Smoking Batteries (was: Battery problem in our Parkliner) - Fiberglass RV
Old 05-11-2013, 05:38 AM   #1
Mimi Lee's Avatar
Trailer: Parkliner
So, We took our Parkliner trailer out after 5 months storage yesterday and woke between 3-4am this morning to a bad smell. We opened the power section and found that both of the batteries were smoking and quickly evacuated the family from trailer, smoke alarm blaring.
It was scary and we are shaken up a bit but thank goodness are all safe. And in contact with the manufacturer this morning so that is a little comforting, who is replacing the blue top marine batteries to a different type. Hopefully that's the correct fix for the problem.
Mimi Lee is offline   Reply With Quote
Old 05-11-2013, 05:45 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
It doesn't make sense that both batteries would fail in this manner simultaneously. I suspect that you have a short circuit somewhere with inadequate fuse protection.
In my UHaul, I installed a 30 amp circuit breaker right at the battery terminal so that any wire past the battery terminal itself is protected.
The photo that Deryk posted of his batteries had a metal hold down strap across the batteries that looked like it could shift and short out . Check this out, too.
Old 05-11-2013, 06:02 AM   #3
Mimi Lee's Avatar
Trailer: Parkliner
Thanks for commenting Thomas. I was thinking the same thing-- what are the odds of both batteries!? I like the idea of the circuit breaker at the battery very much, especially after this incident. We'll want to do that for sure.
Old 05-11-2013, 06:09 AM   #4
Mimi Lee's Avatar
Trailer: Parkliner
After the smoke cleared. Shuddering to think our heads were resting above this.
Old 05-11-2013, 07:21 AM   #5
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Battery placement has been revised but the hanger strapping retained. Aren't there better holddown/racks available for AGMs? Deryk's looks like the strap is in close proximity to the terminal but he's had no scary incident that I've heard about. The strapping does look like a cheap and cheerful make do IMO.
jack
Old 05-11-2013, 07:58 AM   #6
Ed Harris's Avatar
So is there any clue as to what happened now that you can see in there?
I can't see anything obvious looking at the pic you provide?
Either way be sure not to do anything else without figuring out what happened,batteries should not just smoke like that!
Obviously I hope.
Old 05-11-2013, 07:59 AM   #7
Raz
Raz's Avatar
Vermont
If it was something other than the batteries you should see melted insulation. Look for damaged wires. Use your nose and sniff around. It also could be the converter failed to switch to float mode. As far as the tie down, a battery box screwed to the floor might be a solution. Good luck, Raz
Old 05-11-2013, 08:01 AM   #8
Trailer: FunFinder
Most likely something more serious than just bad batteries. Have your tech very carefully check out your convertor. Sounds like some level of unregulated voltage possibly going to the battery.
An internally shorted battery can also fail catastrophically ( I was near one that exploded one time....blew the top off the battery and sent acid all over everything....lucky no one was close by the open hood of the truck ).
As for having a metal strap running across the top of a battery, that is quite simply dangerous and a foolish thing to do. Not trying to sound mean about it, but just trying to be ( brutally ) honest.....that is dangerous.
gmw photos is offline   Reply With Quote
Old 05-11-2013, 08:16 AM   #9
cpaharley2008's Avatar
Those batteries do not look like they are properly hooked up. I noticed in the Parkliner's prototype 2 years ago that they hooked up only one battery with the second being a slave. You need to have converter positive to battery A and converter negative to battery B with the remaining posts connected positive to positive and negative to one another. That way the pair are treated as one big battery for charging purposes. The wrong way will only charge the first battery. See here http://www.gearseds.com/files/twobat_onechgr2.pdf
Old 05-11-2013, 08:27 AM   #10
Jim,
What you're describing is for two 6 volt batteries which you could connect is series to get 12 Volts. I believe these are 12 volt batteries.
I'm suggesting that the batteries were pretty well run down after being in storage. The converter attempted to charge them with a higher current than the AGM batteries could handle thus overheating the batteries. Something else to check out.
Old 05-11-2013, 08:29 AM   #11
No, I'm suggesting 2x12v in parallel series. Look at the diagram. Hold on, another diagram. How to Charge Two 12 Volt Batteries with One Charger | OverlandResource.com
Old 05-11-2013, 08:35 AM   #12
Maybe my eyes are deceiving me, but I see in both cases White wires to the Negative terminals and Black wires to the Positive terminals.
Old 05-11-2013, 08:35 AM   #13
rabbit's Avatar
Delaware
Looked at your diagram. Two 12V in parallel look exactly like Mimi's setup. So many conductors in the lugs on Deryk's I can't tell where they're going. I agree with Byron; think you're thinking of the two 6s in series.
jack
Old 05-11-2013, 08:47 AM   #14
See post#11 for diagram of proper hook up to your converter/charger. This eliminates the slave battery situation another source http://www.gearseds.com/files/twobat_onechgr2.pdf
Parkliner Electrical System & AGM Battery Charging-Maintaining accrete Electrical | Charging, Systems, Solar and Generators 15 05-16-2013 06:03 PM
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
NYS announced no smoking. Mark and Tara General Chat 10 04-14-2012 05:58 PM
Battery box for 3 - 12v batteries ? Dave Storey Electrical | Charging, Systems, Solar and Generators 14 11-01-2010 07:38 AM
Battery Problem Roger L. Problem Solving | Owners Helping Owners 7 10-03-2006 11:16 PM
