said, there have been many folks that have come to this site to find out their dream tug just isn't up to the job. You came here for info and advice. Well the members, with years of experience and miles behind them have voiced their thoughts to you. I've been towing for almost 50 years, 20 of those commercial. Guess it's up to you if you want to believe us or sales ads.
Old 07-31-2015, 10:37 PM   #14
Trailer: T@B
So there are lots of us, eh? Seems like a niche someone should address!
I am grateful for your experience and I do listen to you...I'm just stubborn and optimistic.
scamp, weight
16' Casita v. 16' Scamp Weights CarolMarie Problem Solving | Owners Helping Owners 6 01-14-2011 10:15 AM
Trailer Weights...What are They Really? Pamela H Care and Feeding of Molded Fiberglass Trailers 55 12-01-2009 01:21 PM
Wheel Weights with Bathroom Scale Pete Dumbleton Towing, Hitching, Axles and Running Gear 6 05-20-2009 12:18 PM
Realistic Tow/Cargo Weights V'sGlassSleeper General Chat 25 07-18-2007 12:11 PM
Need 1977 Surfside 14' Weights Raunie Aasland Problem Solving | Owners Helping Owners 2 04-24-2006 07:12 AM
