02-13-2013, 11:34 PM
#21
I see that they made the same conversion error on the GVW. 4410 Kg is a bit more then the axle can carry.
02-19-2013, 09:34 AM
#22
Here is the data sheet for my 1300 trailer I call The Wedding Gift. It is a 1977 1300, with a front quarter bath room, (porta-pottie closet).
02-19-2013, 10:09 AM
#23
Not surprised! given the year of the trailer I suspect most of us where still a little rough in regards to calculations in metric.  1977 was when the cars and road signs where all changed and not until 1981 that fuel changed over....
Edit: Looks like instead of calculating 2000 lbs to kgs they converted 2000kgs to pounds. 2000 kgs = 4409.245 lbs.
02-19-2013, 10:27 AM
#24
According to the conversion from kilo grams, back to pounds on my 4500, I can carry 9700 pounds. I don't think I will give that a try.
02-19-2013, 12:18 PM
#25
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Here's mine from my 1978 Trillium 1300. No bath. It's interesting that the first 2 digits after 13 are 22 instead of 11 but the last four digits are only 198 apart. 5688 vs. 5886.
Don't know what it means, but, it's interesting!
Spanke
Trilliums Rock!
02-24-2013, 12:01 AM
#26
Cantaloupe Serial number.
The closet door has been changed, but this is what was attached to the inside. I think it may actually belong to this trailer.
The important info:
The serial number is 13-609. Fairly early.
Under Gas-burning apliances it says "2 Burner Stove" it has no model number.
1200 lb max GVW.
130 lb tongue weight.
6.00 x 13 Recommended tire size.
28 lb max load recommended tire inflation pressure.
So, to update Franchesca's table:
Francesca:45- 1100758...'78: Front Gaucho
David: 45- .... ..1101043...'78: Front Gaucho
Noreen:45-... .. 1121733...'81: Front Dinette
Scot M: 45-..... 1100893...'78: Front Gaucho
David: 13-....... 1105688...'77: Front 1/4 Bath
Spanke: 13-..... 2205863...'78: Front Gaucho
David: 13-.......609..........'73: Front Gaucho
Here is where someone could really help me identify the year of my Cantaloupe. If another 73 is 610, well then that would be proof positive.
03-05-2013, 08:02 PM
#27
From an old add
I was going through old adds. I am trying to figure out when the 1300's changed the furnace to the rounder style.
I came across another data sheet from a 1979. It is lower resolution, but readable.
SN: 45-1121172
Furnace: Duo-Therm 65512-2
Range: Brown ZML 003Y
Fridge: RM360TI
Power Converter: Pro. Dynamics PD-6921
Bering a 1979 the Metric mass is correct at 910 kg.
If the interpretation of the serial number is correct, this is a front dinette unit. All the pictures from the ad were exterior shots, so no way to tell.
CANADA - 1979 - Trillium 4500 - $2000
03-12-2013, 01:24 PM
#28
1979 - 1300 Front Bath
Thank you to Brett (bgurholt) for providing this data sheet from a 1300 that had a factory front bathroom across the whole front, with a sink and everything. That has got to be a very rare unit. As Trilliums go, it is loaded with every available option. It is advertised for sale in the following thread:
1979 Trillium 1300 For Sale$5500-sold
It looks like the serial number is in the same format as my quarter bath unit.
So, to update the list:
David: 45- ...... 1101043...'78: Front Gaucho
Unknown:45-.... 1121172...'79: Front Dinette (assumed)
Brett: 13-........ 1106227...'79: Front full bath
03-18-2013, 07:03 PM
#29
Trailer: 1980Trillium 1300
Serial number and photos of 1980Trillium1300 for David
Hi, David. I got private message from you and here is what I could supply to you in my best. Within those datas, I wouldn't know for sure which is which??? All photos enclosed were "original" when I got it before tearing it apart for " fix-up". If you want more photos for your research, I would supply more in recent future. Have a nice day...
03-18-2013, 07:47 PM
#30
Trailer: 1978 Trillium 4500
Nova Scotia
1978 4500 front gaucho
451100711
03-18-2013, 11:32 PM
#31
Randy, Thanks! nice trailer. I notice that the shelves above your dinette are the same aluminum and plywood construction as is used on the 4500's. As opposed to the molded fibreglass version that proceeded it. This is something that I think they started in 1979, maybe 1980. I may be biased, but I like your shelves because they have doors. The serial number I am looking for should be on a sticker on the inside of the closet door. It will be in the same format as below.
I am full of questions:
Does your trailer have front shelves?
What does the seat of your front gaucho, (couch) look like. Is it like a front dinette?
Dose the original, (Bargman L400) door latch work? I see that there is an additional one.
Is your fridge an RM360?
Is there a window in the kitchen?
Is there a furnace?
What is the model of your 120 to 12 VDC converter?
The list to date, (now in order of the four digit sequence number):
Chris:.......45- 1100711...'78 : Front Gaucho (Thank you Chris)
Scot M:....45- 1100893...'78: Front Gaucho
David:......45- 1101043...'78: Front Gaucho
Unknown:45- 1121172...'79: Front Dinette (assumed)
Noreen:....45- 1121733...'81: Front Dinette
03-19-2013, 10:39 AM
#32
Is there a furnace?
Hi, David. here are photos and some datas from the trailer. It has no front shelves, it's look is uniform with rear couch with leather? or vinyl bottom. The door latch works but previous owner lost his key and the additional one was changed the location by me. I also replaced rusty screws with aluminum rivets( you can see in photo). There is no furnace, but has 3way fridge and kitchen window. Hopefully these photos help...
03-19-2013, 10:42 AM
#33
Some datas
Here is from ownership : V.I.N 131116743-Trillium, Model 130, Year 1980, Weight 480kilograms
03-19-2013, 11:09 AM
#34
Umm.... are you sure about the VIN? 13- 1116743 is not what I would expect for a front gaucho 1300. The previous ones had a 220 in the place of your 111, but that might be due to the almost front dinette gaucho on your unit. The last photo on your post is almost exactly what I was looking for. If you could give a wider view, then I could see the VIN.
I think I found the add for your trailer:
ON (Canada) - 1974 - Trillium 1300 - $1800
What a great trailer! And a great deal! Your fridge looks to be a RM211, you have the kitchen window, and while you don't have a furnace, your trailer is set up for the Coleman forced air furnace. Not sure where you would find one of those. The fibreglass of the bottom of the gaucho is set up like a front dinette. This would make changing it to a front dinette fairly easy. At the same time, you also have a block of wood that the upper bunk fall prevention bar would mount to. I notice some kids toys in your pictures, If you have two kids, the bunk makes sense, but if you have one, then the dinette would work.
It looks like you will need to re-install your door. This is a common problem with fibreglass trailers.
Really nice trailer!
03-19-2013, 12:27 PM
#35
..Thankyou. The price of 1800Can$ is what exactly I paid after the ad was posted within 12hours. About the year of the trailer, I didn't pay attention because I woud bring her home and refresh her anyway. I do have 2 kids, but one of them is.... "heavy set". So, that's why I will try to remodify bunk bed for them to fit with all of their laptops, toys...with both power sources 12VDC and 120VAC, also cup holders and disc storage/mini tables for...each. Here is what I read in the piece of paper that you gave me the hint: Serial No, 13-1116743, GVW 1500lbs-680kgs, Issue no.(at right bottom corner of page: 380551. Enclose are better photos for you...
03-19-2013, 12:55 PM
#36
I noticed that in the ad, the year was advertised as 1974, how did you know it was 1980? The serial number puts it as 1979, or later.
As for the gaucho, the bottom bunk will support an adult, the top bunk is only good for around 45 kg, (100lbs).
The updated list:
Chris:.......45-1100711...'78 : Front Gaucho
Francesca:45-1100758...'78: Front Gaucho
Scot M:....45-1100893...'78: Front Gaucho
David:......45-1101043...'78: Front Gaucho
Unknown:.45-1121172...'79: Front Dinette (assumed)
Noreen:....45-1121733...'81: Front Dinette
David: .......13-609..........'73: Front Gaucho
David: .......13-1105688...'77: Front 1/4 Bath
Spanke: .....13-2205863...'78: Front Gaucho
Brett: ........13-1106227...'79: Front full bath
Randy:........13-1116743...'80: Front Gaucho (almost dinette)
03-19-2013, 01:29 PM
#37
The updated list:
Hi, David. I have two kids, a boy and a girl. The boy, the youngest, weighs 135lbs at age of 10, heavier and with bigger shoe size than mine. About the year of trailer, I just read it from the ownership card.
03-19-2013, 01:37 PM
#38
Trailer: '78 Trillium 4500
Hey, Randy!
When you say "ownership card", do you mean the registration papers you got with the trailer?
And if so:
Do they have the same number on them as the serial number listed on the papers you posted a picture of earlier?
Francesca
03-19-2013, 02:18 PM
#39
Originally Posted by Francesca Knowles
Hey, Randy!
And if so:
Francesca
Hi, Francesca. Yes, I do. In fact, yes, it does. Here is what were written on my ownership card: Brand: None, Plated, V.I.N: 131116743...Made: Trillium, Model 130, Year 80, Body type: TV, Axles: 01, Colour: CRM, Veh Wt: 00480kg
As you can see, there is one the same serial number of the trailer as posted in earlier photos. FYI. Thanks.
03-19-2013, 03:46 PM
#40
Model 130, hmm.... My second 4500 was registered model 450 when I bought it. It is strange to me that they get this stuff wrong over the years. How many trailers have we seen that are labeled with the wrong year.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
