Snoozy Owners (check valve) - Fiberglass RV
Old 03-30-2014, 05:40 PM   #1
carlkeigley's Avatar
NE Oklahoma
When we pulled the Snoozy out of her house,
the wife cleaned and decluttered the inside.
I cleaned the wheels and carried the clutter
into the house. Then she brought me some small
pieces of pvc which she did not know what they were.
I knew there should not be anything like that to my
knowledge, loose anyway. I looked under the couch
and there I found a broken check valve. I thought it
was a union of sorts. You couldn't see what you see here.
I reconstructed the valve for these pictures.
This is a 1/2" PVC In-Line Check Valve w/SS Spring (Threaded)
The part is a Matco-Norca 523T03.
On the computer the only place I could find was PexSupply.com
They show $3.48 each. I'm posting this as I think it might be
a good idea for Snoozy owners to perhaps carry a spare. Parts
are supposed to be found at Lowe's H.D. etc. but in my area
there's no place that carry these. You may never need a fix and
this may be the only defective one on the market. I ran two heaters
to be sure freezing wasn't an issue. But looking at the break it
looked like a defect to me.
I did learn how to understand how the City Water Supply and the
Water Tank System co-exit and operate. Would rather stayed
ignorant on the subject, but understanding is the up-side to this.....LOL
Old 03-30-2014, 05:49 PM   #2
NE Oklahoma
The fix.
The only fix I could find after going to a dozen supply
houses, was the last Lowe's I went to a lady that was
over the plumbing department came up with this as a
possible solution. It was the nearest match (size wise).
But it was a 3/4" thread on both ends so also had to come
up with a 3/4" thread to 1/2" thread reducer. It has
Pro Plumber tag on the part but I don't have the box with
me to get a part number.
A closer shot, but too much reflection.
The only way to install it was to take the fitting loose from
the water pump itself. Then you can install the components,
install the water pump fitting into the check valve and reconnect
to the pump as it's a compression fitting.
Old 03-30-2014, 05:57 PM   #3
NE Oklahoma
These are shots of the finished install.
This is for drilled well water system.
The Snoozy part is rated at 150 PSI at a Max Tem. of 122 Deg. F. (50 Deg. C)
and .5 PSI Spring Loaded.
I could find no PSI for the loaded side of this valve.
It may be too high for a permanent fix. That's why I
suggest Snoozy owners to maybe carry a spare just in case
they find the need. They are not eazy to find in my neck of
the woods.
Old 03-30-2014, 05:58 PM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Thanks for sharing Carl. I guess I'll see about picking up an extra one when we pick up our Snoozy.
Dave & Paula
Old 03-30-2014, 06:06 PM   #5
NE Oklahoma
You're welcome Dave.
The water pump part number is:
SHURflo Pentair water
OEM: 4008-101-A65
AFTERMARKET: 4008-101-E65
Both numbers are for the same part, but the aftermarket
uses the E instead of the A.
Just a FYI.
Old 03-31-2014, 01:43 AM   #6
cpaharley2008's Avatar
A little bit of advice, one should always use flexible hose in/out of the pump to eliminate vibration being carried thru the rigid pipe lines. They have "pump quieting kits" which is nothing but 2 short pieces of flexible tubing. Makes a world of difference.
Jim
Never in doubt, often wrong
Old 03-31-2014, 08:43 AM   #7
NE Oklahoma
Thanks Jim.
The Snoozy check valve is put in with
stiff pex pipe.
Old 03-31-2014, 10:28 AM   #8
blodn1's Avatar
Trailer: Prius camping - want an Oliver
Virginia
Could be the vibration caused the break. Think I'll put flexible hose on my build list.
I don't get lost, I go on interesting side trips.
blodn1 is offline   Reply With Quote
Old 03-31-2014, 01:51 PM   #9
Here is a lik to the kit mentioned Amazon.com: SHURflo 94-591-01 Pump Silencing Kit: Automotive
Jim
Old 03-31-2014, 01:52 PM   #10
Mine has a flex hose as well but I am wondering if perhaps there was some water in the check valve over the winter which froze. Have seen a number of water pumps suffer due to that which is why I always pump anti freeze into the system through the check valve and pump.
Old 03-31-2014, 01:57 PM   #11
blodn1's Avatar
Virginia
Apparently, some owners had the cracked valve with no freezing issues. Since it was installed with rigid piping, I just suspect vibration is a cause - and freezing wouldn't help matters.
Shower Drain Check Valve Baj Problem Solving | Owners Helping Owners 12 10-03-2016 02:27 PM
ALL scamp (especially 5er) owners should check their axle brackets. Jared J Towing, Hitching, Axles and Running Gear 5 12-30-2012 11:32 PM
dump valve - leak at knife valve Doghaus Problem Solving | Owners Helping Owners 3 09-29-2011 11:30 AM
Check your rubber tire valve stems Steve C. Towing, Hitching, Axles and Running Gear 15 07-02-2010 10:48 PM
Dog owners ~ check your food Gina D. General Chat 6 01-13-2006 10:33 PM
