Serial numbers on a Trillium - Page 34 - Fiberglass RV
Old 09-26-2018, 12:42 PM   #661
Trailer: 1979 Trillium 1300
Connecticut
Exterior of my 1979 1300
DHolhubner is offline   Reply With Quote
Old 09-26-2018, 03:39 PM   #662
David Tilston's Avatar
Thank you very much Diane!
A few observations:
- The cupboard doors have been replaced. They look much better then the stock particle board with mac-tack.
- The lights above the dinette have been replaced. But only at the rear. Originally there would have been lights on the side shelves as well, (is that small circle on the curb side a light?)
- The back rest/upper bunk of the gaucho is missing. I have done some drawings, if you want to replace it:
1980 Trillium 4500 Bunk Bed Plans
- The fridge is not original
- The T-Molding is getting a bit wavy. It needs to be boiled. Yah, I know it sounds crazy, but it just snaps into a socket strip that is glued to the fibreglass. Pull it off, put it in boiling water and then lay it out to cool. It will cool flat. Then reinstall it.
What is below the kitchen cupboard?
What does the outside curb side of the trailer look like? Was there a furnace at one time?
Old 09-26-2018, 03:55 PM   #663
Connecticut
Hi David,
The previous owner replaced the cabinet and closet doors. He also rewired and installed LED light fixtures and updated the plugs. I have the whole upper bunk. I decided I wasn't going to use it so I detached the board, removed it and currently the cushion is over on the other side on the bed/fold down table (my son didn't fit on the bottom bunk with it still there). I forgot to put it back on the couch before taking the photo. Previous owner installed one LED puck light on the upper right shelf above the fold down table area. The owners manual for the fridge indicates it was purchased and installed in 2013. Electrical system has a new Deep cycle AGM battery and a new WFCO power converter and is set up so I can easily hook up a solar panel from the outside. The axle was replaced within the last 3 years with new electric brakes.
My projects will be straightening out the T-Molding and I'd like to polish up all the aluminum window frames inside and out.
There was a furnace below the sink but that was removed by the 2nd owner, I'm the 4th owner. That area is now a nice cabinet to put in pots and pans. I'll take a photo from the other side.
The fact that all the major work has been done was appealing to me as I don't have the time to do it, just enjoy it! I'm very happy with it!
Old 09-26-2018, 03:57 PM   #664
Connecticut
Also, when I travel alone I think I will convert that couch to a dinette. I've got two cushions that should work for the seats and I think I've found a folding table that is the right size. When I come to the rally I'll bring everything.
Old 09-27-2018, 09:04 AM   #665
Based on this post:
New 1300 Trillium owner...
I have the serial number wrong on the list 13-441, not 13-411.
Old 01-02-2019, 04:29 PM   #666
I am still finding new Trilliums on the Random Images:
Fiberglass RV - Westcoastapril's Album: 1983 18ft Trillium 5500 - Picture
Old 03-01-2019, 09:35 AM   #667
Trailer: 71 Trillium 1300
Nova Scotia
Hi David -
Serial Number 13-28 manufactured in Richmond Hill Ontario checking in.
tim42 is offline   Reply With Quote
Old 03-03-2019, 03:16 PM   #668
kbingel's Avatar
Trailer: 1975 1300 Trillium
Adding our 75 13 ft trillium number
Hi,
We now have a 75, 13 foot trillium. it's number is: 13-1104479
We are just now starting to fix it up. It doesn't have the original furnace or refrigerator. We are looking into adding both....but need more info and that's for another thread.
John and Karen
75 Trillium 1300.
kbingel is offline   Reply With Quote
Old 04-12-2019, 04:21 PM   #669
New Trillium 4500 owner...
I had the pleasure today of finally finding my Fiberglass Trailer, after many years of searching, and losing out on several opportunities, either by timing, location or price...
I finally came across a 1981 Trillium 4500, that has been stored in a garage for what the current owner believes to be around 12 -13 years.
He says it may be one of the last off the line?
Other than the front left corner hitting a branch, which has been fiber-glassed on the inside and now solid, the exterior needs the same, which I will do,
as the remainder of the trailer is in good condition, and I am looking forward
to updating and personalizing her.
Please add me to the Trillium list, serial # 45-1111714
Thanks, Ian
Jake is offline   Reply With Quote
Old 07-05-2019, 12:10 AM   #670
Dick's Avatar
Nor Cal
Hi, David and fellow Trilliumites, I am new to this forum. We have owned a 1979 Trillium 4500 for the last 20 years that we are getting ready to sell. It is serial number 45-1111545. It is mostly original except for some newly rebuilt running gear and everything still works. Here are some pictures:
I am sorry about the sideways pictures, they were copied upright and I don't know how to rotate them here.
The trailer has a gaucho front bunk which I removed but still have all the pieces to it. The hand pump stopped working (needs new seals) so the water tank is drained, but the plumbing is intact. There is a porta-potty (never used) in the hatch designed for it by the door. I added another cross member and a 2" receiver to the rear bumper. The door knob, the light over the sink, the thermostat for the furnace, and the propane regulator have been replaced.
The furnace, stove, and refrigerator all work with no gas leaks, and the reefer also works on 12v and 120v. All the lights work. Over all, it is in really good shape for a 40 year old trailer.
It has 500 miles on new hubs, bearings, brakes, drums, and backing plates. The torsion bars and tires are in good shape. It has a new 2" coupler and safety chains. The lights all work and the battery charges. It is extremely road worthy.
Let me know if you want detailed photographs of anything.
Dick is offline   Reply With Quote
Old 07-12-2019, 10:51 AM   #671
TiggyTheTrill's Avatar
Wisconsin
Post '79 Trillium 1300 with Front Bath
Originally Posted by David Tilston View Post
118 Entries
Just wanted to add my newly acquired Trillium 1300 to the list.
My sn is 13-1106034. It's a front bath layout, the title says it's a '79.
Is there an easy way to see the updated list? Can it be stickied or does it have its own thread? I can't find it when I'm searching.
Imgur album with additional pics
TiggyTheTrill is offline   Reply With Quote
Old 07-12-2019, 02:29 PM   #672
Roy in TO's Avatar
The link you referred to is likely the last time Dave posted one. He historically updates them in this thread. But he has not been around for a while, which is unusual.
His profile says: Last Activity: 02-28-2019 12:56 AM
He has not responded to my emails/calls this year, I am starting to wonder and get concerned if everything is OK on his end.
Old 08-28-2019, 01:12 PM   #673
Roy, I hope you got my text. I have been very busy lately. I have a job that I love, but it is very demanding. The rest of my available time has been given to my rather large family. The youngest child is now 12 his older sister, (15) now has a boyfriend and active social life. She had me take her and her friends camping at Crimson Lake this summer. Also, six of us went out to Vancouver to attend the graduation of another daughter, (21). Her twin is taking nursing at university. My oldest, (24) moved out a couple of years ago, but came to Vancouver with us.
I have copied the serial number lists and will be working on them for another update.
trillium
uhaul serial numbers and tracking andrew78 General Chat 6 11-12-2019 01:38 PM
Trillium 1300 Serial Number Rick Mooyman Problem Solving | Owners Helping Owners 8 04-30-2015 05:22 PM
Possible trillium--no title, no serial # jenbooks Care and Feeding of Molded Fiberglass Trailers 42 04-23-2012 04:20 PM
production numbers Perry Mac Donald General Chat 3 05-12-2010 07:13 PM
numbers BAMA & Pachyderm Posse Forum Admin, News & Announcements 1 02-15-2007 11:01 PM
