Scan Gauge 11 - Fiberglass RV
Old 06-29-2010, 08:14 PM   #1
Chester Taje's Avatar
I am just curious if anyone here is using a scan gauge to improve fuel mileage.
Old 06-29-2010, 08:45 PM   #2
paulw's Avatar
Trailer: Escape
I use one - primarily for the transmission temperature gauge.
I suppose I could watch it to try and improve mileage, but I think it would try to get me to drive like my dad did 40 years ago - easy on the gas when you start out, don't race up to a stop sign ....
I did use it to check a code and clear a CEL the other day.
I like it..
paulw is offline   Reply With Quote
Old 06-29-2010, 10:46 PM   #3
Trailer: 1990 Bigfoot 17 ft.5 ft
The Scan Gauge II info states only coolant temperature not transmission temperature .
Bill A is offline   Reply With Quote
Old 06-30-2010, 04:37 AM   #4
Ed Harris's Avatar
Evidently it will display Tranny Temp for certain vehicles.
I know some other Sprinter owners have reported this function.
I use mine every time I tow to watch coolant temp,engine load,MPG amd GPM and in general just have something else to watch and be unsettled about?
I move mine from car to car too and track and reset codes as needed.
It gives a lot of info in a small package I think.
I need to look into the extended functions more and see if I can take advantage of any in my vehicles.
Ed Harris is online now   Reply With Quote
Old 06-30-2010, 05:08 AM   #5
Mark J's Avatar
Trailer: 13 ft Scamp 1999
How do you know which vehicles it works in? I would like to moniter the transmission temp. Is must install in some simple way? (As you can see I am not familar with the scan gauge!).
Mark J is offline   Reply With Quote
Old 06-30-2010, 05:15 AM   #6
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
Here is a link to the Scan Gauge web site
http://www.scangauge.com/
Bill K
Old 06-30-2010, 05:19 AM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I have one. You can read 4 gauges at a time. I have mine set to read Water temp,Trans. Temp
Avg MPG and MPG as you drive. It has about 25 other gauges also. My ScanGauge II is on a 99 Silverado Pickup.
Old 06-30-2010, 07:49 AM   #8
Len Cater's Avatar
Trailer: 88 Cadet
To be able to track mileage requires a lot of user inputs since the OBDII connector does not have any gas tank capacity information. So on each fill up the user needs to input the data. I don't do this as I find it a bit of a pain. What the scan guage is great is looking at fault codes (check engine lights etc) and self diagnosis before deciding to take into the shop. With all of the electronic sensors on today's vehicles is nice to know what's going on and if it is an intermittent or serious issue. Besides, if the garage charges you $75 to clear fault codes, you'll have this paid for in 3 visits.
Len Cater is offline   Reply With Quote
Old 06-30-2010, 08:02 AM   #9
member
Trailer: Bigfoot Rear Queen 25 ft
Don't most later model vehicles have this information available on board?
Time K is offline   Reply With Quote
Old 06-30-2010, 08:27 AM   #10
Len Cater's Avatar
Trailer: 88 Cadet
Old 06-30-2010, 08:30 AM   #11
Ed Harris's Avatar
I think it takes less than 10 seconds at each fill-up to enter the data?
I consider this extremely quick to do.
Old 06-30-2010, 08:38 AM   #12
paulw's Avatar
Trailer: Escape
Ya - The ScanGauge just plugs in to your car's OBDII connector and lets you display whatever data's available that you want to see. Higher end versions of my truck have a display built in to the dash.
I had to set some codes to display the transmission temperature (The instructions are on their web site). Evidently its not available from from vehicles.
Gas consumption features:
When you first set it up you enter your vehicles gas tank capacity and when you do the next few fill ups, you correct the quantity of gas your car thinks you pumped in to calibrate the unit. I think its as accurate as I usually am doing division on the back of a gas reciept.
I like it for the four extra gauges I keep displayed - intake air, transmission & water temps and miles per gallon - but there's a lot more available if you want to play with it.
Old 06-30-2010, 09:16 AM   #13
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I have mine set for current MPG, Miles Until Empty, Water Temp & Battery Voltage. As long as you enter the # of gallons at each fillup & the tank size, the Miles Until Empty works pretty good. I Do wish transmission temperature was available for the RAV4, but I have not been able to find codes for it. Not sure why since there is an transmission overtemp indicator lamp.
Jon Vermilye is online now   Reply With Quote
Old 06-30-2010, 10:46 AM   #14
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
NO sensor for a RAV4.
scan gauge 2 ebay daily deal steve w General Chat 1 03-27-2010 07:03 PM
What gauge wire should I use? Kevin K Electrical | Charging, Systems, Solar and Generators 14 10-15-2007 01:13 PM
Wiring Gauge D Shubel Problem Solving | Owners Helping Owners 9 05-09-2006 05:44 PM
What gauge wire should I use? Kevin K General Chat 0 01-01-1970 12:00 AM
